teacherphilenglish wrote:I have cyclone 960, GM 901, 902 and Magic Pie 3
I recommend the Magic Pie 3 hands down. $400, climbs good, very efficient, doesn't shut off after 2 min of non use (like cyclone) and doesn't care about water and snow.
I have a ping 36v20ah and it goes 50km road with hills, 60km road no hills, 15km+ steep climbing trail.
GM batteries are cheaper and have a case, but the small batteries have huge, heavy cases so ping is better for small batteries.
Diamondback wrote:i know you have now settled for the hub motors because of the noise of the cyclones.
in my noobishness, i was loading the cyclone too heavily on the climb up the hill also.
this contributed to the noise it makes.
thought i would share this short clip of my first ebike that was cyclone powered so you can hear the noise it makes.
by comparison, my current Geared hub ezee motor is almost silent. not as quiet as the DD hubs, but compared to
the cyclone, it's almost silent.
the ezee im running now can (with pedal assist) do 40km/h and it's great at climbing the hills.
it's rated at 550W at 48V, but because of the 60V (FOC) 48v ping, im getting about 1000W.
Jason.
jasonf150 wrote:I can't chime in on much here, but I've been running the hs3540 with a 36v nimh and it literally makes ZERO noise. I got mine in a kit from ebikes.ca. It's definitely disc compatible as I run my stock disc parts with it.
chilledoutuk wrote:I got my Nine continent kit from the Italian guy at a really good price including delivery.
http://www.wheelkits.it//index.php
I got a 6x10 with a 27amp controller and it averages about 15-16mph on the flats on 36v
It cost me 248 +26 =272 euros delivered about £220
he also does kits with a 45 amp 48/72v controller for 298 plus delivery which is 26 euros.
The delivery was very quick UPS if I recall correctly.
My 9c 6x10 kit has been great I've had it since December and have done lots of miles on it. It hauls my ass up hills unassisted no problem doesn't even get warm.
Personally I looked at hubs from cystalyte europe myself and every time I keep thinking two things
A. I don't like the way there axle is cut in the side for the wires
B. For that price I could get a complete kit including an nice infineon controller.
There are some UK options for batteries also.
tony67 wrote:2 quick points. There is disk compatible and standard 6 hole disk compatible. Be sure it is the latter, the former is some weird eastern standard that is a SOB to make work by all accounts. The specs are well documented on here.
5.5 ah is minuscule. Consider the bottom 20% and the top 5% unusable that will leave you approx 300w/h which on 72 v won't go that far. I'd advise a 15s2p setup 6 bricks for 54v 11ah bout 450w/h but at a lower voltage meaning less aero losses due to reaching higher efficiency at slower speed. Should still be capable of 45-50 kph on the 9x7.
Wizzbit wrote:Hi tony, will defo ask for the standard 6 hole disk attachment, (edit) are the 15s2p a123 lifepo4?
chilledoutuk wrote:Honestly I would go with the ping it will be more reliable and a lot easier to look after in the long run.
The way ping has his batterys setup with the bms you just get back from a ride plug in and leave it.
You would spend a lot of time messing about with charging the individual packs if you went with a lipo and the learning curve is supper steep and you don't have any room for error with this being your only battery pack.
My recommendation for someone new coming into ebikes is to buy something that they can rely on from the get go and then later on when you have a backup play around with more complicated battery solutions.
With my 36v combines 11ah i get about 25 miles range on my 9c 6x10.
Another caveat with a ping pack would be that you wouldn't have to worry about LVC as the pack would have that built into itself.
Dogman has said before that the 15ah 48v ping is about the best size as its got good range but still fits on the bike reasonably easily.
Users browsing this forum: cmugler, kifukarider, pjgold, SiriusFun and 3 guests
