Attn Experts: When Will Battery Capacity Double ?
Re: Attn Experts: When Will Battery Capacity Double ?
Postby flathill » Mon May 14, 2012 5:12 pm
"DeVries":
Dude once again you missing the point :(
Did you see the Temperature column?
even the best EIG NMC (what Zero uses) cells are "only" rated for 1000 cycles at 25 Centigrade with a FOUR year calendar life. Try running NMC cells in Iraq without active cooling and you'll see why the military is funding Wildcat
Wildcat is baselining NMC at 50 Centigrade because NMC cells do not last long at high temp.
The fact they have a 5V (4.9V) cell that does 1000 cyles at 30 Centigrade is huge (1C discharge)
The point of all this is now we are in a 5V land now that there are a couple 5V stable electrolytes out there in the wild :)
"this is just the beginning – because the EM1 electrolyte is stable at 5-volt operation, it opens the door to development of a new world of cathode materials that should bring even greater advances.”
flathill
Postby deVries » Mon May 14, 2012 5:43 pm
flathill wrote:"DeVries":
I'm not suggesting these aren't positive developments. These are plus factors for "hot" operating environments. So, yeah, the military or desert people might see that as a real advantage.
1,000 cycles is *not* good enough for normal operating environments. Current tech has already standardized on way more cycles.
This company makes chemical additives to extend battery life, not a retail 5v battery, so I want to know how many cycles it will extend in current A123 batteries that do thousands of cycles now. I want to know what it will extend in the next-gen 5v battery with a baseline starting at 1,000, 2,000, and 3,000 cycles.
I don't give a damn about military use or the hot desert and low cycle life of 440 to 1,000 cycles even it it's a 5v battery in overheated environments. That is not what a non-military typical buyer wants for his EV vehicle.
That data you referenced seems promising, maybe, but I'm highly skeptical of what it shows me now! Whoopy for the military. :wink:
deVries
Postby flathill » Mon May 14, 2012 5:47 pm
Once you get to 1000 cycles (at 100% DOD) the calendar life becomes the limiting factor (since at normal use DOD the cycle life will be more than the calendar life in most EV applications)
"The Arrhenius equation defines the relationship between temperature and the rate at which a chemical action proceeds. It shows that the rate increases exponentially as temperature rises. As a rule of thumb, for every 10 °C increase in temperature the reaction rate doubles. Thus, an hour at 35 °C is equivalent in battery life to two hours at 25 °C. Heat is the enemy of the battery and as Arrhenius shows, even small increases in temperature will have a major influence on battery performance affecting both the desired and undesired chemical reactions."
Now look at the electrochemical stability plot in the wildcat pdf and you'll see why this development is crucial for all cells
But yes the LiFe A123 is an excellent cell with both long cycle and calendar life, the wildcat CM1 is LiFe with a 70%! increase in volumetric density, and HV operation=less cells=less connections=less total pack weight
flathill
Postby deVries » Mon May 14, 2012 6:09 pm
flathill wrote:Once you get to 1000 cycles the calendar life becomes the limiting factor
This makes sense, but until Wildcat can show me the data for 1,000, 2,000, and 3,000 cycle life "extensions", whether it's calendar based and/or cycles based, I'm skeptical. :twisted: Don't really care about the heat equations without the Real World data that I want well beyond 1,000 cycles of CM1 at normal operating temperatures. Show me the Real World data...
For example, does CM1 extend A123 battery cycle life another 1,000, 2,000, 5,000 cycles or not? Tell me. Well, you can't, because they've got nothing Real World showing any battery life extension for current battery maker's batteries that are selling on the open market now. :idea:
They're going for the military gold, because there's no competition there with big money contract awards sticking it to the taxpayer. :evil: Let's see the cheap consumer side of these products? :?:
Again, seems promising, but we/I need data of the kind I'm asking for too. That data sheet does not have what I'm asking for, and what I'm asking for is reasonable. IMO.
deVries
Postby flathill » Mon May 14, 2012 6:12 pm
Dude your still not getting it
It is a 5V stable electrolyte good for 1000cycles
the fact it improves lower voltage cell stability is just gravy on top
flathill
Postby deVries » Mon May 14, 2012 6:25 pm
flathill wrote:It is a 5V stable electrolyte good for 1000cycles
Well, it is an additive; not a finished product. 1,000 cycles is not good enough, IMO. Price is unknown.
flathill wrote:the fact it improves lower voltage cell stability is just gravy on top
Really, where is the Real World data for that in cycles beyond 1,000 vs other commercial products already being sold? :?: In other words, see my previous post just above your post above I quoted here.
