Group Buy? Dr.Bass Steveo found 7s3p Module! Awesome Price!!
Re: Group Buy? Dr.Bass Steveo found 7s3p Module! Awesome Pri
Postby bigmoose » Sat Apr 28, 2012 11:21 am
Dave please present your proof that the loose cells are "krap"... Until folks get these modules and disassemble, we don't even know the usable tab length after you cut them free from the bussbars. Clearly 60AHr is too large for a bike or Trike...
Please present your test data or links to sources that did test them... We, as a community, are in an attempt to discern where the defective cells are, and at what percentage.
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby peterperkins » Sat Apr 28, 2012 11:49 am
I'm curious about the bus bars. :?
They are laser welded onto the tops of the tabs as far as we know.
But what are they made of?
Are they two different metals on each side to fuse with the copper or aluminium tabs?
Joined somehow along that dotted line between 3 pos and 3 neg tabs? Or is that some sort of fusible link?
Anyhow if we assume the bus bars are one type of metal then using a dremel to seperate cells cutting exactly in the middle of the spaces between cells but leaving the laser welded part on the tab it would seem a trival job then to overlap the part and flow solder onto the bus bar metal rather than the tab itself.
If that makes sense.
Honda Insight MK1 lmpg 131mpg Imp
Lifepo4 40ah HiPower IMA Pack & 20ah A123 IMA Pack
BCM Fooler, BCM Interceptor, BCM Gauge, Li-Ion BMS System, OBDIIC&C, IMAC&C
http://www.150mpg.co.uk
peterperkins
Postby Harold in CR » Sat Apr 28, 2012 1:16 pm
Makes sense to me. That is exactly how I figured to cut cells loose and reattach to leads.
Just waiting for someone to get one and open er up. :lol:
Thanks to Justin, the forum is open source and NON-commercialized.
http://www.costaricacraftwood.com
Harold in CR
Postby miro13car » Sat Apr 28, 2012 1:42 pm
dave,
bigmoose's thread is reposted here by Devries,
bigmoose did not post here his thread with pictures above.
miro13car
Postby davec » Sat Apr 28, 2012 2:28 pm
regardless- who posted what- he was only making a reference - i'm not going to argue over loose cells on here- we should keep this a module thread for folks curious about the 7s3p packs- cheers
davec
Postby deVries » Sat Apr 28, 2012 5:42 pm
davec wrote:i'm not going to argue over loose cells on here- we should keep this a module thread for folks curious about the 7s3p packs- cheers
I agree we should not *argue* over the loose cells, BUT the loose cells make modules. The *source* of the defect is some type of misalignment involving the "torch" (laser) AND the cell. It is perfectly reasonable to speculate on this thread with the kind of quality post, i.e. excellent observations & documentation, that BigMoose made (that I re-posted here from another thread).
BigMoose found two different cell anomalies that may be directly or indirectly related to the defect. It is very helpful to have that informative knowledge posted on this thread for reference purposes & it is definitely "On Topic". 8)
peterperkins wrote:Anyhow if we assume the bus bars are one type of metal then using a dremel to seperate cells cutting exactly in the middle of the spaces between cells but leaving the laser welded part on the tab it would seem a trival job then to overlap the part and flow solder onto the bus bar metal rather than the tab itself.
Yes, it makes sense to me too. I've posted this same idea 2-3 times in this thread too, search on dremel if interested, so I'm hoping this is correct. Here's to hoping! :!: :mrgreen: Someone will explore this possibility once the modules are in our devious (KFC black & scarred) hands. :twisted: :shock: :lol:
deVries
Postby bigmoose » Sat Apr 28, 2012 5:52 pm
You gents will know soon enough. ... but I have been speculating from the photographs. I opine that the "buss bars" may be two different materials ultrasonically welded where we see the crimple zone about halfway down, or between 3 cell stacks.
Next it looks like the clearance through the black plastic "cap" is small. So one may not be able to extricate a cell by dremelling off only one side of the "bus bar". That slit in the plastic cap or header may only allow the cell tab through. If that is the case, then the tabs might be too short to reuse in this great and nifty packaging, and an alternate cap may need to be fabricated to do the interconnects for 1PxS.
The A123 packaging design looks really nifty. I sure hope it can be reconfigured.
bigmoose
Postby liveforphysics » Sat Apr 28, 2012 6:01 pm
Just having a 60Ah pack is not too bad of a thing either. :-)
A pair of these modules in series to make a 60Ah 14s pack would be a pretty nice ebike setup. It's going to hold about 45v for you until the cows come home, and that's enough voltage to make a mean bike if you just use a higher kV motor and don't mind needing a little larger wires.
liveforphysics
Postby Kirk » Sat Apr 28, 2012 7:12 pm
bigmoose wrote: Clearly 60AHr is too large for a bike or Trike...
I've never had the chance to do anything with A123 cells but my tike does just fine with 64 Ah of Zippy Lipo at a bit over 50 lbs. Why would 60 Ah of A123 be too large?
