Aussie 200 Watt Limit Thread
Re: Aussie 200 Watt Limit Thread
Postby t3sla » Sat Apr 21, 2012 12:29 am
Nah officer, I was running at 100V with only 2amps so that means I was under the limit :mrgreen:
t3sla
Postby whatever » Wed May 09, 2012 6:14 am
the australian auspost bikes, to be legal on 36v system ( i'm assuming they are using lithium) with bmc motor would be
5.5amps max to be legal ( at around 80% efficiency).............( other battery types max amps would be very similar)........a bmc motor using 5.5amps max would be very very very very poor , if it would run at all with load on it. I've seen the auspost bike around here, I think I could be fairly confident they are not under 200watts peak.
I tried a standard non geared brushless motor on 200watt peak ( 48v system) by adjusting controller max amps via the shunt and it WOULDN'T EVEN RUN PROPERLY!!!! it wouldn't start you from a standstill, had to get it running by pedal first then it would run, just enough power to push you along a flat.........completely useless.
whatever
Postby schmidty_81 » Thu May 24, 2012 12:38 am
This is my workaround for this silly law...
Just print out one of these...
onto something like this...
http://www.officeworks.com.au/retail/pr ... per/AUPS64
Slap it on the side of the hub motor and Bob's your Uncle.
If they're going to be silly enough to not spell out how exactly it is to be rated or even who it should be rated by we might as well just rate it ourselves and be equally as vague.
Take that crazy government laws!... Check Mate.
schmidty_81
Postby Hyena » Thu May 24, 2012 4:55 am
schmidty_81 wrote:onto something like this...
Those stickers aren't waterproof and will fall off/look crap in 5 minutes. Ideally you want something vinyl based or specifically waterproof
How very deceitful of you towards our govt anyway :lol:
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
10 GW
10 GW
Postby schmidty_81 » Thu May 24, 2012 6:12 pm
I thought those stickers would be lousy too, so did the guy in the shop, but I thought I'd just give it a try and see how it went. It's been on for about 10 months now and still looks fine, I've ridden in the rain and everything too.
Agreed, it is a little on the deceitful side though.
schmidty_81
Postby Hobbit » Thu May 24, 2012 6:25 pm
"If a law is unjust, a man is not only right to disobey it, he is obligated to do so." - Thomas Jefferson
"The Precious"
Rans Fusion, Crystalyte H4080, Crystalyte 75V 50A stock controller,
66.6V 18s3p 24Ah zippy lipo.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=37934
Love.
Hobbit
Postby d8veh » Fri May 25, 2012 3:51 am
I made some nice labels for my Bafang BPM motor using a standard cheapo laser printer (doesn't work with ink-jet). Design your own label; get some of that 2" wide shiny aluminium tape; print your label on normal paper to see where it's positioned; lay a piece of the aluminium tape on top of the print with it's backing still in place; fix it in position by using normal selotape just over the edges; put the paper with tape back in the printer and print again; cover the image with 2" wide clear selotape to make it weather-proof; cut out the label; peel the backing and stick in place. Mine have been on for about 18 months now and still look totally professional.
Just a reminder that The Speedict can limit power by software and has a very quick option to switch the governor on/off via bluetooth, so you can switch on the governor while your bike is being inspected. Just make sure that you pedal all the time and you're panting hard when they stop you to match your story of pedalling very hard.
