Rad2Go E36 Build
Re: Rad2Go E36 Build
Postby E-racer » Fri Apr 13, 2012 11:25 pm
I press fit my sprockets. If its 12mm clearance hole in the sprocket you are going to have to drill and pin probably. You could also key it or weld it.
Kona Stinky: custom swing arm w/ batteries
-13s3p Turnigy Li-po
-Turnigy 80-100 rewound 130kv (Burtie's optical board)
-Kelly KBL 48201
-Nuvinci Dev Kit
http://endless-sphere.com/forums/viewtopic.php?f=28&t=35341
Goped ESR750
-12s2p Turnigy Li-po
-Turnigy 80-100 HXT w/halls
-Kelly KBL 48201
http://endless-sphere.com/forums/viewtopic.php?f=35&t=20732
E-racer
Postby milesinfront » Sat Apr 14, 2012 12:17 am
I don't think press fit is for me as a) I don't have the technology to make a press fit b) sprocket needs to be removed easily for gearing changes and motor install/removal. Not enough 'meat' to key it (lack of technology also). I think drill and pin with grub screw may be the answer... Thanks! :)
milesinfront
Postby E-racer » Sat Apr 14, 2012 1:13 am
I recommend drilling an 1/8" through hole and using a hardened roll pin like this one. http://www.mcmaster.com/#roll-pins/=h3irwy
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby milesinfront » Sat Apr 14, 2012 1:27 am
Thanks for that. I had considered those, but didn't know what they were called...
milesinfront
Postby E-racer » Sat Apr 14, 2012 1:32 am
I've never had great luck with set screws to constrain sprockets. The ones on the other side of the 80-100 (in the orange aluminum) hold OK but they will develop slop over time.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby milesinfront » Tue Apr 17, 2012 5:20 am
So today I spun the C80100 for the first time! I think I fluked the wiring:- Motor spun in the right direction. Runs smooth at low revs, so I guess my sensors are wired right too! BUT - Motor cuts out at full throttle. I'm not sure if it's losing sync or it's the LV setting on my controller. Lyen preset mine for 20s, but for my test I was only running 13s. To begin with, the motor would spin up to a certain RPM then die. After a second if would run again. But after a few minutes of playing it would stop for longer and longer periods of time. I suspect that I'm right on the voltage cut-off, and at open throttle I was getting some voltage sag which crossed the threshold.
Now the other problem is that I'm having trouble reprogramming the controller. I've PM'd Lyen for some assistance...
I may have also possibly fluked the trigger wheel position! While I couldn't get to full throttle, amps never went over 2! Am I celebrating prematurely???
And some pics of the test:-
milesinfront
Postby milesinfront » Tue Apr 17, 2012 4:57 pm
Doh, just realised that I was current sensing off one of the phase wires, NOT battery, so my no load current is still unknown... Lyen has replied asking for my model and serial numbers, which I have given. Hopefully I'll be able to have another crack at it soon, but am VERY busy with work for the rest of this week... :(
milesinfront
Postby milesinfront » Tue Apr 17, 2012 5:24 pm
Lyen came up with 'the goods' on the controller programming, so another issue solved. Ready to re-test now! :)
milesinfront
Postby milesinfront » Mon Apr 23, 2012 5:41 am
Had some more time testing the motor/controller today. After fully charging the batteries, the intermittent no-run situations have gone, but I'm still having trouble. After a certain rpm (2/3 throttle) the motor runs rough, and stops. After playing with the trigger wheel angle, I did get it to run to full throttle about 75% of the time. It sounds awful! I don't know if it's a balance thing, bearing thing or the controller loosing sync. I do need to make a better bracket as the very springy bent alloy one is vibrating the trigger board HEAPS too, but even while steadying with my finger it still sounds BAAAD. And this is at 50 volts! The plan is to run ~75 volts!
The only good news was seeing 6-7amps no load current (+skirt bearing) at full throttle...
milesinfront
Postby Burtie » Mon Apr 23, 2012 6:53 am
You need to fix that trigger board vibration.
Beyond that:
Play with the distance to the trigger wheel,
Play with the timing. Only a very small mechanical adjustment can make a BIG difference, remember that 1 mechanical degree is equivalent to 7 edegrees with this motor.
Shield the sensors from any possible light interference
Make sure your encoder image has the right optical properties, look at the sensor signals with a meter or 'scope as you turn the motor, to make sure they are working as they should.
Burtie
Postby milesinfront » Tue May 01, 2012 4:55 am
Latest news:-
Ordered and fitted new bearings to the C80100. They're 2RS' so no efficiency is gunna suffer some, but hopefully will be more reliable long term.
