Wich controller supports a pedelec or PAS sensor?
Postby dutchlincoln » Wed May 23, 2012 2:24 pm
For my build i need a controller thats compatable with a pedelec sensor.
I want the pedelec be a must in order to activate the electric assist.
I want to install the hand or thumb throttle to set the desired speed.
Better may be the support for a torque sensor, so i can ditch the throttle, and have the electric assis be regulated by the load i have to pull on the pedals.
Anyone knows if the Lyen or Kelly controllers can do this, or do i really need specific controllers? If so, which would these be then?
Thanks.
dutchlincoln
Re: Wich controller supports a pedelec or PAS sensor?
Postby d8veh » Wed May 23, 2012 4:18 pm
I've been wanting to do the same thing. I have a 10k potentiometer on the handlebars that I use as a speed control, but up to now I've had to switch it manually. I have a prototype working at the moment that uses a very small microprocessor to take a signal from the pedal sensor and switch a relay that connects/interupts the throttle signal wire, and I also made a protype that would give a direct throttle signal from the microprocessor using the pot and pedal sensor as inputs, but my programming skills are a bit rusty, so I couldn't get it running smoothly. Speedict told me that they will try and get this function in a future software update after they've developed their new controller. Other alternatives atre the Thun torque sensor, which I've seen on Aliexpress:
http://www.aliexpress.com/fm-store/6055 ... ensor.html
or the one that BMSbattery do:
http://www.bmsbattery.com/91-torque-sensor
All my present bikes that I built can be seen here: http://www.pedelecs.co.uk/forum/members/d8veh.html
d8veh
Postby dutchlincoln » Wed May 23, 2012 4:43 pm
Im not looking for the sensor, but a controller to connect them to.
I want to work with stock availAble parts, as i'm obligated by law to have it working with a pedelec...(europe..)
dutchlincoln
Postby cal3thousand » Thu May 24, 2012 11:44 am
Speedict can add PAS functionality to any ebike.
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Return to E-Bike Technical
Users browsing this forum: Bing [Bot], pradeepswain, Sancho's Horse and 11 guests
