Speedict Ebike - Anybody seen/tried this?
Re: Speedict Ebike - Anybody seen/tried this?
Postby speedict » Sun Apr 29, 2012 12:35 am
cwah wrote:Is there a way to make it work on a 64 bit without having to reinstall the complete system?
no, or wait for our paid for 64 bits digial signed certificate !
Speedict Technology - Drive . The . Future http://www.speedict.com | http://www.facebook.com/speedict.technology
speedict
Postby nopap1 » Sun Apr 29, 2012 1:52 pm
Hi to all,
I just started to play with my recently purchased Speedict, and i'm quite happy about the product and the support provided by Danny, thanks !
A quick question about the speedo connection, the Magic Pie 3 provides a connector for a 'speedometer display'
see below
Could this be hooked to the speedict speedo connection in some way to replace the magnet ?
I have no idea what kind of signal is getting this plug, any Magic Pie expert advice ?
Thanks !
Emmanuel
nopap1
10 µW
10 µW
Postby speedict » Sun Apr 29, 2012 1:59 pm
if the speedometer connector provide on / off type signal, you can hook it up to speedict's port 1 because speedict port 1 just simply measure on / off signal !
speedict
Postby o00scorpion00o » Sun Apr 29, 2012 5:34 pm
Hi Danny,
Can power be taken form the usb port on the speedict box to power phone via cable ?
Mark
Back to pedal only power.
o00scorpion00o
Postby speedict » Sun Apr 29, 2012 8:31 pm
o00scorpion00o wrote:Hi Danny,
Mark
hi mark,
sorry the usb port can not provide power, just for data transfer only !
cheers,
danny
speedict
Postby cwah » Tue May 01, 2012 6:34 am
I tried the governor setting with speedict. I tried different maximum speed and power but it doesn't do anything on my bike.
I limited to 25kph and 700W but I can still go over 40 kph and 2000W. How do I use this governor thing?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby speedict » Tue May 01, 2012 6:44 am
cwah wrote:I tried the governor setting with speedict. I tried different maximum speed and power but it doesn't do anything on my bike.
can you send us your port status log ?
with both firmware and android client is 2.4 you have feature called "Port Status" under option menu.
1. go to port status page, you can see all of your 4 ports' status, press the menu button and select "record", then press the start record button, throttle up and see if speedict ebike govern your speed to 40 kph, and after that stop and send the log to us !
cheers,
danny
speedict
Postby cwah » Tue May 01, 2012 7:34 am
Hello Danny,
Just sent you the report on contact@speedict.com.
Cheers
cwah
Postby cwah » Tue May 01, 2012 1:05 pm
I also just tried the throttle mode.
It works but it's not smooth at all. I have small "acceleration bump" every second.
Also, is it normal to have a small delay between the moment I move the throttle and the moment the motor moves? The motor runs immediately without the throttle mode.
cwah
Postby speedict » Tue May 01, 2012 1:11 pm
cwah wrote:I also just tried the throttle mode.
since it's involved some parameter such as soft-start value, could you please either send me your logs or post it here together with your comments therefore we can examine it and see if it's caused by setup parameters ...
speedict
Postby cwah » Tue May 01, 2012 1:37 pm
Ok, going to do that.
Do you know what's a good value for soft start and speed gain in order to have immediat start (without delay) and not having "bumpy" acceleration?
cwah
Postby speedict » Wed May 02, 2012 12:31 am
cwah wrote:Hello Danny,
Cheers
hi cwah,
i think the main reason was the mode you used, according to your log, the function mode you selected was "Multi-Sense", with this mode speedict ebike can't govern speed (without throttle output cable function) ...
on unit setting, you use Celsius for temperature and KM/H for speed
on function mode, you selected Multi-sense
on governor setting, you set with following parameters
speed = 10 km/h
voltage set to 70v
current set to 10A
temperature set to 70c
watt set to 50w
so please focus on road legal 2 mode at this moment with both cables connected, and you can try with different speed throttle, current throttle, governor settings ... whenever you like just send us you logs for examinations because it can improve our software and we can know more about customers' practice ...
cheers,
danny
speedict
Postby cwah » Wed May 02, 2012 8:48 am
Thanks.
