EVPowers wrote:You can see in the third graphic down, that there can be some high-current draws. (290a, 250a, 225a, etc)
I'm not sure three 7s3p packs will be able to handle the load.
The voltage would probably need to be upped a small bit by creating another small pack of cells as well.
oatnet wrote:that makes me wonder whether they were intended to decay, or if it was a bad batch of PCBs.
oatnet wrote:On another note - am I the only one whose BMS's smell really bad? I think the circuit board itself decomposing, do I need to worry about the chemicals in it? Looking at the picture above that compares a good vs decomposing, you can see how the PCB seems to be balloning up and around the traces...
on the right one of the 2009 BMS's that STINK, are gooey, you can see the color and sorta matte finish on these.
davec wrote:you guys did a really good job
thanks for the great pics and for reviewing these modules for us
i do have a request for anyone who has the time so we can get a good idea about what we're getting here
1. IR test on one of the cells in the module
2. 1C test on a cell in the module to see how many AH they deliver
would be awesome
davec wrote:i do have a request for anyone who has the time so we can get a good idea about what we're getting here
davec wrote:a cba test on the whole pack itself at 1c
JRP3 wrote:As has been repeatedly stated the cells are welded in parallel groups of three, you cannot isolate an individual cell from the other two without physically cutting it out. Not going to happen, and not necessary.
drgrieve wrote:Charging LiFeP04 basics.
There is a formula called CC/CV to charging these batteries. You can't pick and choose what parts of the formula is easiest - it doesn't work that way.
To charge to 100% you should charge at 3.65v at a constant current until cell or module voltage is 3.65 then decrease current holding voltage at 3.65 terminating charge when current is 0.05C (3 amps on 60h). After settling (24 - 36 hour period) the resting voltage will be 3.4V. This is 100% charged.
My main issues with some of the recent comments is as follows.
1. If you are charging at 2 amps you are below 0.05C already and you should charge to a lower voltage otherwise you are over charging.
2. Charging LiFeP04 batteries is NOT excessively lossy, you should get back 99% of the energy you put in. Counting AH is an effective way of measuring SOC if you know your starting reference.
3. A cell resting at over 3.4V is OVER charged and likely suffered a small capacity drop.
Note [except for capacity testing] I recommend charging so that the resting voltage is 3.33 or 3.34 for extended cycle life. Replace 3.65 with 3.5. Also even when testing capacity 2V is too low (not much room for error!), aim for 2.5v when capacity testing as ah between 2.5V and 2.0v is minimal.
Not unless you have a charger that is 100% efficient, which you don't. 90-95% efficiency is probably normal including the charger. Losses will probably be higher if you are using resistors to do top balancing.
drgrieve wrote: 1. If you are charging at 2 amps you are below 0.05C already and you should charge to a lower voltage otherwise you are over charging.
drgrieve wrote:2. Charging LiFeP04 batteries is NOT excessively lossy, you should get back 99% of the energy you put in. Counting AH is an effective way of measuring SOC if you know your starting reference.
drgrieve wrote:3. A cell resting at over 3.4V is OVER charged and likely suffered a small capacity drop. Note [except for capacity testing] I recommend charging so that the resting voltage is 3.33 or 3.34 for extended cycle life.
Users browsing this forum: No registered users and 6 guests
