E BIKE MY1020GDA 60V 1000W YK43B 24-60 V Controller
Re: E BIKE MY1020-B GDA 60V 1000W YK43B 24-60 V Controller
Postby Miles » Fri May 18, 2012 6:18 pm
darkangel wrote:i have no idea how
Take the wheel off and measure across the inside of the frame with a ruler?
BMX hubs are usually between 110mm to 114mm O.L.D.
Miles
Postby darkangel » Fri May 18, 2012 8:26 pm
5.5" inside of rear wheel forks
darkangel
Postby Miles » Sat May 19, 2012 3:03 am
So, it's a frame for standard 135mm width hubs.
The Currie USPD hub will fit: http://www.evdeals.com/USPD%20Drive%20Parts.htm
Miles
Postby darkangel » Sat May 19, 2012 11:33 am
i am on the way to bike shop will see what they got to offer i will need new set of spokes i guess
darkangel
Postby darkangel » Sat May 19, 2012 5:30 pm
ok guys just got back
shop master suggested getting new fixie wheel insead of buying all parts
all parts for the wheel coversion would cots me 150 including; spokes, tools cog, cog lock
good news
my sprocket set/casete is not slide on but screw on so, i do not need freewheel
also he mentioned, that under so much torque fixie hub may unthread
darkangel
Postby Miles » Sat May 19, 2012 5:45 pm
darkangel wrote:shop master suggested getting new fixie wheel insead of buying all parts......
Quite.
Miles
Postby darkangel » Sun May 20, 2012 3:54 pm
ok guys under so much cost it is not worth converting this bicycle so like Miles said i am forced to quit this project without any further attempts
29ner mountain bike is just to big to convert
thank you all for suggestions and good luck with your coversions :wink:
darkangel
Postby Miles » Sun May 20, 2012 5:22 pm
Yikes! I hope you didn't read my "quite" as "quit"......
Miles
Postby darkangel » Sun May 20, 2012 5:41 pm
no thats ok miles :D
darkangel
Postby darkangel » Sun May 20, 2012 5:56 pm
this is what i was told
them;
"you need 700cc rear wheel with 135mm quick release hub and brake disk mount holes, so you candrill holes on the cog and mount it on to disc brake mount. the quick release excel/shaft needs to be changed to longer shaft. cost for rear wheel $99, 3 cog set 16, 18, 22tooth $45, new slide on casete $35, the matching front wheel with disk brake $85"
me;
my budget is $100 i cant spend no more than $100, as i need to get new motor
them;
"well, thats your problem"
darkangel
Postby darkangel » Sun May 20, 2012 6:52 pm
i looked all over e bay and found wheels but there are no details about hub, checked links miles and others posted but no quick release
if you guys know someone who got it at resonable price let me know
darkangel
Postby DATABASE00 » Mon May 21, 2012 4:45 pm
sorry to hear of all the issues your running into. its hard keeping it looking good while trying to save cash. Im in the middle of that still, but finally got a complete bike s now im trying to figure out batteries and stuff. still like a month away from actual riding thow lol.
DATABASE00
Postby darkangel » Mon May 21, 2012 5:03 pm
i have contacted other supplier to see if he can offer me wheel set for + - $100
the way my bike wheel set is setup, just doesn't work so by changing the wheels on it, the performance and equipment suitability will improve by 100%
database-why don't you run it with slas for couple months and see how it holds up, then make a decision
i still care about looks, i would rather quit the project then ride something that looks like from the junk yard, but that is just me i guess the way i am :D so don't you guys take it personally, every mans creation is his reflection. look what Miles built the damn thing lookes awesome
darkangel
Postby rjoe » Thu May 24, 2012 12:55 pm
this site has parts to build a double-freewheel wheel with an adaptor for large sprockets on the left side
I built mine for about $100 including hub, left-side freewheel and spokes
rjoe
Postby darkangel » Thu May 24, 2012 1:42 pm
hi thank you RJOE
I looked into it and the problem is price $50 for the hub then $35-40 for new spokes custom made not including shipping, that's as much as whole rear wheel would cost me, while all of it would be already setup on it and i wouldn't have to mess with anything.
