Good! Someone finally oil cooled a hubbie!! HS3540
Re: Good! Someone finally oil cooled a hubbie!! HS3540
Postby John in CR » Sun May 20, 2012 8:16 am
dfar wrote:
hjns wrote:
dfar wrote:On my other motor I run regen braking so I don't use a back brake caliper so no worries about clearance there.
Hmm. I use regen AND a disc brake. I find that my regen braking just does not cut it in case of an emergency brake. In such a case, I want both my front and rear hydraulic calipers to be fully engaged in providing the maximum braking without blocking.
kids this is good advice, :wink:
It depends on the rig. I run regen as the only rear brake on my SuperV, and at 5.5kw peak braking it test the limits of traction. The only time I miss a rear mechanical brake on that bike is at very low speeds where there is no regen braking. On my cargo bike I run throttle activated regen with a very gentle stopping force, so yes that bike requires a rear brake.
John
John in CR
Postby Andje » Sun May 20, 2012 8:23 am
I feel like skidding my rear tire in an emergency does not compare to instant full regen of about 5000w. I doubt my calipers can absorb 5000w as efficiently as my motor.
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby hjns » Sun May 20, 2012 11:51 am
Andje wrote:I feel like skidding my rear tire in an emergency does not compare to instant full regen of about 5000w. I doubt my calipers can absorb 5000w as efficiently as my motor.
Agreed. However, in an emergency stop, I use both regen AND calipers. The regen will bring me back to 20kmh only. Also, adding the brake force of my hydraulics to the regen allows for an even better controlled stop. And yes, of the 6kW power, 5kW may be produced by the regen, and another 1kW by my calipers, which is very nice.
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, TALAS 36 front fork, Maxxis Minion 2.7 tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby The Stig » Tue Apr 09, 2013 12:33 am
Well it sounds like the NZ geeks are having some luck with this oil cooling thing
http://www.ev.geek.nz/viewtopic.php?f=32&t=162&sid=7c6fe6e8b7a1a2f8e8879728ce4247fd&start=150
Anyone tried this with a 9C or MAC?
Last edited by The Stig on Tue Apr 09, 2013 12:34 am, edited 1 time in total. View post history.
The Stig
Previous
Return to Motor Technology
Users browsing this forum: No registered users and 5 guests
