24mm, I think. I'll check that.turbo1889 wrote:Is the spindle diameter for the Shimano Octalink bottom bracket cartridges which as you mention do use internal needle bearings also 25mm?
turbo1889 wrote:I really wish I could find a good source of 25x30x14 drawn cup needle bearings since Staton-Inc already sells a cup set designed to to use doubled up (four bearings two in each cup) 17x30x7 sealed ball bearings and they could be easily modified to use a single 25x30x14 drawn cup needle bearing one in each cup instead.
Yes, 22mm. Sorry, I misremembered.turbo1889 wrote:I did some online research and some people say the Shimano Octalink spindle diameter is 22mm and others say it is 22.2mm (either way that sounds like 22mm put sounds like it is not exactly 22mm). ISIS is consistently listed at 22mm for the spindle diameter. That is from gleaning info from the startpage search engine across multiple web-sites with trial and error search queries..
31mm OD seems to be a common bearing size for bottom brackets. If one could find some reasonably deep 31mm ID caps .....Miles wrote:You could sleeve the BB shell and press in a pair of 24x31x20 drawn cups?
Miles wrote:. . . You can try it out on one of your old bikes.....
turbo1889 wrote:Continuing evolution of the design based on further improvements that Miles has put forth in his thread on the same subject:
As drawn:
----- 1.37"-24tpi x 73mm bottom bracket reamed on each side to accept press in bearings of 35mm outside diameter.
----- Primary bearings are 28mm x 35mm x 20mm (ID x OD x W) directly pressed into bottom bracket from each side.
----- Outer spindle shaft is 28mm outside diameter and screws together in the center via. M24-2.0 LH thread 30mm long.
----- Secondary bearings are 17mm x 21mm x 13mm (ID x OD x W) pressed into the two ends of the outer spindle shaft.
----- Inner spindle shaft is 17mm outside diameter solid with tapered square end.
----- Axial containment and sealing of the primary bearings is provided by simple brass washers taking up the slack between each side of the bottom bracket shell and the outer spindle.
----- Both sides of the outer spindle use standard 1.37"x24tpi RH threaded freewheel threads to accept White Industries Heavy Duty crank freewheel unit.
Users browsing this forum: No registered users and 8 guests
