Simon.
curious wrote:NeezyDeezy wrote:When it's plugged in it by default comes on high, without buttons, so depending on what you want to do a switch would work.
Not sure we are talking about the same light. I just got the MJ-808E XML head from geomangear and it does not "remember" the power setting and always comes in the "off" state when plugged in. The remote switch is not an option.
Few notes for those considering it:
- It takes 0.8A on full at 12.5V, there are 3 levels of brightness and no blinker.
- It has a clearly defined round spot (a bit small to my taste, I am used to flood beam) and rather weak flood area.
- The color in the spot is a pleasant white (warmer than my trailtech HID) with no blue tint (if anything there is a very slight greenish tint to it). There is some blue tint in the flood area but not in the spot.
- Mounting may be a problem for some, the light does not pivot and sits very close to the handlebar (uses rubber rings instead of a usual clamp). It may interfere with the cabling because of proximity to the handlebar (it does on our bikeE recumbent had to move things around to mount it).
NeezyDeezy wrote:Hi, I'm really sorry - I didn't mean to lead you astray. I received my magic-shine 1000 lumen light from geoman gear in September 2011, and it DOES come on high on being plugged in. Something must have changed since then with a newer or different model. If you don't want it and can't return it, I might be able to buy it from you.
Duc998 wrote:Can anyone confirm this light works off the aux off the CA. Looking to keep it simple and if I can wire the light up to the CA that would be great. Mines a CA-DP.
GCinDC wrote: i think i'll end up cutting a lot of the extra cable before and after the driver