Welded the motor mount to the frame:- Ugly but effective!
Ordered and received roll pins for 'staking' drive sprockets.
Ordered halls for internal mounting. Motor is apart, so may as well glue some in and see... ;)
milesinfront
Postby milesinfront » Wed May 02, 2012 4:27 pm
Changed my mind again... Reassebled motor without halls. Thought of a much better way to mount the optical board, and incorporate a more precise way to adjust the timing... Will post pics when done!
milesinfront
Postby milesinfront » Fri May 04, 2012 6:38 am
Here's my progress on timing adjustment... The long screws may confuse, but they will be shortened...
milesinfront
Postby Bluefang » Fri May 04, 2012 7:32 am
You seem to be having fun with your project, all the cut out pieces your making really look nice
viewtopic.php?f=10&t=49912 Current build, Electric flat tracker
Bluefang
Postby milesinfront » Fri May 04, 2012 5:02 pm
Fun? Yeah I suppose... ;) It's definitely fun when all the parts fit and work properly! I just hope the effort yields the results I am looking for...
milesinfront
Postby milesinfront » Tue May 29, 2012 5:56 am
Another mile stone! Testing motor and opto board on frame. For the first time I was able to reach full speed! I was amazed how smooth the motor became once the revs went into crazy land! (54.6v x 130kv = ~7krpm?) Best no load current was a less than impressive 12.5amps. Not surprised considering the rubber sealed bearings I fitted. More alarming is the motor and controller temp. Getting hard to touch and I'm not even doing anything yet... :?
Quickly ran out of time, but after attaching the wheel and chain I could no-longer hit full rpm! Controller would cut out at about 1/2 throttle. I'm suspecting voltage cut-out again! Will re-charge the batteries and try again another day...
Dam these outrunners are noisy!
milesinfront
Postby milesinfront » Thu Jun 28, 2012 5:51 am
Quick update:- Stripped the motor and reassembled with internal halls. I did a quick bench test and the results are very promising! Controller didn't lose sync once, no matter how violent I was with the throttle. Motor is nice and smooth and quickly ramps up to full speed. I think I'm on a winner now, but am worried about long-term reliability of the halls and wiring in such a harsh environment... Time will tell! :) Hopefully a test ride tomorrow! :D
milesinfront
Postby milesinfront » Fri Jun 29, 2012 1:15 am
Quick test ride:- HOLY MOTHER OF GOD!!! This is one ANGRY scooter! Max amps is less than half what the unite was pulling (64 vs 150) and bottom end is twice as strong! I will need to increase the current limiting substantially as the throttle response is just silly... :twisted:
milesinfront
Postby E-racer » Fri Jun 29, 2012 6:19 pm
Yea you really dont appreciate an 80-100 till you ride one :-)
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby milesinfront » Fri Jun 29, 2012 8:09 pm
New top speed - 57.3km/h! This motor/controller combo feels like a 2-stroke, with a supercharged bottom end! Initial launch is brutal, then the torque plato's. Just when you think that's it, it suddenly comes on 'cam' and there's a top end hit! It's SOOOO awesome! I've just parked the scooter and I'm still shaking...
I spent about 20secs at full speed and nothing is more than just warm. No hot bits or electrical smells. I'm a VERY happy camper! Will get some video ASAP...
milesinfront
Postby milesinfront » Mon Jul 02, 2012 5:45 am
Discovered some things today which I didn't know...
The motor is a 180kv version! Spins the rear tyre at just over 1510rpm with 13s pack. Gearing is 9/54t... (9060rpm)
I didn't realise that the current doesn't taper off as quickly compared the the brushed motor. (makes sense, variable electronic commutation vs. mechanical) My 60A current limit is possibly knocking a little off my top speed. (I'm too scared to look down and read the CA display at full speed.) eBike Calc predicts max velocity at ~80amps...
No load current (inc. drive train and wheel) is 11.5 amps.
milesinfront
Postby milesinfront » Tue Jul 03, 2012 2:50 am
Max amps are now at 110! I programmed the controller to 100 amps. I wanted to set it at 80 amps, but the software jumps from 64 to 100 for some reason...
My quick test ride included MANY unintended wheelies! What a beast! :) Wrong time of day to go for a max speed run, so the current record of 57.4km/h still stands.
Of course the only true measurement of power is turning rubber into smoke:- :twisted:
http://www.youtube.com/watch?v=jXYLsrtP2ec&feature=plcp
milesinfront
Previous
Return to Stand-up E-scooters and E-skateboards
