psycholist wrote: Gotta be the poor quality epoxy.
neptronix wrote:Because the docbass torque arms i bought are so loose, they are basically $35 worth of scrap metal to me. I don't see how they'd work as clampers, especially when you're gluing something on, then stressing out the bond that glue ( ok, epoxy ) has made.
John in CR wrote:psycholist wrote: Gotta be the poor quality epoxy.
OR ___________ . I'll leave it up to people to fill in the obvious answer on their own.
neptronix wrote:I don't believe in this glue stuff.. just does not calculate. bolt or weld it on..
izeman wrote:i think epoxy is a really great thing. if used properly and if you got the right stuff.
there must be a reason why today many parts in cars are glued and not bolted or welded. glueing is superior to welding/bolting to some degrees and to some it's vice versa. it*s as simple as this.
drilling a hole with a not 100% good drill can make the plate very hot. and heat is the only way to remove epoxy. and once it got hot it's like dried jewing gum. can you pry the remaining epoxy off with a screw driver easily? if it falls of in small crumbles than you know it got too hot.
However, they are EXTREMELY sensitive to the materials being bonded, and prep involved. You can't glob some smoo on sanded paint and think its going to hold back 20HP. I was a bit worried when I initially noticed rather inexperienced people trying out DP420 for really critical stuff, looks like there was good reason.
Because%20the%20docbass%20torque%20arms%20i%20bought%20are%20so%20loose,%20they%20are%20basically%20$35%20worth%20of%20scrap%20metal%20to%20me.
The drill bit was probably dead by the time you got to the bike piece. The expensive drill bits require low rpm and frequent cooling, even dipping in water a number of times for each hole extends the life tremendously. Get it hot with too much rpm and you can kill it in seconds. Typically a squeaking sound while drilling tells you the bad news.
Return to E-Vehicles General Discussion