I'm just waiting for different and new data before I could become a believer in their products. :wink:
deVries
Postby flathill » Mon May 14, 2012 7:55 pm
You are never going to know which batteries use Wildcat's electrolyte.
I guess you won't be buying a Zero as it's 1000cycle (100%DOD to 80%) battery is only rated for 300,000 miles in the real world, or a Telsa Roadster (700 cycle battery, many 100,000+ miles cars on the road)
I'm sure you plan on going more than that on your ebike :roll:
flathill
Postby deVries » Mon May 14, 2012 8:40 pm
flathill wrote:You are never going to know which batteries use Wildcat's electrolyte.
Well then, it will be very hard to know just how good their products really are IF they can't show me some kind of Real World comparison between Battery A and Battery W-ildcat additive inside. I don't need to see the Brand Names. I do need to see the data that shows their product beats the competition with specific performance data for 1,000, 2,000, 3,000 cycles. Why not? A123 has that kind of data available. Wildcat can too! :twisted:
flathill wrote:I guess you won't be buying a Zero as it's 1000cycle (100%DOD to 80%) battery is only rated for 300,000 miles in the real world, or a Telsa Roadster (700 cycle battery, many 100,000+ miles cars on the road)
I've never brought-up the subject that this has anything to do with an eBike. It has plenty to do with 250-lb+ Motorcycles & Scooters & larger vehicles, of course.
As a minimum requirement, I want a 75mph 350-lb Motorcycle that can run 120 minutes continuous hwy at that speed for the same price of the 9kWh ZERO battery, which can now run for barely 60 minutes hwy in optimal conditions @ 75mph. I want Real World at double what that ZERO can do today. :twisted: :D
This thread is When Will Battery Capacity Double? I pick the ZERO as my target example of what I want. No need to roll your eyes about that, imo. :P
BOTH EDITS: I would, especially, also want to know how much voltage sag there is under load between 800-1,500 cycles vs new. I agree going beyond 2,000 cycles is not nearly as big a deal as capacity & performance under load is from 800-1,500 cycles. Calendar life would be more important after 1,500 cycles. IMO.
It seems Wildcat may have some additives that may get us closer to the answer of "when". Show me that data, so I can believe in a "Wildcat" too. :idea: :mrgreen:
deVries
Postby flathill » Mon May 14, 2012 8:49 pm
Dude you're clueless.
flathill
Postby spinningmagnets » Mon May 14, 2012 9:17 pm
IMHO...the technology is in the lab right now...there are other issues. If some company R&D department finds a cheap and available way to double capacity, it will be patented. It will be an upscale upgrade for the first few years. There will be a struggle with foreign (Chinese?) reverse engineering, which will bring competing products to the market.
There will soon be competing technologies. Nobody wants to make a long-term commitment to a new patented type, just to find out a few months later that they bought into Betamax, instead of VHS, or HD-DVD instead of Blueray...although...sooner or later you have to make a choice. Also, nobody wants to make a long-term commitment to a new patented battery technology just to find out they invested in Tidalforce (great product, went bankrupt).
As much as I don't like Chinese industrial espionage and patent-piracy...they move new tech quickly into the market and allow the big players to see what a large group of actual buyers are willing to pay real dollars for.
I just bought a variety of unique Chinese flashlights to test, nothing like them in the US market, and they were cheap. A tiny 1000-lumen light using a 14500 3.6V cell with a T6 emitter. Once I find what I like, I'm more than happy to support US products, but...how long should I wait?
spinningmagnets
10 GW
10 GW
Postby deVries » Mon May 14, 2012 9:36 pm
flathill wrote:Dude you're clueless.
Usually, companies that develop products for the military are 10x-100x more expensive than consumer products. It's the gold-road for R&D at extreme profits. Clueless? Let's see them make it in the consumer market to just give you *one* clue of mine I already hinted at too. :wink:
Here's Luke's post on that same thread you posted in on May 11, 2011:
liveforphysics wrote:There are 5v and 6v lithium chemistries.
The problem is cycle life. If you're a primary cell, or just used for a mission, cycle life doesn't matter.
So, Luke sees the problem as cycle life too. Hmm. Now there's a clue too. :D Mainly, though, see the bold text below. Wildcat is only publishing 25%-65% better battery performance in cars that use a 5v battery. Is that double capacity than what is available now? :?: Just to offer a clue: Shouldn't that read instead a 100% performance boost in order to double capacity from what we have now? :?:
Your very first post on ES was on May 11, 2011 & has to do with Wildcat:
flathill wrote:The tech is real and not just for primary batts. The tech was "invented" the same way humans usually "invent", by trying everything and discovering universal principles, but now we can try faster :mrgreen: 675 Wh/kg!!!