I don't have a photo, but here's aphoto of a frame label I did with the same method to show compliance:
All my present bikes that I built can be seen here: http://www.pedelecs.co.uk/forum/members/d8veh.html
d8veh
Postby adrian_sm » Thu May 31, 2012 7:21 am
http://www.bicyclenetwork.com.au/genera ... ing/10607/
30 May 2012. Australia will adopt the Euro standard for e-bikes, clearing the way for the major bike brands to introduce the latest, modern e-bike products into Australian markets. The move should lead to substantial growth in the use of e-bikes in Australia, opening up the benefits of bike riding to a wider range of people. Some Euro standard e-bikes have been available locally, but the market has been dominated by Chinese machines that the local bikes retailers were reluctant to be associated with. Quality was poor, service and spare parts restricted and durability suspect. E-bikes have boomed in Europe in recent years and have been responsible for keeping millions of older people cycling who otherwise would have been hanging up the bike for good. The move came when the Gillard government's Parliamentary Secretary for Infrastructure and Transport, Catherine King, announced changes to the national vehicle safety standards. "This change in the Australian Design Rules will encourage modern electric bicycles as a healthy alternative to other means of transport,” Ms King said. “With the National Cycling Strategy 2011-16 aiming to double the number of people riding by 2016, the Government is keen to work with the cycling community to implement reforms that promote healthy lifestyles. Ms King said that changes to the standard mean the allowable power output has now increased from 200 to 250 watts giving a higher level or performance, while maintaining safety by restricting powered speed to 25 km/h. Riders are required to pedal to access the power or to reach greater speeds than 25 km/h. The change also means new construction standards for batteries, cables and connections as well as other requirements such as braking performance and the strength of frames. Ms King said the changes are an important first step towards an overall review by Austroads of alternative vehicles, which would also include mobility scooters, and a key action identified in Australia’s National Road Safety Strategy 2011-20. “It’s important that this continues to be a national process that is supported by all governments,” Ms King said. Ms King praised state and territory authorities for working constructively with the Commonwealth on this change. However, she said that changes to state and territory road rules may be necessary to allow use of the new electric bicycles and advised people to contact their state road authorities to confirm local provisions. The standard that has now been adopted is EN 15194.
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby adrian_sm » Thu May 31, 2012 7:26 am
adrian_sm
Postby Diamondback » Thu May 31, 2012 7:28 am
a step in the right direction, but not far enough.
i say we should have a 750W limit and have a speed limit imposed instead of the ridiculously low 250W.
Jason.
Ignorance can be solved, stupid is forever
Diamondback
Postby full-throttle » Thu May 31, 2012 7:29 am
25km/h :lol: :roll: :evil:
I can run faster than that..
Time to switch bikes :mrgreen:
PS saw a few posties with their new "200W legal" bikes. None of them even pedal :roll:
full-throttle
Postby Diamondback » Thu May 31, 2012 7:40 am
i saw one of those today too, but he was pedaling, quite hard too.
Diamondback
Postby full-throttle » Thu May 31, 2012 7:42 am
Meh. Prob forgot to charge the battery.
Was it a lime green with a front MAC?
full-throttle
Postby Diamondback » Thu May 31, 2012 7:47 am
he was on a yellow one. didn't get a good enough look to know what the motor was, but it was a very small hub.
about the size of the ezee motor. saw him going up a hill near Marrickville in sydney.
jason.
Diamondback
Postby whatever » Thu May 31, 2012 8:26 am
wholly **** batman!!
thanks adrian sm for posting those links,
this is the change that we've been waiting for, for about 10 years now.........
fantastic news, the 25km/hr is not good, but hey if you've got your legs moving who knows if its the motor or the legs getting you over 25km/hr
this is the important part
"increases the allowable power from 200 to 250 watts and specifies this as a continuous rating"
its changed from 200watts peak power ( 130watts continous) to 250watts continous which is approx 750watts peak!!!!
So all of a sudden the 99% of ebikes in australia that were illegal are now legal ( apart from being able to go over 25km/hr with no assist)........... a small price to pay for the increase in power limit.
It will probably take 20years to change from 25km/hr to something higher but who cares, now things might really get going in australia................about time.
There will likely be some paper come out that mentions the peak power also, 750watt is a guestimate, but should be pretty close.
fantastic
whatever
Postby sn0wchyld » Thu May 31, 2012 9:02 am
the 25km/h thing is a bit of a joke. Call me pesimistc but I see allot of people (legal or otherwise) getting pulled up by the fuzz cause they're going too fast on their ebike, even if the motor isn't doing anything. I mean, if a lycra can pedal at 50km'h and not bother anyone, what difference does it make if a ebike goes 50?
the change to continuous power is a good move, but I wont be getting excited 'till they tell people how that's measured. the last one was apparently 200w peak input power, not peak output :? .