so that's why i am looking into getting new rear 700cc wheel. I think that quick release wheels come with 135mm nut to nut hubs and disk brake mount on the side so i don't have to worry about stripping the threads.
the rear hub would have to be able to handle 300lbs of pure weight so that's why i think by bolting the sprocket on to disk brake mount would work better then screwing the cog on to the hub (if otherwise let me know guys, maybe i am just wrong, it wouldn't be the first time though :) )
also i need the front wheel with disk brake mount to = rear wheel
my budget is $100 for both disc brake wheels
darkangel
Postby darkangel » Fri May 25, 2012 2:05 pm
great mother of smurfs i found some wheel
darkangel
Postby darkangel » Fri May 25, 2012 2:22 pm
on idea to what i want to accomplish
here is the link for the cog
http://www.ebay.com/itm/VeloSolo-DISC-C ... #ht_6648wt
darkangel
Postby darkangel » Sun May 27, 2012 11:24 am
darkangel
Postby darkangel » Sun May 27, 2012 10:49 pm
the new my1020b 60v is on the way
darkangel
Postby Alan B » Sun May 27, 2012 11:48 pm
Did you ever solve the gearing problem? If you don't get the motor spinning at the right RPM it will overheat. Match the voltage to the gearing, your voltage was too high on the first try.
Alan B
1.21 GW
1.21 GW
Postby darkangel » Mon May 28, 2012 11:15 pm
will use 4 sla batteries as 6 is to much
i have 11t sprocket from my old motor will use it for the new
direct drive or hub sprocket:
thin but not to thin tires for the new wheels,
computer 12v fan running of 1 sla battery will some how connect to motor, will use the old one to make the fan tupe profile, hell i may start selling those fan cooling profiles.
i have 3 sprockets got it from bike shop 15t 18t 22tooth
to begin with i will use the 15t sprocket and see how hot motor gets after 1 mile.
will see what happens, hope it works.
darkangel
Postby darkangel » Tue May 29, 2012 8:59 pm
curently waiting for all orders to come in, uh!!
cant wait even though i wont be able to start working on it all till this saturday
darkangel
Postby darkangel » Tue May 29, 2012 9:02 pm
darkangel
Postby darkangel » Fri Jun 01, 2012 3:36 pm
the wheels arrived and new motor arrived
dang wheels are so light compared to my old wheels, it's unlivable what i had on my bike, no wonder my knees were killing me
so now i have to get sprocket cassette, and new tires, will take it to bicycle shop tomorrow, probably will need some sort of spacer for in between hub and rear frame fork.
once all done will post some pictures
darkangel
Postby coldfusion594 » Fri Jun 01, 2012 8:08 pm
DATABASE00 wrote:about the motor that is alot of amps needed. And weight isnt that pretty looks like my treadmill motors. But seems really strong.
4 HP 24 VDC ELECTRIC MOTOR
45 AMPS NO LOAD
140 AMPS FULL LOAD
8000 RPM FULL LOAD
32 INCH POUND OF TORQUE
¾” DIAM. X 1 ¾” SHAFT WITH KEYWAY
MOTOR DIMENSION 4” DIAM. X 7 ¾”
SHPG 24 LB (ESTIMATED)
Also lookup flip flop rear hibs.
it makes it so the back only has one gear on both sides. one side you always have to peddle other side you can coast, you could put the coasting side for you and the motor side for the motor.
So long story short, you can't just put a freewheel on both sides? hmmm
if so...
Can you choose which side to put the freewheel on?
I'm liking the idea though! would something like this be beefy enough to handle the power coming from the motor?
sorry I did not want to open up a whole new thread
coldfusion594
PreviousNext
Users browsing this forum: christerljung, Miles, panurge and 7 guests
