Doctorbass wrote:Ah interesting.
Also I see alot of past projects in standby mode...
What was Gordo doing there?
Doc
Doc
Gordo wrote:Doctorbass wrote:Ah interesting.
Doc
Did my frog toque give me away?![]()
I've been following Randy's builds for 10+ years. His prices on batteries and parts are great for us, as his volume buying and being local make for low end cost. Shipping adds a lot if we buy elsewhere.
Arlo,
That scooter rear axle you were moving around in the basement, might be good for something with the kid builds? It has a sprocket and differential on it.
liveforphysics wrote:With sub 150vdc batteries, the shock hazard makes no difference if they are capable of delivering 1million amps or 1amp. It only pulls what your bodies resistance can draw, which will be tiny unless you've pierced the skin and gone into the blood which conducts well. (and even then, very high current shocks rarely kill as often as low current shocks)
I touch <150vdc batteries capable of 1,000's of amps on a daily basis. I can't even feel a tingle from under 60-70vdc, even if my fingers are wet.
The risk is arc-flash blinding and burning kids. Or if you're using lead, the risk of kids splashing acid in their eyes or cells exploding when shorted.
Lebowski wrote:very cool stuffcan you imagine ripping with one of those through the sand ?
Arlo1 wrote:Just got confermation they will let us run this in the 1/8th mile at victoria! We are hoping to be the first electric anything down the track! Should be a couple weeks! And with the power to weight the numbers will be good to get some atention!!!