I tried to set to road legal 2 but it's asking me the number of magnet on my PAS sensor disc. I don't have any pedal sensor for now. How could I manage that?
cwah
Postby speedict » Wed May 02, 2012 8:55 am
cwah wrote:Thanks.
if you don't has pas installed you can leave it by default value, and don't connect any sensor to port 3 because port 3 is for pas sensor for road legal 2 mode, just want you focus on road legal 2 mode first to let you take a look of how governor and throttle mode works.
speedict
Postby cwah » Wed May 02, 2012 2:11 pm
I think I melted the speedict. I was at 79,4V and when I connected the speedict to the battery and the controller there was a spark.
No more light anymore now... :(
cwah
Postby speedict » Wed May 02, 2012 9:12 pm
cwah wrote:I think I melted the speedict. I was at 79,4V and when I connected the speedict to the battery and the controller there was a spark.
ha ha, nothing we can do now, please send it back for either replace or repair.
danny
speedict
Postby cwah » Thu May 03, 2012 5:34 am
Thanks Danny,
To what address should I send back the speedict?
Also, is it because of the voltage 79.4V is too close to the max voltage that it melted? Is there anything I can do to make sure it won't happen again?
Thanks a lot
cwah
Postby speedict » Thu May 03, 2012 5:45 am
cwah wrote:Thanks Danny,
Thanks a lot
for such high voltage source better install switch before speedict ebike is recommend, spark can kill :(
most controller use voltage divider before voltage regulate ic therefore spark may not kill ...
i will PM you the return address
danny
speedict
Postby cwah » Thu May 03, 2012 5:48 am
Could you recommend any switch or whatever I can buy (in the UK) to prevent this? I'm going to purchase it immediately after :)
cwah
Postby speedict » Thu May 03, 2012 5:55 am
cwah wrote:Thanks :)
do you know RC guy make the anti-spark switch ?
speedict
Postby cwah » Thu May 03, 2012 6:00 am
No, I don't know any.
If you have any link to any shop to do that, that would be great. :)
cwah
Postby speedict » Thu May 03, 2012 6:02 am
i will email you about anti-spark information, we can discuss later on
speedict
Postby speedict » Fri May 18, 2012 6:59 am
Speedict Speed Controller prototype, sensor-less start voltage range from 9 - 80 V ....
speedict
Postby 3nslav3 » Sun May 20, 2012 4:18 pm
Hi all,
I've recently purchased a speedict, I love the product but i'm missing a mode on it
in my Country the max speed limit on public roads for pedelec bikes is 25km/h, the max power is 250 watt (i know there is a mode for that)
but when I get on private property I would like to set my bike from pedelec to e-bike with 2000watt but that is a problem...
when I originally ordered my speedict I thought it was possible to easely change those settings using my phone but I've found out that I have to switch some wires on my speedict
with just having a throttle out, throttle in, pas in, speed sensor => so going from throttle only (full power) mode to a road legal mode (pas only, 250watt 25km/h) without switching ports but only a few screentaps on an android device would be a awesome!!!!
I think a lot of people in the Netherlands, Belgium would be intrested ;)
Thanks for listening,
Kind regards Niels
3nslav3
Postby speedict » Sun May 20, 2012 10:51 pm
3nslav3 wrote:Hi all,
Kind regards Niels
hi niels,
if you want to disable governor or speed throttle mode in road legal 2 mode, you don't need to switch port, all you need to do change setting via android :
1. disable throttle mode, if your setting is speed throttle
2. disable governor or reset your speed govern to say 100km
see if it can help !
cheers,
danny
speedict
PreviousNext
Users browsing this forum: Google [Bot], GSteg, wildharemtbkr and 17 guests