It all still seems kinda stupid to me when I can go out and strap a 2.5+kw 50cc gass motor to my bike and burn around at any speed I like under the speed limit, and though its 'frowned apon' by the cops, it is in fact 100% legal. but I get on my 300w ebike and hit 26km'h, or go faster than 6km'h without pedalling and balm. breaking the law. and I'm pretty sure my ebike at 50km'h is going to both handle those speeds better and stop faster than a road racing bike.
sorry for the rant. long day... and the 'nanny state' kind of attitude in Aus kinda pisses me off. Ill go sleep now :lol: .
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby adrian_sm » Thu May 31, 2012 7:54 pm
Here is a link to the EN15194 standard that manufacturers need to design to, and get tested against to legally sell the bikes in the EU. I haven't read through it properly yet but this is what I noticed when I quickly scanned through it, and discussed it over on this thread.
viewtopic.php?f=25&t=39671#p583494
adrian_sm wrote:
EN-15194 wrote:4.2.7 Maximum power measurement
4.2.7.1 Measurement at the engine shaft
The maximum continuous rated power shall be measured according to EN 60034-1 when the motor reaches
its thermal equilibrium as specified by the manufacturer.
NOTE Thermal equilibrium: temperatures of motor parts do not vary more than 2K per hour.
In circumstance where the power is measured directly at the shaft of the electronic motor, the result of the
measurement shall be decreased by 1,10 to consider the measurement uncertainty and then by 1,05 to
include for example the transmission losses, unless the real values of these losses are determined.
4.2.7.2 Alternative method
When the power is measured at the wheel, the result of the measurement is the reading value.
Annex D gives guidance on how to measure the power at the wheel.
The way I read it, it seems to boil down to what the manufacturer claims the motor can thermally withstand (on a 100% duty cycle for an ebike presumably). Which is wide open for reinterpretation, since is wholly depends on the motor speed, and the temp limit you feel like setting. It is more about protecting the purchaser from a motor melting, than limiting the motors power output. Which would allow you to slap on a 250w sticker on anything, by using a stupidly low thermal limit, then allow people to run it hotter.
Weird standard.
I can't believe my first read is accurate though, I might just have to wade through the whole thing and see how they actaully test it.
adrian_sm
Postby schmidty_81 » Thu May 31, 2012 8:23 pm
I can't understand the logic behind having a blanket speed limit like that, that would be like saying Hybrid vehicles like the Prius are only allowed to go 60kmph running on electric, but unlimited on fuel.
Also you could just have a governor set that your bike only goes 25kmph under throttle only electric power, then as soon as you exert any effort whatsoever through the pedals it unleashes the rest, how could it be determined exactly how much extra power is coming from the pedalling.
I think whoever's in charge of making these rules needs to actually go down to a busy bike track in peak hour and find out just how much slower 25kmph is than the rest of the bike traffic, I used to go along the bike track from Glenferrie road into the city in Melbourne and I can tell you that going 25kmph along there would be like going 60kmph on a busy 100kmph freeway... It's just unsafe.
schmidty_81
Postby Hyena » Thu May 31, 2012 8:41 pm
Cool, my motor is compliant with the new rules! At 25km/hr in street mode on the flat it draws around 5 battery amps to maintain this speed, which is bang on 250w when allowing for motor efficiency. Obviously peak power is a little more than this when accelerating hard or going up hills but that's to be expected. In the same fashion, ford doesn't publish that my XR6T will consume over 60 l/100km of fuel ( 5 times the quoted fuel efficiency) when booting it up a hill or otherwise accelerating hard.
Time to attach some angel wings to the back of my body armour so everyone knows how good I am :mrgreen:
Hyena
10 GW
10 GW
Postby adrian_sm » Thu May 31, 2012 10:28 pm
For ebikes to fit into the new alternative EN15194 type AB definition they would have to be pedelecs. That only allow power when the rider is pedaling forwards, and are below 25kph. So that rules out all throttle only bikes from this category. Leaving us with the old 200w definition.
I have read through EN15194 again now, and still think is is pretty crappy in describing the power limits. The 25kph limit is pretty well described. Saying no more assistance from the motor above that speed. Period. End of story. :cry: No good. The power definition on the other hand has holes all through it. It can be measured in two ways:
1) Section 4.2.7 - As per EN60034-1 - when measuring the power at the motor shaft.
