puddleglum wrote:Its got a 300w brushed motor...
The common failure is throttle... if it fails it usually fails WOT.Kin wrote:So, when brushed motors do that, I imagine it's because the controller is shorting through or something like that, and a brushed motor with applied voltage just spins.
TylerDurden wrote:The common failure is throttle... if it fails it usually fails WOT.Kin wrote:So, when brushed motors do that, I imagine it's because the controller is shorting through or something like that, and a brushed motor with applied voltage just spins.
A pullcord on the mains is a good idea.
puddleglum wrote:Thanks for the response. What I was trying to decide is if I should use the 250w or 300w motor for the scooter. I'm already using the frame from the larger one, but it looks nothing like it originally did. I think I'm going to go ahead and use the 300w motor anyway. I can change it later if I want.
Return to Stand-up E-scooters and E-skateboards
Users browsing this forum: hb_nc and 2 guests
