Cheers Simon. Yeah they're fairly time consuming aren't they!Tench wrote:Nice work Paul, I know what is involved in making those harnesses!! and better pics than the ones i took of my balance harness too, have you done the male plug for the charge lead yet? i found i could bend the solder pins together and solder into groups of 3 resulting in the need for only one wire for each cell string, keeps it a bit simpler.
Tench wrote:I am quite proud that others are using the solution i arrived at for the series/parrallel conundrum especially as i am a relative noob here. Just picked up an alloy frame to start my next build, i,m not 100% commited to a design yet but i think it is going to be a single speed ME4201.
BATFINK wrote:Thanks Paul, that has helped me ALOT. I just want to get a really good ideaof what I want the frame to be like before I take it to my friend who is a tig welderby trade. Seeing bikes like yours is inspirational and I'm hoping I can pull something Similar together. Thanks again.
Kepler wrote:Excellent job on the torque arms. I am presuming no fancy CNC mils used here, just an angle grinder, drill, and file. Makes the job even more impressive in my opinion. Always look forward to your next post. Inspiring stuff.
doc007 wrote:Kepler wrote:Excellent job on the torque arms. I am presuming no fancy CNC mils used here, just an angle grinder, drill, and file. Makes the job even more impressive in my opinion. Always look forward to your next post. Inspiring stuff.
Just what i was thinking.
Timma,
how did you make your torque arms? Im very curious bc I have to cut a similar design.
I only have access to an angle grinder, hand drill, and dremel. Do you think torque arms like yours can be made with those tools? If so, what kind of cutting discs should I be looking to get for the angle grinder and the dremel. Special bits for the hand drill?
The thickness of the metal will have to cut through is 20mm thick. Any tips would be great!
ROG130 wrote:fab job i am just about to start a big hit fsr frame its all ready to tig weld up but am looking for a bit of help what setting did you use for tigging tig gass settings. and the settings onthe tig welder to weld the alloy on your frame what size tig rod did you use and the size alloy tig rods
this will be a big help in getting me started on the welding thanks roger
Yeah i always like to give a bit of extra thought and take a bit of extra time to finish a part nicely too, its good to have pride in your work. Haha, i wish i could have used ti! I got the (certified) mild steel for free so i'm happy lol.Tench wrote:Love those torque arms, they are fab! i like to see thought and care being taken over every aspect of a component rather than just making something functional, but i would have used ti![]()
Don't keep us in suspense for too long dammit!Tench wrote:The new frame is going to be a complete build, all drawn and jigged so i can reproduce it if it turns ok good. I bought a Sarecen dirt jump alloy frame for the bottom bracket and headset tube, it came with some bonus parts, seat post and clamp, head set, handle bar stem, hollow teck bb and a chain device all for £16. But i am not going to give any details about the frame style/design away untill it is finished![]()
Ta Kepler. Yep you guessed it, my cheapy drill press, small fine file, 5" grinder with an ultra thin cut-off wheel and an old M6 tap.Kepler wrote:Excellent job on the torque arms. I am presuming no fancy CNC mils used here, just an angle grinder, drill, and file. Makes the job even more impressive in my opinion. Always look forward to your next post. Inspiring stuff.
Kepler wrote:And Trench, hurry up and start your new project. Paul will be finished soon and I need another top notch build to follow
doc007 wrote:Timma, how did you make your torque arms? Im very curious bc I have to cut a similar design. I only have access to an angle grinder, hand drill, and dremel. Do you think torque arms like yours can be made with those tools? If so, what kind of cutting discs should I be looking to get for the angle grinder and the dremel. Special bits for the hand drill?The thickness of the metal will have to cut through is 20mm thick. Any tips would be great!
Hyena wrote:Nice one mate, I told ya the HT wasn't very thirsty and that a 12 fet would suffice. But nooooo, you listen to these other stooges... J/K, it's good to have the overheads of the 18 fet, it's not working hard at all with those loads so should last for ever.
Hyena wrote:Nice KFF too! It gets all of us sooner or later, I got my first case the other night after years of playing with lipo incident free (similar story, after midnight, tired and not paying enough attention)
Hyena wrote:How'd you go for juice out there in the bush ? Recharge off your car battery or just ride as long as you could on a single charge ? That's one nice bonus with the RC chargers, running off 12v. Though it sucks supreme ass if you inadvertantly flatten your car battery out in the sticks!
sn0wchyld wrote:bah you just need a better charger! get a cellpro, they've got regenerative discharge, so you can charge up your car off your lipo! hehe!
Cheers mate, yeah i'm happy with it! Why would you go back to 20s - if you reduce the volts can you up the amps on the 12fet?sn0wchyld wrote:Great to hear the bike's running so well mate! makes me think I might go back to 20s and up the amps a bit with the 12fet. I would too, if I wasn't so keen on getting a mid drive running!
ROG130 wrote:the spokes you used are thay 13g spokes what lenght are thay on front and back and thanks for the tig tips
Timma2500 wrote:Haha don't laugh, i did flatten a battery in my old XU-1 Torana about 13yrs ago in the middle of no-where, it was fun push-starting an 1100kg car with triple 45mm Webber carbies...I didn't do it again thats for sure!
Timma2500 wrote:I guess with a quick reconfiguration, i could change the lipo from 20s 10ah to 5s 40ah and start the engine over from it!![]()
Haha, the poor old starter motor wouldn't have known what hit it!Hyena wrote:I've done that too! My missus left the doors open on her corolla when we were moving into our new house and flattened the battery. I had minimal tools with me but did have an old 4S 5ah lipo pack in my tool box (who doesn't ) The voltage was probably a touch high for the other electrics at nearly 16v but I guess it would have quickly sagged under load. I know it jumped the engine quick smart!
Quite easily. Before chopping the frame, simply assemble your crank / bottom bracket unit as per normal then using a ruler, measure out from the centre of your frame to the chain wheel with a chain on it. If it measures say 55mm to the edge of the chain, allow a few millimetres clearance and call it 50mm from the centre point of the frame. Double that and you have a max frame insert width of 100mm. You could always widen the frame further up once it clears the crank chain wheel if 100mm is not wide enough.BATFINK wrote:Im in the final stages of pulling everything together before i send my frame for the chop and welding, i was wondering how you measured for the clearance on your front chain wheel, it looks very tight?
Kepler wrote:I use BMS chargers for all my bulk charging needs. I have tried quite a few sizes including the 900W version which I use on my 125V Bomber. They work really well on LiPo and I have never had an issue with them in relation to the actual charge. I di have one 400W charger burn out a component though for no specific reason. They replaced it under warranty. I did need to pay the postage though which I could live with. All the hard case chargers are quite easy to adjust the output voltage too just incase you decide to change your cell count.
I like the 900W version as it has a voltage reading that switches to an amp reading also. Best value for money IMO. DoctorBass has an excellent thread on moding a 1200W version which is very similar in construction to the 900W version. Just be aware though that 900W is a peak figure. Expect more like 700W out of the 900W version. Still charges my 1500W/hr Bomber in around 1 1/2 hours though.
Timma2500 wrote:Haha, the poor old starter motor wouldn't have known what hit it!![]()
Has anyone tried those BMS Battery 900w chargers? Any good for charging Lipos?
Users browsing this forum: bikeelectric, chilli, Cowardlyduck, miholc and 6 guests