This definition (as I explained above) is all about the safe operating power of a motor, and does not define the actual power output. FAIL
This would let the manufacturer just rate it for 250w, saying if you load it at that it will last. Done.
But the motor in use could be loaded much more allowing higher powers without restriction, and they just rely on the 25kph limit stopping people getting stupid.
OR they have a different method to measure it at the wheel.
2) Annex D - Maximum Power Measurement - Alternative Method - when measuring at the wheel
Test method is hit the throttle from a dead stop (no pedalling allowed, PAS sensor overridden) and time how long it takes to travel 20m, with the bike loaded to 150kg. Then plug it into a formula they specify to determine power.
P = m * (2*D^2) / T^3
P = 150kg * 2*(20 metres)^2 / time^3
The way I read it, if your bike travels 20m from a deadstop in less than 7.8 seconds, your over the power limit. So it is in effect an acceleration limit.
This would be easy to design around if you we happy with a soft start.
Bottom line this new EN15194 definition is really about allowing EU bikes to be sold here. But due to the 25kph power limit, won't be that attractive to the young and fit, but will be quite good for those that like a more leisurely pace as you can get more power than what our current laws allow.
adrian_sm
Postby John in CR » Thu May 31, 2012 11:09 pm
If they're actually uptight enough to enforce these silly laws, I'd move. I guess it's good that they have nothing better to do, but maybe the answer is less cops. The guys out west don't seem to have the same enforcement problem, so what gives. Hassling ebikers is just absurd, and I'm serious. I really would move. I moved to a new house a few months ago due to a mile of torn up road that I got tired of dealing with. :mrgreen:
John in CR
Postby Hyena » Thu May 31, 2012 11:56 pm
adrian_sm wrote:For ebikes to fit into the new alternative EN15194 type AB definition they would have to be pedelecs. That only allow power when the rider is pedaling forwards, and are below 25kph. So that rules out all throttle only bikes from this category.
Yeah that's pretty sucky, what happens to every ebike currently on the road now ?
That's great, all our hub motors are WELL under 200w :lol:
Yep, this is why I run a bigger motor with air cooling holes, it'll last much longer at 250w :P
Power loop holes aside (ie ignoring it) I guess 25km/hr is just an arbitrary limit based on existing euro guidelines. As stated anyone can pedal faster than that and I guess it just stops people roaring around at near-impossible human powered speeds and claiming it's all them if it came to a court case. Until the cops start hating on ebikes like they do with petrol kits the key, as it has always been, is not to ride like an idiot and draw attention to yourself.
That's rediculous, I just timed myself briskly walking 20m down a corridor and it took 8 seconds :roll:
Hyena
10 GW
10 GW
Postby full-throttle » Fri Jun 01, 2012 12:18 am
adrian_sm wrote:The way I read it, if your bike travels 20m from a deadstop in less than 7.8 seconds, your over the power limit. So it is in effect an acceleration limit.
Doesn't mention anything about brakes being on or off ;)
Just to prove how stupid the law is we should make a video of a drag race between a legal ebike and a swimmer :lol:
full-throttle
Postby adrian_sm » Fri Jun 01, 2012 1:36 am
@hyena. This new definition runs in parallel with the old. So it doesn't affect any current bikes, just allows the euro EN15194 bikes to be used in Oz.
Remember that 20m test is to accelerate 150kg total bike mass from a dead stop. You have to admit it is a quick and easy test, just load the bike up and lightly ghost pedal. Not too hard for a cop to do on the side of the road....
adrian_sm
Postby Hyena » Fri Jun 01, 2012 1:41 am
full-throttle wrote:Just to prove how stupid the law is we should make a video of a drag race between a legal ebike and a swimmer :lol:
I reckon we get Aussie Jester out there in his wheel chair - or even on his hands and knees for that matter - I reckon he could cover the distance quicker without any functioning legs!!
Also for maximum impact and to drive our point home the the race should also include a 3 legged dog, a transvestite in ball gown and this guy, all of whom will cross the line before the mighty govt approved ebike - our planet's salvation that will have people abandoning their cars in droves!
Hyena
10 GW
10 GW
PreviousNext
Users browsing this forum: dnmun, dr_frost_dk, JennyB, rick-c and 18 guests