March 14, 2011 09:00 AM Eastern Daylight Time
Wildcat Discovery Technologies Discloses Fundamental Advances in Rechargeable Battery Materials Technology
Newly developed 5-volt electrolyte, cathode material boost battery performance 25-65 percent in cars, electronics, other applications
SAN DIEGO--(BUSINESS WIRE)--Fundamental advances in rechargeable battery technology disclosed today by Wildcat Discovery Technologies could result in battery performance improvements of 25 to 65 percent or more in electric cars, portable electronics, military, medical devices, and other demanding applications.
“This is a breakthrough discovery by our development team, which can lead to batteries capable of storing much more energy than current materials allow”
Wildcat has developed a pair of new materials that set new standards for the rechargeable battery industry, by providing unprecedented energy density of more than 675 Wh/kg while operating in full cells at 5 volts – levels beyond today’s industry standards.
Wildcat’s EM1, a novel 5V electrolyte formulation, and CM1, a new high voltage cathode material, have been shown to deliver a 25 percent improvement in gravimetric energy density, and a 61 percent improvement in volumetric energy density in the electrode, compared with existing state-of-the-art battery materials with comparable attributes. Thus far, batteries made with EM1 and CM1 have expected power and safety performance comparable to lithium iron phosphate (LiFePO4), while also handling more than 100 charge/discharge cycles in full-cell testing.
“This is a breakthrough discovery by our development team, which can lead to batteries capable of storing much more energy than current materials allow,” said Wildcat CEO Mark Gresser. “When batteries hold more energy, it creates new options for design engineers - electric cars can go farther, tablets, laptops and smartphones can be smaller with no loss of runtime, soldier packs can be lighter, and implanted medical devices can last longer before the need for replacement surgery. And while our initial tests have shown a 61 percent improvement in energy density, this is just the beginning – because the EM1 electrolyte is stable at 5-volt operation, it opens the door to development of a new world of cathode materials that should bring even greater advances.”
Gresser added that the new materials are fully compatible with industry-standard anode materials.
The EM1 electrolyte’s high-voltage capability is of special interest for the automotive sector, where cell development has been restricted by the inability of existing electrolyte formulas to cycle at high voltages. Current EV systems based on low voltage cells require complex and expensive pack designs and battery management systems. EM1 enables high voltage systems which are expected to reduce required cell quantities 30-40% vs. competing materials like LFP and NMC. Fewer cells and simpler pack designs translate into substantially lower costs for auto makers.
The materials were developed using Wildcat’s proprietary high-throughput synthesis and screening platforms, which enable rapid discovery and development of advanced materials. For the CM1 cathode material alone, Wildcat’s R&D team synthesized and evaluated more than 3000 materials in just eight months; this research may have taken years using conventional methods.
Wildcat is actively seeking licensees and partners for further development and commercialization of EM1 and CM1 and successor materials. Sample quantities of up to 1 kilogram will be available as of April, 2011.
About Wildcat Discovery Technologies
Wildcat Discovery Technologies is engaged in the discovery and development of specialty materials for clean tech energy applications; including materials for batteries, gas separation, catalysis and advanced structural materials. Wildcat has developed proprietary high throughput synthesis and testing workflows for the rapid exploration of new inorganic materials. This technology enables Wildcat scientists to synthesize and evaluate thousands of materials in the time it takes most labs to evaluate only a handful.
http://www.wildcatdiscovery.com/news.html
We'll never know if EEStor is real...but keep an eye out for EM guns that don't use homopolar generators :twisted:
deVries
Postby flathill » Mon May 14, 2012 9:54 pm
Nice selective quoting
Here is the thread
Marines use 5v lipo
viewtopic.php?f=14&t=27877
We now have 1000cycle 5v secondary lithium cells
Get a clue moron
flathill
Postby 999zip999 » Mon May 14, 2012 10:06 pm
The price came down from 70usd. to 19usd on A123'S. There some energy density in my wallet.
999zip999
Postby deVries » Mon May 14, 2012 10:46 pm
flathill wrote:Nice selective quoting
Here is the thread
Marines use 5v lipo
Get a clue moron
This sort of name calling only serves to point out your intolerance for good discussion & learning. You started this kind of intolerant behavior stating falsely that I did not read one of your previous posts correctly...
"Obviously you lack critical reading skills and simply skim read to find the negative"
My point to you is this company is *not* proposing a doubling of battery capacity at this time. Furthermore, it is only a "battery additive" company that improves aspects of certain battery chemistry types. Unfortunately, it is UNPROVEN in any product, nor do we know if it is even being used in any commercial product.
