Lyen controller not working at 37V
Re: Lyen controller not working at 37V
Postby cwah » Wed May 23, 2012 5:23 pm
Yeah, but I wasn't sure about the voltage I would need. Better to have something adaptable rather than having to change the whole system. I found that the weight was identical to a normal controller, so I preferred to get a higher voltage one for safety :lol:
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby NeilP » Thu May 24, 2012 1:59 am
Yes, se your point, but less current with the high voltage ones, so less acceleration :(
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
10 GW
10 GW
Postby Jeremy Harris » Thu May 24, 2012 2:28 am
Using a high voltage controller for a lower voltage application also means less efficiency. There is a fairly linear relationship between FET on resistance and maximum voltage, such that 100 V capable FETs will have around double the on resistance (and hence double the losses at a given current) than 50 V capable FETs.
It's for this reason that I changed the FETs in my boat controller (that works at around 20 V max) to IRLB3034 FETs (40 V maximum. These have only 38% of the loss that the 100 V max IRFB4110 FETs commonly used in ~80 V controllers, and only 15% of the loss of the 150 V max IRFB4115 FETs frquently used in 100 V + capable controllers.
If you want best efficiency, then go for a controller fitted with FETs that match your operating voltage range, don't go for a controller with an unnecessarily high voltage spec.
Please ask questions on the forum, rather than by PM, as it helps others and you'll get a better range of answers.
Jeremy Harris
10 GW
10 GW
Postby NeilP » Thu May 24, 2012 7:50 am
Ah yes, forgotten about that.
Is this the same controller that you have the 400W for 12mph thread going about or is this a different bike? This could account for a few more watts lost. OK, probably not the full amount, but a little bit here and there, all soon adds up
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby cwah » Thu May 24, 2012 10:06 am
Yes, it is the same controller. Actually I wanted to be able to transform my 74V8AH battery to 37V16AH for maximum distance when required. But I didn't know that higher voltage controller would be less efficient...
Hopefully, I know that I can always increase the speed and voltage If I want/need to!
cwah
Previous
Users browsing this forum: Bing [Bot], cware05, Drunkskunk, marych, Miles, Rassy and 10 guests
