Recently I noted that these drill presses have a headless screw that serves as a pin guide to the chuck's column (the column has a small cut where the pin travels), and it reminded me that I removed the play on my dremel column by tightening this screw (also adding some lubrication to the chuck's column cut):
Now, can this screw be used to remove the play on these bigger drill presses or one really needs to put down a few thousand for a professional zero-play drill press?
