HI All,
I bought a kit - http://www.bmsbattery.com/ebike-kits/345-bafang-350watts500watts-bpm-motor-e-bike-kit.html from BMSBattery, which came with a thumb throttle. The kit didn't have any wiring instructions or anything. I managed to figure out pretty much everything apart the battery level indicator lights on the throttle.
The thumb throttle works as expected, but the battery level indicator lights will not work. The throttle came with a 3-way connector as well as a couple loose wires. I just simply connected the 3-way connector to the controller, which made the throttle work, but not the lights.
Do I need to connect those two loose wires to the controller somehow or it just means that the lights on the thumb throttle are faulty? Does anyone have a diagram or some info on the throttle wiring?
Thanks in advance!
- zooz
