5404/5403 The good The bad The ugly
Re: 5404/5403 The good The bad The ugly
Postby Evoforce » Tue May 01, 2012 10:50 pm
Where are you guys getting the disk for the brake on these and are the holes lining up? And what mods are you having to do to get the caliper mounted?
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Postby MadRhino » Tue May 01, 2012 11:07 pm
Evoforce wrote:Where are you guys getting the disk for the brake on these and are the holes lining up? And what mods are you having to do to get the caliper mounted?
Standard bicycle disc brake 6 bolt pattern fits the motor
Various calipers are fitted on the frame with a specific adapter, providing the frame has disc brake mounts. If it doesn't have any, you can integrate IS mounts to the custom steel dropouts or torque plates that you will have to do anyway.
Norco A-Line, 50+ Mph dirt bike and winter commuter... sold
Specialized Demo 8 performance dirt bike
http://img715.imageshack.us/img715/5824/dsc03417ae.jpg
Santa Cruz Heckler, lightweight road racer
Santacruz V-10, performance dirt bike
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby Tincan » Wed May 02, 2012 12:31 am
How many others are having issues with the pi55 poor hole spacing for the rotor..
Mongoose Caayne
-Lyen 18x4115 Controller, CA, -132v bla bla bla, Waiting on Uber ultra fantastic group buy Crystalyte
Mongoose Full suspension, HT3525 rear hub motorReturned back to pedal power
-Lyen 18x4115 Controller, CA, -132v LiPo
**Shithouse motor blew up, thanks for nothing Crystalyte :(
Chinese Vespa Scooter with 16inch 200w 8x8 hub motorRetired
-132v LiPo, Lyen 18x4115 Controller, Cycle Analyst, Rear disc brake
**Top speed - 86.1 km/h
Tincan
Postby megacycle » Wed May 02, 2012 5:22 am
Andje wrote:Just a video of my 5403 performance... Personally, I am very very happy.
Sympathies to your sphincter there.
That was excellent, those birds not having time to know the beast was coming :shock:
Brilliant looking forward to my build even more now, thanks for that :D .
Iron Horse SGS Pro DH.
72V 16AH lipo. 3kW charging system.
Modded Crystalyte 72V/50A, regen, 3 stage overcurrent.
4060 ☆/\, 20mm cover holes.
Hyena supplied motor (much appreciated Onya mate)
5404 next build giant strata, A123 20Ah, 72/large.
megacycle
Postby megacycle » Wed May 02, 2012 5:29 am
[quote="ZOMGVTEK"]Heres how my 5404 is mounted.quote]
Beautifull job, any concerns about the cable snagging, coming straight out :?:.
Can a cover go over there in case the worst happens lean the wheel against something or even worse, god forbid :cry: drop the bike on that side.
megacycle
Postby megacycle » Wed May 02, 2012 5:35 am
Floont wrote:
Evoforce wrote:I see on your pictures Zomgvtek, that your spokes are also improperly laced like mine. The spoke to the outside of the hub should go over the top of the spoke laced to the inside instead of spagetting behind it which applying side force to each spoke. I wonder if they were all laced this way on the larger rims?
[color=#000080]Mine is like that too. I think they were all laced incorrectly.color]
Seconded Same :roll: .
megacycle
Postby megacycle » Wed May 02, 2012 5:43 am
MadRhino wrote:Over crossing spokes is ugly, but not bad at all for wheel durability.
I kept the rim for I found it OK, but relaced it with rim washers.
Are your rim washers flats or an angular profile :?:
My spokes are bending at the nipples from the crazy angle they take, due to the hub diameter.
megacycle
Postby MadRhino » Wed May 02, 2012 6:45 am
Yep, the washers are angled to align the nipples with the spokes.
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby megacycle » Wed May 02, 2012 7:44 am
Did you buy, make or mod them :?:
megacycle
Postby MadRhino » Wed May 02, 2012 8:01 am
If they could be found, I would gladly buy them. It is time consuming to shape them angled, oval, and bore to match the nipple head.
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby ZOMGVTEK » Wed May 02, 2012 8:03 am
megacycle wrote:Beautifull job, any concerns about the cable snagging, coming straight out :?:.
