Evoforce wrote:Where are you guys getting the disk for the brake on these and are the holes lining up? And what mods are you having to do to get the caliper mounted?
Andje wrote:Just a video of my 5403 performance... Personally, I am very very happy.
Floont wrote:Evoforce wrote:I see on your pictures Zomgvtek, that your spokes are also improperly laced like mine. The spoke to the outside of the hub should go over the top of the spoke laced to the inside instead of spagetting behind it which applying side force to each spoke. I wonder if they were all laced this way on the larger rims?
[color=#000080]Mine is like that too. I think they were all laced incorrectly.color]
MadRhino wrote:Over crossing spokes is ugly, but not bad at all for wheel durability.
I kept the rim for I found it OK, but relaced it with rim washers.
megacycle wrote:Beautifull job, any concerns about the cable snagging, coming straight out.
Can a cover go over there in case the worst happens lean the wheel against something or even worse, god forbiddrop the bike on that side.
MadRhino wrote:If they could be found, I would gladly buy them. It is time consuming to shape them angled, oval, and bore to match the nipple head.
ZOMGVTEK wrote:megacycle wrote:Beautifull job, any concerns about the cable snagging, coming straight out.
I will mount pegs to the swingarm to protect the wire. The bike isnt done yet, the wire will be much closer to the bike and secured better.
moonshine wrote:Has anyone relaced the x5404 into any other rims? I have some sun double wide rims (26"/36h). The local bike shop is not quite sure about the nipple size...which means i'll most likely have to find another rim. Duc was trying to get an alexd24 rim, i was thinking an alex dx32 rim (im going for 39mm). Has anyone had a problems with the current rim it's laced in???
MadRhino wrote:moonshine wrote:Has anyone relaced the x5404 into any other rims? I have some sun double wide rims (26"/36h). The local bike shop is not quite sure about the nipple size...which means i'll most likely have to find another rim. Duc was trying to get an alexd24 rim, i was thinking an alex dx32 rim (im going for 39mm). Has anyone had a problems with the current rim it's laced in???
The rim that I got my 5404 laced in, is a copy of an older DH rim, a DT Swiss of the late "90s if my memory is good.
It is stronger than most of today's DH rims, except for the very best that are made of 7000 series Alloys.
Nipples are ordinary 12 ga.
Have the rim re-laced adding nipple washers, and it will last hard riding.
Users browsing this forum: Google [Bot] and 13 guests