Stable:
05 Catrike Road (Yellow), 20" 48V 1000W GM hub motor,12s24Ah Lipo batt.
12 Catrike Expedition (Candy Purple), 18s32Ah Lipo batt. Lyen 18 FET low RDS controller, C'Lyte HS3540 hub motor, CA-SA, Mueller Bros. Windwrap XT fairing, Terra Cycle Cargo Monster extension. Still evolving, should be interesting by next Spring.
2011 Roll Over America tour, 50 Velomobiles, 5000 Km, 24 days, Portland, OR-Washington DC, July 28th-August 24th 2011, damn I was tired after that.
Kirk
Postby deVries » Sat Apr 28, 2012 8:22 pm
liveforphysics wrote:Just having a 60Ah pack is not too bad of a thing either. :-)
+1
Hey, Luke, has had (or maybe still does) have a crap-load of LiPo Ahrs on his commuter bike. What was it Luke? :?:
I think it was somewhere between 40-60Ah at some point along the way of Luke's build. Maybe Luke can tell us what his higher capacity setup was? :?:
A 48v 42 cell pack in 14s3p 60Ah is going to weigh in at about 44-lbs just for the cells, so this 60Ah setup is obviously *not* for some high performance maneuvering bicycle or trail bike unless we bump-up to trials, motorcycle, or dirt-moped format. But a commuter bicycle with long-range AND less need to charge very often is definitely doable. Luke has mentioned the benefits of having a high-capacity setup to extend battery life *and* not have to balance often (if at all), because you don't have to drop the pack down to lower levels before charging again with that extra high-capacity on tap. :idea: :twisted: :mrgreen:
EDIT: Luke's Commuter Bike has or had: 25S (100v+) 25Ah of Nano's ... Sooo, covert that to 50v and the Ah goes to 50Ah. Btw, Luke's Commuter Bike is a Race Bike too! :twisted: :lol:
deVries
Postby texaspyro » Sat Apr 28, 2012 8:49 pm
The Mighty Volt wrote:Some very good advice in here, but I have one question: how do I know what the market price is to begin with?
Mavizen says the market price is X. Some unknown Chinese person on Alibaba says it is Y. Then somebody here says it is Z.
Thanks.
It's "Q". :roll:
texaspyro
Postby texaspyro » Sat Apr 28, 2012 8:57 pm
The last time somebody sent me something significant (around $10K) via DHL, they wanted certified copies of my birth certificate, social security card, and and the last two years of my income tax returns before they would deliver it because of alleged Homoland Insecurity rules. I told them that they cold go fornicate an aids infested hedge hog, and to return the package to the sender in London. He then re-sent it to me Royal Mail. It arrived two days later, I didn't even have to sign for it. No more DHL for me...
texaspyro
Postby SlyCayer » Sat Apr 28, 2012 9:16 pm
texaspyro wrote:The last time somebody sent me something significant (around $10K) via DHL, they wanted certified copies of my birth certificate, social security card, and and the last two years of my income tax returns before they would deliver it because of alleged Homoland Insecurity rules. I told them that they cold go fornicate an aids infested hedge hog, and to return the package to the sender in London. He then re-sent it to me Royal Mail. It arrived two days later, I didn't even have to sign for it. No more DHL for me...
Same happened to me, not that much value, but I was shipping to one of our customers in NZ and the wanted to use his DHL account, so we did, and they asked the guy basically every thing that had to do with his business, so he said no, did the same has for you, sent it by UPS and voila, it got delivered without a problem...
DHL has quit on Domestic shipping within the U.S. because they can't provide customer service, I have learned why.
http://www.JCCayer.com Where you can find tools and Dewalt(A123) batteries.
SlyCayer
Postby cwah » Sun Apr 29, 2012 6:42 am
Anyone knows the total weight of an 7s3p module? I know the cell are 0.480g. So a 21 cell module weight at least 10 kg.
But added as a module is it much heavier?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby deVries » Sun Apr 29, 2012 8:05 am
cwah wrote:Anyone knows the total weight of an 7s3p module? I know the cell are 0.480g. So a 21 cell module weight at least 10 kg.
Check back next week about Wednesday on this thread. I think we will know around that time frame next week.
deVries
Postby silentflight » Sun Apr 29, 2012 8:54 am
FYI guys,
Jack Rickard discusses the A123 module he ordered from China in this week's video starting at 24' 25"
http://www.evtv.me/vidarch.html
silentflight
Postby cwah » Sun Apr 29, 2012 8:56 am
Ok going to wait then.
Looking forward for the results :)
cwah
Postby Pure » Sun Apr 29, 2012 9:45 am
I'm watching this thread with great enthusiasm for this very reason. 3 of these would be perfect for my trike build. Mounting 2 on each side of the frame under my seat and one in the cargo platform behind my seat, the extra weight shouldn't really be noticeable. It's all about how and where you mount them. 72V 60Ah A123 goodness for less than a grand...*drools*
Mongoose DH
X5304
60V20Ah LiFePO4
I'm polymerized tree sap and you're an inorganic adhesive, so whatever verbal projectile you launch in my direction is reflected off of me, returns to its original trajectory and adheres to you. So there!