I will mount pegs to the swingarm to protect the wire. The bike isnt done yet, the wire will be much closer to the bike and secured better.
ZOMGVTEK
Postby megacycle » Wed May 02, 2012 3:57 pm
MadRhino wrote:If they could be found, I would gladly buy them. It is time consuming to shape them angled, oval, and bore to match the nipple head.
Group instigated engineered solution coming soon :D hope. Made in china $100 per million.
megacycle
Postby megacycle » Wed May 02, 2012 4:03 pm
Nice, sounds like a motor bike the 5404's have come to be, i was thinking, for my cables, a copex solution.
megacycle
Postby Tincan » Thu May 03, 2012 7:20 am
Well just took mine for it's first go.
Low batteries, flat tyres, next to no brakes and im still grinning from ear to ear :D
Over the weekend ill fix up the brakes etc but now i'm content and happy :)`
Mongoose Caayne
Tincan
Postby moonshine » Thu May 03, 2012 12:59 pm
Has anyone relaced the x5404 into any other rims? I have some sun double wide rims (26"/36h). The local bike shop is not quite sure about the nipple size...which means i'll most likely have to find another rim. Duc was trying to get an alexd24 rim, i was thinking an alex dx32 rim (im going for 39mm). Has anyone had a problems with the current rim it's laced in???
03 Giant DH comp w/ 05 swingarm, cromotor in 26" large marge, Kelly KBL96251, 24s4p
Build Thread: viewtopic.php?f=6&t=40031
moonshine
Postby ZOMGVTEK » Thu May 03, 2012 1:04 pm
moonshine wrote:Has anyone relaced the x5404 into any other rims? I have some sun double wide rims (26"/36h). The local bike shop is not quite sure about the nipple size...which means i'll most likely have to find another rim. Duc was trying to get an alexd24 rim, i was thinking an alex dx32 rim (im going for 39mm). Has anyone had a problems with the current rim it's laced in???
I don't have more than about 10 miles on my motor yet, but I'm happy with the rim it came with. I never heard anything coming from the wheel under acceleration, it was only when I was doing repeated 12kW WOT runs into 3kW regen did I hear a few 'pings' from the rear wheel. Nothing terribly concerning. My Golden used to make all kinds of sounds.
ZOMGVTEK
Postby Evoforce » Fri May 04, 2012 4:20 am
Watch for shavings inside the rims and sharp edges around the holes inside the rim.
Evoforce
Postby ZOMGVTEK » Fri May 04, 2012 8:11 am
Does anyone else have a resonation in the motor at low speeds? It was similar to this with my Golden, but at a higher speed. I'm fairly sure it wasn't there when new, or at least started getting louder. The motor has about 20 miles on it now.
Looks like 18 mph efficiency is down from my 1000W Golden as well. I consumed about 26-27Wh/Mi at 18 MPH, whereas it used to be in the 24 range. However, the bike is new, and the tires are a bit more aggressive. Might just need to break in a bit.
I don't know if its my motor, or controller, but it looks like high speed efficiency is very poor. I'm going to triple check my CA shunt calibration, but it looks like the motor pulls 3kW or so topped out at 41.x MPH and WOT. It takes HOURS to cool down this big motor when it warms up, which is quicker than I would like. It looks like some sort of cooling is a very good idea.
Regardless, my GM was in sad shape, and this motor wasn't that much more than a decent replacement, so its acceptable. This guy throws out some serious power, whereas my GM gave up past 70A or so.
I'm using 12 as the pole count in the CA for speed, and it looks to be accurate. Is this low pole count why my controller won't regen as slow as my GM did? Below about 10-15 MPH nothing at all happens. Above 20 or so it works great, and at 40 it almost locks up the tire with 25A of regen.
ZOMGVTEK
Postby whatever » Fri May 04, 2012 8:27 am
some of the x5s has a problem where the motor could move sideways a few mm along the axle, required internal washer to solve it,
I have one it vibrates a bit at different rpm, I never bothered to stop the sideways movement.
whatever
Postby MadRhino » Fri May 04, 2012 3:21 pm
The rim that I got my 5404 laced in, is a copy of an older DH rim, a DT Swiss of the late "90s if my memory is good.