The company has NO new PR Press Release Announcements since March 2011. Which is the press release you 1st posted, & I have copied from too.
Please stay off this thread if you intend to name call one more time, period, because you resort to making personal attacks that are completely irrational. :? Being respectful or not rude is the proper etiquette & form for posting on ES at least in technical areas. :twisted: Go to the Biker Bar. :lol:
This proves this company can not double battery capacity by its own statement, at this time, which is the main topic of this thread...
deVries
Postby deVries » Tue May 15, 2012 2:15 am
I've reconsidered and changed my mind about battery life-cycles beyond 1,500 cycles:
Once energy density doubles from today's A123/EIG current best cells, then I am in complete agreement with your statement above. Though, I would always hope for more too. 8)
I would then suggest these specs become much more important:
I would, especially, also want to know how much voltage sag there is under load between 800-1,500 cycles vs new. I agree going beyond 1,500 or even 1,000 cycles is not nearly as big a deal as capacity & performance under load is from 800-1,500 cycles vs new. Calendar life would be much more important after 1,000 to 1,500 cycles too. IMO.
deVries
Postby fivari » Tue May 15, 2012 6:24 am
fivari
Postby deVries » Wed May 16, 2012 9:13 am
Thanks for the link. :D That looks very promising, still basic research though, and it's looking to be 7-10 year off tech IF it works. The thing to watch for is more news, this one is July 2011, and if they already have big funding, licensing arrangements, patents pending, or VC money.
Now, Dr Li and his team have discovered the key to maintaining the remarkable properties of separate graphene sheets: water. Keeping graphene moist – in gel form – provides repulsive forces between the sheets and prevents re-stacking, making it ready for real-world application.
“The technique is very simple and can easily be scaled up. When we discovered it, we thought it was unbelievable. We’re taking two basic, inexpensive materials – water and graphite – and making this new nanomaterial with amazing properties,” said Dr Li.
When used in energy devices, graphene gel significantly outperforms current carbon-based technology, both in terms of the amount of charge stored and how fast the charges can be delivered.
deVries
Postby chilledoutuk » Thu May 17, 2012 7:45 pm
Honestly i am about as interested in experimental battery technologies as a monkey is in bannana skins. If its made it to mass production then i will maybe read about it and perhaps consider using it.
I am firmly in neptronix's court of thought what needs to be the primary investment of development is in making affordable battery's that don't rely on rare materials that last many many cycles yes battery cars might weigh twice as much as current petrol cars but who cares we aren't pushing the weight the car is.
Hey it might even be an excuse for everyone to be driving around in Huge presidential sized vehicles for long range and have smaller cars for short range trips.
Technically I think what manufacturer are mostly developing are ways of making it so you can charge you battery in a matter of minutes at a station which is possible with a123 cells i have seen people zip charge a123 cells to 80% capacity in 10 minutes.
They will be frantically looking for ways to keep company's like shell in the loop and letting them provide high speed charging outlets that they can sell you electricity from would be a way of appeasing the pressure from company's like them who are no doubt scared shitless about EV vehicles.
Honestly stopping for 10 minutes every couple of hours of driving would probably be a good thing on long road trips in terms of safety.
chilledoutuk
Postby JRP3 » Fri May 18, 2012 8:07 am
All the attention to fast charging and long range is rather misguided since most daily miles driven are less than 40 miles. Cheaper batteries with better specific energy means more affordable vehicles with more usable range, the more range you have the less you need fast charging.
Building the AMPhibian http://amp-phibian.blogspot.com/
JRP3
Postby Lock » Fri May 18, 2012 11:20 am
chilledoutuk wrote:They will be frantically looking for ways to keep company's like shell in the loop...
They're already totally in the loop... hydrocarbons used to make plastic components like battery separators and containers. Oil and gas to produce electricity. Plastic components to lighten overweight vehicles... No worries mate, we're totally hooked on oil and gas, EVen if not burning it in vehicles with infernal combustion exploding engines...
Lock
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
Lock
10 GW
10 GW
Postby myzter » Mon May 21, 2012 7:46 pm
Here is two links with some newer news..