Pure
Postby davec » Sun Apr 29, 2012 10:05 am
silentflight - good find - very informative
that video certainly answers most of my questions - he claimed the module was used and had some bad cells in it - rebuilding/fixing these seems extremely difficult so i can understand why he gave up it's simply not worth it. Although Jack did a good review he could have still done a 1c test for us so we can see the specs on at least 1 cell. He made it clear why their dumping these on us- my personal guess is they might be coming out of used sources due to cells getting bad in them. how worn are they would be my next concern- and my last concern is the possibility to tear cells out to build a custom pack and how much tab is left after cutting them loose- and what's the process to do that.
the positive is that the cells are coming out of a legitimate factory built pack.
My only intention of getting one of these is to rip it apart take the cells discard the bad ones and build my custom pack.... i wonder if it's possible and how much effort that will involve... hopefully someone will have an answer when they get it on Wed...
davec
Postby mistercrash » Sun Apr 29, 2012 10:08 am
silentflight wrote:FYI guys,
I just finished watching the segment. Thanks for the link SilentFlight. For anyone interested, and for anyone who don't have the time to watch and still would like to know. After some testing, Mr Rickard is not too impressed by the 28S3P he got. First he was not pleased with the shipping and Paypal fees he paid which he said were more than the pack itself. Well a reason for this might be, like some think in this thread, that he was not successful negotiating with the vendor. I can't remember if it was said in here that the modules were new, the one he got definitely was not from what he reported. His opinion on the physical aspect of the pack is that it's over engineered and under built. The pack is very compact and very light compared to other alternatives to have the same kind of power. He reported the pack weighing 106 pounds. No words on exact dimensions.
When trying to do his "bottom balancing" technique, two cells were lower than the others. He managed to bring the voltage up on one but the second one went dead.
He tried to take the pack apart, probably to see if he could replace the dead cell. The straps that hold all the cells, heat sinks and end caps together are Stainless Steel which are spot welded, easy to take apart but difficult to put back on, the bus bars are welded to the cell tabs and DO NOT take solder, he wasn't able to TIG weld either to the bus bars.
He came to the conclusion that once a cell goes bad, the whole pack is trash since he feels it is not easily serviceable. For now his conclusion is that he doesn't want to keep tinkering with the pack and he doesn't wish to get a second one.
Not my opinions here, just reporting Mr. Rickard's view from what I can remember from the video. I found it interesting to watch as it answered a couple questions asked in here about the modules.
Is it ready yet?
mistercrash
Postby kevo » Sun Apr 29, 2012 10:27 am
Mistercrash,
Thank you for the summary on the video. The load times for the evtv were excessive. Disappointed to hear how difficult it was for Mr. Rickard to take apart the packs. Hope ES members are able to find alternative ways to reconfigure cells :|
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Postby JRP3 » Sun Apr 29, 2012 10:49 am
I wish Jack had dug a little deeper, but I'm sure the people here will. If he had dremeled off the weld on the tabs to see how much tab was left to work with it would have been informative. I'd think you could figure a way to clamp in a new cell to the existing bus bar. The band doesn't seem like big deal, just drill out the weld.
Building the AMPhibian http://amp-phibian.blogspot.com/
JRP3
Postby kevo » Sun Apr 29, 2012 10:59 am
JRP3 wrote: I'd think you could figure a way to clamp in a new cell to the existing bus bar.
Not ideal, but I suppose given the moderate weight (for ebikes anyway) could be an option. I'm waging (at least hoping) once units arrive people will step up to the task.
kevo
Postby mistercrash » Sun Apr 29, 2012 11:24 am
JRP3 wrote:I wish Jack had dug a little deeper, but I'm sure the people here will.
Exactly what I thought when I watched the video. Many in here don't give up so easily.
Edit: I want to make clear that I'm not insinuating that Mr. Rickard is a quitter. From what I've seen from his videos, I didn't watch all of them, he has been tinkering for quite some time with A123 cells lately and I feel he just didn't want to waste any more of his time with this module he got.
Is it ready yet?
mistercrash
Postby deVries » Sun Apr 29, 2012 5:18 pm
The 28s3p "bare" module weight *not* counting the cells is just under 18-lbs.
Cell weight is just below 89-lbs. 84 cells x 480g.
Total module weight is 106-lbs. EDIT: 106-lbs is only referenced verbally on video from Jack Rickard's 28s3p module. So, all numbers depend on the accuracy of his measurement. The weights below should *not* be on the low-side or underestimated, imo, so actual weights may be very slightly less than what is predicted below.
7s3p packs are therefore going to weigh about 1/4 the above numbers:
The 7s3p "bare" module weight *not* counting the cells is just under 4.5-lbs for module only.
21 cells add about 22.5 lbs, so total weight for a 7s3p module will be about 27-lbs or slightly less.
deVries
PreviousNext
Return to Battery Technology
Users browsing this forum: inoam, neptronix and 10 guests