It is stronger than most of today's DH rims, except for the very best that are made of 7000 series Alloys.
Nipples are ordinary 12 ga.
Have the rim re-laced adding nipple washers, and it will last hard riding.
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby megacycle » Fri May 04, 2012 5:05 pm
Has the 5404 been dyno'd yet, no spec's :?:
megacycle
Postby moonshine » Fri May 04, 2012 11:19 pm
Rhino,
I've been searchin through the forums about dishing for wider rims and specifically for the dh comp's 135 dropouts. I'm pretty hooked on the surlys. I want to get the large marge....but i'm confused about how its gonna fit into the 135 dropouts...How much dishing is really needed? How much is too much? I saw that you told wayne 1/4" to the left is good. What i plan on doing...is using the spokes that are currently lacing the 5404 into the stock crystalyte rim (i'm hoping to avoid any custom spoke cutting and what not).
I wanted to mount the 5404 without dishing into the regular large marge XC version (26"/36h) :
http://www.niagaracycle.com/product_inf ... _id=415380
As for dishing...well...i could also mount it into the DH version of the large marge (26" with a 17.5mm offset):
http://www.niagaracycle.com/product_inf ... _id=504313
1. Any problems with over a half inch offset?
2. Am i better off going with the XC version and just tightening up the left side spokes to create an offset?
3. Can i even USE the spokes that came with it? I don't see why not....please let me know...
4. WHERE ARE THE THREADS WHERE PEOPLE ARE RELACING 5404s into more BADASS RIMS!!!!
Let me know cause i'm itching to buy the large marge. Looks sooo sick. most likely gonna fit it with the nate tires...well..that is if its not >3" then i'll have to go with the frickin larry's...
Oh and...cycle us superfat??? WAY CHEAPER!!! Anyone know the difference? Is it just like sony/samsung vs everything else? Surlys~130-180 Superfats~80-90
http://www.choppersus.com/store/product ... 2.5-Black/
moonshine
Postby MadRhino » Sat May 05, 2012 6:29 am
Yep, you can dish half an inch NP, even more if needed. 2 spoke length are needed when dishing a lot.
Re-using the spokes with a different rim might not fit. This one is deeper than most, many other rims will need longer spokes.
Lacing a wheel is lacing any wheel, no need for a specific thread to lace this motor. Heavier motors though, require a good lacing job to give a chance to the wheel to last. The X54 is heavy enough to destroy a poor lacing job in a very short time.
If you want a wide rim, I suggest that you go with a trial motorcycle rim. The Large Marge is very light for its size, its design is made to be saved by a soft fat tire that will keep it from taking any beating. To give you an idea, those fat Surly 4 in wheels are lighter than most DH racing wheels with a mud tire.
Those balloon tires are not a good ride in all conditions, they are specific for soft terrain, snow, sand, mud. They don't have a stiff enough casing for hard cornering at speed.
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby moonshine » Sat May 05, 2012 6:37 pm
Alright...if they're too soft, then i had my eye on the excel rims. However, my biggest concern is trying to figure out how big i can go. I don't want ridiculously knobby tires. I'll be riding it mostly on the streets (75% of the time) and the other on bike trails in DC (not super intense). I wanted to do a 21"x1.85" excel rim...but GCinDC was telling me that he was running a 19"x?? with 2.75" tires and said he was at the max...I guess i'm a little confused because i have a 26"x1.80" DH rim with 2.7" tires and i have a little room left (actually, for a FS, we'll say that im at my max). Is the 2.75" tire that he's running that TALL? Either way, i wanna pull the trigger on a rim here. I wanted to get a 21"x1.85" (dimpled or non-dimpled???) and put a relatively normal sized tire on it. Probably gonna get buchananspokes to custom lace it with a 1/4" dish. Thoughts?
-Pat
moonshine
Postby MadRhino » Sun May 06, 2012 6:04 am
Knowing what fits your bike is yours to measure
A 19" motorcycle rim will give a 24" to 25" OD wheel
Suggestion
Rim: Morad TC 19 X 1.60
Tire: Shinko 244
Work in progress:
Trek Session 10
Fatboy
MadRhino
PreviousNext
Users browsing this forum: d8veh, dolby, oldtown169, pecan777 and 7 guests
