Thumb throttle wiring - HELP needed
Postby zooz » Sun May 20, 2012 6:53 pm
HI All,
I bought a kit - http://www.bmsbattery.com/ebike-kits/345-bafang-350watts500watts-bpm-motor-e-bike-kit.html from BMSBattery, which came with a thumb throttle. The kit didn't have any wiring instructions or anything. I managed to figure out pretty much everything apart the battery level indicator lights on the throttle.
The thumb throttle works as expected, but the battery level indicator lights will not work. The throttle came with a 3-way connector as well as a couple loose wires. I just simply connected the 3-way connector to the controller, which made the throttle work, but not the lights.
Do I need to connect those two loose wires to the controller somehow or it just means that the lights on the thumb throttle are faulty? Does anyone have a diagram or some info on the throttle wiring?
Thanks in advance!
- zooz
zooz
Re: Thumb throttle wiring - HELP needed
Postby rkosiorek » Sun May 20, 2012 8:05 pm
the battery level meter reads battery level. so i guess it would have to connect to the battery to read the level. the throttle should have a 4th wire. that 4th wire connects to the battery + (red) wire to read the level.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby Rassy » Sun May 20, 2012 9:21 pm
I would say not to bother. The LEDs are ok for SLA batteries, but even then, when you send your main voltage to the throttle you increase the chances of an internal fault, particularly if the throttle ever gets water in it. The actual throttle just works with 5V from the controller.
Another issue with the LEDs comes up when you increase your batteries to 48V. The LEDs become useless, are super bright, will probably soon burn out, and the chance of a short is increased. Just for the record, many of us started with 36V kits and then upgraded to 48V for better performance.
-Rassy-
Two Tadpole Trikes, 6X10 9C mid drive, NuVinci CVT Auto Shift, 48V LiFePO4
viewtopic.php?f=28&t=18606
viewtopic.php?f=28&t=47043
Rassy
Postby DAND214 » Sun May 20, 2012 11:20 pm
If it's working, don't try to fix it.
the battery level indicator is just usless.
Even with SLA's when the light shows it's low, it too late.
Ignore that and get a CA, best piece or instrument you can possiby own.
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby 999zip999 » Mon May 21, 2012 12:30 am
If you have only three wires for the throttle that's all it takes to work. Some have 4 wires with the throtttle connection. The being live hot the seem as battery voltage, but being hot is a posable problem. The guage dosn't work not worth the trouble. Let us know how it works. That's a cheap kit, plus postage. Oh
999zip999
Postby zooz » Mon May 21, 2012 5:00 am
Thank you all for your answers! Useful info.
I will just leave it as it is at the moment.
zooz
Postby d8veh » Mon May 21, 2012 10:15 am
There should be three extra wires. The brown and yellow are for the red switch and the green is for the LEDs. You can us the switch for anything you want, but if you have one of their controllers, you can cut the thin red wire to the battery connector and connect the brown and gree to the controller side and the yellow to the battery side. The switch will then work as a "standby" switch for your controller to cut the power when you want to. You shouldn't leave it like that overnight because there's still a slight battery drain, but OK for several hours. The LED lights will be on when your controller is active (not standby) and show approximate state of charge of your battery if it's a LifePO4 or LiMn (not sure about Lipos). Alternatively, you can connect the green directly to the battery and the LED's will show approximately the charge.
All my present bikes that I built can be seen here: http://www.pedelecs.co.uk/forum/members/d8veh.html
d8veh
Postby chisixer6 » Wed May 23, 2012 6:02 pm
I have a similar kit(Yescomusa) with that battery led's. I got the 3 wires for the throttle with the white connectors, there is also 2 separate black connectors (2 wire and 3 wire), I believe these are for the led's and on/off switch. All of this in a black housing with the 3 sets of wire.
Motobecane ..bafang front driver.. 42v
24" girls bike ..ebikekit 20" fwd..75v
24" Schweinn 9c 20"rwd 75v
26" Schweinn Yescomusa 48v 800watt dd
Easy Racer clone LWB.....24" rear e-bikekit 48v ..ready for testing
Hooligan clone , longer rear chain stay.. twin 20"...
fun bike...twin 16" wheels. small rear motor... ready for testing
convert my CLWB recumbent to a front bafung@48v..ongoing
chisixer6
Return to E-Bike Technical
Users browsing this forum: Little-Acorn, Nanoha, rscamp and 6 guests
