NiMH charger 36volts needed
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
Postby zoshe » Sun Mar 18, 2012 12:30 pm
I'm a newbie. Nice stuff U guys R doing here.
I need a charger for a 36v NiMH battery pack from a Giant Suede.
zoshe
Re: NiMH charger 36volts needed
Postby momo » Sun Apr 15, 2012 8:53 am
Hi, did you find one? I have one for a tidalforce bike if you still need one.
momo
Postby zoshe » Mon Apr 16, 2012 6:19 pm
I only found new ones online, but I have not bought one yet. How much do U want for the NiMH 36v charger, and R U in the tri-state area?
zoshe
Postby ambroseliao » Wed Apr 18, 2012 2:15 pm
The Tidalforce charger is designed to work with (surprise!) Tidalforce batteries including their integrated BMS. It will take a bit of work to modify it to work with non-TF batteries!
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby joe tomten » Thu Apr 19, 2012 11:50 am
I have one, along the the battery pack and case that came with - if you're interested.
joe tomten
Postby momo » Thu Apr 19, 2012 4:59 pm
Its actually pretty simple. The third wire is a temp sensor input which needs a feedback. you can use a cheap resistor.
momo
Postby momo » Thu Apr 19, 2012 6:39 pm
Yes, this charger is not for you. Just tried a 10k resistor from third wire to groung and seems to work. Has to be connected to the circuit at same time as the battery pack inorder for it to work. Possible to bypass internally, but
Probably not worth the effort.
momo
Postby zoshe » Fri Apr 20, 2012 2:29 pm
Thks 4 trying MoMo. I sent U a message Joe.
zoshe
Postby Monstarr » Wed Apr 25, 2012 8:59 am
Novox C20 scooter
Lyen 12FET controller
Prius NiMH powered
Monstarr
Postby rickhoover » Tue May 08, 2012 10:37 am
Hello all! I'm a noob, and this is my first post. Has anybody had experience with the Tenergy 3A 36V Ni-Mh charger mentioned by Monstarr. It receives 2.5 out of 5 stars from the selling site all-battery.com and can be purchased cheaper at Amazon.com ...Problem is I too bought a used Giant Suede with its 2 original batteries and the charger. It rode fine during the test ride, but when I got it home the charger starting its blinking lights indicating it was charging correctly, and thus not charging. I thought the batteries were bad, and soldered up a new series of D-cells, soldered the old terminals up to them with [including the two resistors and the temp sensor (not sure if either of those are good, and if they may in fact be part of the problem)], but the charger still indicates with its blinking light that there is a problem charging. Any help or advice is appreciated...TIA!
rickhoover
Postby ambroseliao » Tue May 08, 2012 11:14 am
Welcome, Rickhoover.
You would be much better served if you created a new topic with what you stated in your post. Perhaps title it, "Giant Suede Battery Charging Problem" or something to that effect.
Ambrose
ambroseliao
Postby rickhoover » Tue May 08, 2012 2:04 pm
Thanks Ambrose,
I've posted here for anyone interested:
viewtopic.php?f=14&t=39522
Rick
rickhoover
Postby Monstarr » Wed May 16, 2012 3:03 pm
I use the tenergy/all battery 48V NiMH charger on my Prius 42s2p pack.
Works fine!
Novox C20 scooter
Prius NiMH powered
Monstarr
Postby cal3thousand » Wed May 16, 2012 3:55 pm
I have one for sale! PM me if you are still interested.
I just picked up a Giant Suede where the battery kicked the bucket, charger should still work. I'll take $20 + shipping.
SOLD to aperry4751
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby Lessss » Wed May 16, 2012 8:30 pm
NiCd and NiMH chargers are the same apparently as that is what ebikes.ca sent me for my NiCd I got from them a Nimh charger. Confirm this with others.
Give me nuclear batteries I say!! Ripped off by Joshua Goldberg to the tune of almost $900 re headway groupbuy for batteries, no $ no batteries
http://www.openoffice.org/ or https://www.libreoffice.org/
http://www.ubuntu.com/
Lessss
Return to Items Wanted
Users browsing this forum: ian.mich and 0 guests
