Two kit choices. Which one? 36V $1000 or 48V 1700?
Re: Two kit choices. Which one? 36V $1000 or 48V 1700?
Postby dnmun » Wed May 02, 2012 12:48 pm
ping will build you pack to specific dimensions and in split sections if that helps. paypal charges him 8% for the transaction so you can ask him if he will give you some discount if you gift the money through paypal or do a wire transfer from your bank.
but you should also buy the large charger from him too besides the small one so you have backup chargers.
motors come and go but the battery is what you wanna keep for the long term so that's an investment. burning up the motor is an education. 48V15Ah is a good size. maybe 60% buy that one, but i am guessing from what i see here.
dnmun
Postby dogman » Wed May 02, 2012 1:15 pm
Get the ping. It should fit in your frame triangle in 48v 15 ah. But do check with a cardboard cutout of the battery dimensions before ordering.
You turn it on it's side, so it's only about 4" wide. This pic shows a box for a 48v 15 ah ping in the front triangle of my frankenbike. Couple of boards to support the metal toolbox.
Frankenbike longtail. Bouncing Betty..jpg (115.34 KiB) Viewed 141 times
dogman
Postby chisixer6 » Wed May 02, 2012 6:09 pm
63corvairsprint;
If you looking at headway batteries, here is another vendor's web
http://www.ebikedeal.com/lifepo4.htm
motomech;
quote"On the Ebike CA simulator, it looks like a top speed of 19 mph on 50V[20" wheel]. The stock controller is good for 63V, so you might throw some more bricks on the fire if you want see the other side of 20 mph.
I use a Lyen controller good up to 75v,
also for someone asking about CA, I had an CA plug added, but no CA yet
Ykick;
cool on all those Corvairs
Jerry
Motobecane ..bafang front driver.. 42v
24" girls bike ..ebikekit 20" fwd..75v
24" Schweinn 9c 20"rwd 75v
26" Schweinn Yescomusa 48v 800watt dd
Easy Racer clone LWB.....24" rear e-bikekit 48v ..ready for testing
Hooligan clone , longer rear chain stay.. twin 20"...
fun bike...twin 16" wheels. small rear motor... ready for testing
convert my CLWB recumbent to a front bafung@48v..ongoing
chisixer6
Postby motomech » Wed May 02, 2012 6:59 pm
63corvairsprint wrote:I am too new for the motor discussion as well and I was frustrated about "what" motor was being offered in various kits. I have sent out several direct emails asking for specific questions and have had most of the replies only answer certain questions and "skirt" around others.
I want a motor would for higher RPM as opposed to torque , but cannot determine which motor is being offered in the "kits".
I did get an email back from Jason and he said their controller don’t have a direct plug in for the CA, but no other details. The BMC I listed is the torque motor, they offer the speed motor, but not as an online option for that kit.
Do you still have all the extra control features with the CA when you just wire in as opposed to a direct plug into the controller, or are you only just plugging in line?
@Gary, I have been in the Corvair hobby for quite a few years, currently drive a 66 turbo Corsa coupe as my daily summer driver. I also own a restored 63 Corvair Sprint convertible ala John Fitch. Fun little cars. My 63 has the 4 carb engine as opposed to the stock 2 carb configuration like the one you recall.
That's a very nice kit. I have more or less the same kit that I got from another vendor a couple of years ago, but it was not as nicely finished as that one. Those connectors are deluxe! I'm in the process of re-doing many of my connectors and wiring and it's a PITA.
That motor is what I would call a "mid-wind", 250 no-load rpm @ 36V. The performance figures that Ebike supplies are very accurate. I see 23 to 24 mph on 48V w/ lite pedaling. Although I think mini-motors are better than most give them credit, it isn't a power house. Head winds and hills will give you plenty opportunity to pedal, but that is what you wanted, right.
BTW, I just checked my Cycle Analyst and was suprised to see my total mileage is approaching 1000 miles. No problems with either the motor or controller to report.
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby 63corvairsprint » Thu May 03, 2012 12:22 pm
Next phase of my bike build in process..
Stand alone CA pre-wired with connectors
11-32 8 speed freewheel
1 hub spacer
Order submitted to Ebikeca …pending 1 question
And first big road bump to my timeline….
It would appear that Headway-Headquaters and Ebikedeal (both of whom are offering Headway cells) appear to be out and are both waiting for shipments to arrive sometime later this month. So my plan on using one of these particular domestic LifePO4 battery packs seems to be in jeopardy.
So now I am back to looking at Ping and Cellman, of whom both are out of the country…
Grrrr….
63corvairsprint
Postby dnmun » Thu May 03, 2012 1:28 pm
studebiker is selling his 9C, a rear direct drive with disk brake, headway cells.
viewtopic.php?f=9&t=39349
dnmun
Postby 63corvairsprint » Fri May 04, 2012 11:56 am
Just got a message from Jim at Headway-Headquarters that his batteries are now back in stock...
Now I just gotta figure out which configuration...
63corvairsprint
Postby MikeFairbanks » Fri May 04, 2012 1:07 pm
I found this.
I have no idea if it's legit, who it is, etc., but they claim the entire manufacturing process is in the USA.
http://www.batteryspace.com/51.2V-LiFeP ... Packs.aspx
MikeFairbanks
Previous
Users browsing this forum: cal3thousand, dl1955, docnjoj, evaleto, zombiess and 19 guests
