chuckufarley wrote:Oh and also mine weighs in at at about 400lb or less I picked it up and moved it so it cant be 1000 lbs but the rearend is like a chevy .....4.11 gears??
The later 4-wheel ones were heavier than the early 3-wheelers like you have. The "dry weight" of mine is generally listed as 400+ lbs, then add ~400 lbs more for the batteries, and more yet for the optional windscreen and roof mine has. It doesn't add up to an actual 1000 lbs, but it's damned heavy.
And yes, it doesn't have a "controller". I was using the term colloquially...
Good find!