Stable cycling of double-walled silicon nanotube battery anodes through solid–electrolyte interphase control
Although the performance of lithium ion-batteries continues to improve, their energy density and cycle life remain insufficient for applications in consumer electronics, transport and large-scale renewable energy storage. Silicon has a large charge storage capacity and this makes it an attractive anode material, but pulverization during cycling and an unstable solid–electrolyte interphase has limited the cycle life of silicon anodes to hundreds of cycles. Here, we show that anodes consisting of an active silicon nanotube surrounded by an ion-permeable silicon oxide shell can cycle over 6,000 times in half cells while retaining more than 85% of their initial capacity. The outer surface of the silicon nanotube is prevented from expansion by the oxide shell, and the expanding inner surface is not exposed to the electrolyte, resulting in a stable solid–electrolyte interphase. Batteries containing these double-walled silicon nanotube anodes exhibit charge capacities approximately eight times larger than conventional carbon anodes and charging rates of up to 20C (a rate of 1C corresponds to complete charge or discharge in one hour).
http://www.nature.com/nnano/journal/v7/n5/full/nnano.2012.35.html
New Nanostructure for Batteries Keeps Going and Going ...
https://news.slac.stanford.edu/features/new-nanostructure-batteries-keeps-going-and-going
SolarCross
Full suspension e-bike (w/double crown forks) 38lbs 8oz / 17.46kg
Electric bike drifting and burnouts in Canada
rolling on 15 watts of solar - thats just 5 watts more than an Ipad requires!
myzter
Postby Lipoflyer » Mon May 21, 2012 8:49 pm
Lipoflyer
Postby myzter » Mon May 21, 2012 9:43 pm
Envia Systems is several years away 2015-2017
SolarCross
myzter
Postby deVries » Tue May 22, 2012 9:57 am
The motorcycle guru from ZERO seems to agree closely with my original post for this tread:
8) :twisted:
Here are links:
Real Range Motorcycle
Simply State The Range At 30 and 70 mph
A simple solution is to state the range at 30 mph constant speed and 70 mph constant speed. It still is going to be a "best case" kind of range, but at least it's easy to understand. Stop and start driving is not as important to evaluate because it doesn't majorly affect the range like in a gas car. It would be even better to redue these ranges by some fixed percentage just like the EPA does for cars.
Motorcycle riding is about having fun and that means spirited riding. The MIC test does not account for spirited riding. An electric motorcycle is eco-friendly and economical, but it should also be fun. You need to be able to pull away from traffic at stoplights and zip around cars without worrying about how it affects the range. The electric motorcycle industry has to come up with better standards that reflect real world motorcycle riding so buyers can know what to expect.
6-7 Miles Per Kwh
One way to quickly estimate the average range of an electric motorcycle is to multiply the capacity of the battery (in kilowatt hours) times either 6 or 7 miles (10 or 11 kilometers). Use 6 miles for more upright motorcycles with poor aerodynamics and 7 miles for sportbikes with better aerodynamics. For a 9 kwh motorcycle with upright riding position, that yields about 54 miles. From that number you can adjust it up or down for speed and riding style. You still have to account for how much your range will vary due to speed, but at least you are starting with a range number that is going to be closer to your average range.
100 Miles Real Range is the Goal
We think 100 miles of real range on an electric motorcycle is what most people want. This is about an hour or so of saddle time. For most riders, when a trip is longer than an hour, it's more comfortable to drive a car. Figuring the battery capacity backwards, this equates to 14 kwh for a sportbike or 17 kwh for an upright motorcycle. That's a much bigger battery than what's currently on the market, but we think that it will be the turning point for electric motorcycle sales.
15kWh 100 Mile Range is Getting Closer to My Ideal - What Speed to Do It???
Electric Motorcycle Battery
Let's look at an example of an electric motorcycle battery pack that uses this technology. This will show how significant the improvements are.
The result is a motorcycle that has over 60% more capacity than what is currently available. More importantly, it can do a real 100 miles range when ridden the way that motorcycles are generally ridden. The pack shown by the blue rectangle is to scale and is only 7 inches wide when looked at from the front. It's made thin so that the frontal area is minimized. This helps the motorcycle cut through the air like a knife and increases the range at 70 mph. The pack is about 200 pounds and the total motorcycle weight is around 400 pounds. The battery cell cost and assembly cost is the lowest possible. Service and reliability is unmatched by either gas or electric motorcycles.
Notice that the pack is rated by the cell manufacturers minimum capacity, not the nominal capacity. The total capacity is also not rounded up. Exaggeration is not needed when you can deliver 100 miles of real range.
deVries
Postby myzter » Thu May 24, 2012 9:39 am
Why just double capacity when tripple capacity is within the next year !
http://news.wsu.edu/pages/publications.asp?Action=Detail&PublicationID=31776
SolarCross
myzter
PreviousNext
Return to Battery Technology
Users browsing this forum: Bing [Bot] and 5 guests
