[/quote]
Justtoby wrote:Rix wrote:Justtoby,
I noticed the frames as well. 100K right there in retail. Really neat. Do you have any information about the new upgraded batteries coming with all of the steatlh models? Besides most likely being lipo4, I am wondering if its either more capacity same weight or same capicity and slightly lighter weight. Rix
As far as I understand from Darin they are a new spec due to new supplier or new cells (probably due to slow supply) but Darin said there was no difference in output at all. Yes, still lifepo4.
Rix wrote:Here is a pic of my Lizard Skins fork and shock protectors and a Felt Bermaster Tire. I really liked this tire on my old cruiser. I am hoping it can handle the power of the Bomber.
Removing cranks
To remove a crank, proceed as follows:
- Hold the gear shift button with pliers and unscrew the tiny Allen screw M3
with an 1.5-mm Allen wrench.
- Unscrew the button.
- Remove the axle bolt with a 14mm box spanner. Check, to make sure that
the washer underneath the bolt didn’t remain in the axle hole.
- Insert the small tube from our tool set, before using a standard puller to
remove the crank. (an M6-nut may do the job as well, if you don’t have the
original tool set).
Very important: If not using the small tube or an M6 nut, you will destroy
the shifting shaft when pushing with a standard puller!
If using a different crankarm not provided by the manufacturer, make sure the
hole has a depth of at least 8mm.
Please also make sure that the right-side crankarm is not wider than 25mm,
to prevent it from touching the spider when being tightened.
full-throttle wrote:I don't think you need a puller - the cranks are self extracting.
i.e. turn the smaller hex counter-clock-wise. It will bottom out against the cap and release the crank.
Mr Lowbank wrote:full-throttle wrote:I don't think you need a puller - the cranks are self extracting.
I did try that and the cap started to bulge I thought I was butchering it so thought there must be another way.
glowwormbicycles wrote:Mr Lowbank wrote:full-throttle wrote:I don't think you need a puller - the cranks are self extracting.
2 different systems being discussed for each bike Bomber vs Fighter
Bomber's Vboxx crank arms do have self extracting inner bolts. It's a nice easy system if nothing's seized up. No tools needed except the big hex wrench.
Fighter has a square taper BB axle hollow in the middle with the shift rod that sits through it. The Fighter needs the crank extractor with a hole in the middle as mentioned.
Rix wrote:Hyena,
Checked out your fighter on you website. Looking at the pic, did you relace your hub motor to a 26" MTB Wheel? It looks bigger than the front. If so, I want to know how it handles. Is it pushing the front in the corners? Breaking loose? Stuff like that. BTW, great videos. Please keep em going.
Rix
Rix wrote:Cowardly duck,
You mentioned you had the Felt Bermasters on your bike and they were noisy on pavement. How was the traction off road? Other than being noisy, was the tire durable? What about rolling resistance on pavement. If I could design the perfect Ebike tire, it would have the following traits: low rolling resistance, super traction in wet, sticky on dry, excellent off road, fast on road, very light, puncture proof, last forever. "Right". Seriously though, I am always on the hunt for good all around tires and would like to know what you think about the Bermasters.
Rix
Users browsing this forum: chroot, dawnpatrol, tuurb and 17 guests
