thepronghorn wrote:I don't think you want a lyen sensorless controller. ...
In addition, you might also want to take a look at the P80 gearboxes made by banebots.....
Sorry to Hijack your thread Snowchyld (later post)......
.png)
.png)
bandaro wrote:looking good dude, to get it built over the holidays will mean you can't make any changes, as shipping in the new parts will take you over time...
Couple of things though, firstly regarding the motor, were you going to go the 6374-170 or the 80100-130? .....
I would love to take a squizz at your designs if I could, see how you have done it and if there are any problems I can see. If you want to pm me them/upload them that would be awesome.
So lastly, being both in OZ, if you are getting any parts from a seller that has a 13t sprocket and a 15t freewheeling sprocket in stock............
What degree are you doing at uni?
nikos7 wrote:I would definitely not recommend the Bane Bots planetary......
bandaro wrote:So any updates? If you still needed some stuff from superkids I managed to get a reply, they can't ship via usps only ups, so its 80 bucks for one pound apparently. If you get anything from a place selling #25 sprockets I'm still interested.
sn0wchyld wrote:is 9mm belt width enough? or should I go with 15mm...
so asuming ive got the numbers right, im now thinking of 2 each of these...
http://www.smallparts.com.au/store/item/ph5072150palaset12000/pulleystiming5000mmpitchhtd/
http://www.smallparts.com.au/store/item/ph5016150ffalaset06000/pulleystiming5000mmpitchhtd/
RWP wrote:You definitely need to go to 5mm pitch and 15mm wide for the first stage. 9mm wide will fail for sure. For the second stage my experience tells me that a 15mm belt will fail...sorry. But maybe if you use a relatively large diameter tensioner to get more pulley wrap you will get a way with 5mm pitch and 15 wide belts if you use a low power motor (my guess is less than 1.5K watts).
Alignment is not problem as the drive pulley has two flanges that keep the belt in line.
If you look at the power handling charts for these pulley systems you will discover that at low speeds and very high power levels (at the extreme ends of the charts) you will find that the belts fail. You need to get rotating a bit to get into a range that will be OK at the low end, and too much power will destroy the belt at the high end.
https://sdp-si.com/eStore/ has the above for $34 and $11...
Matt (recompense) has 5mm pitch - 25mm wide pulleys and belts.
Two stage reductions are a pita. Matt has some wide 5mm pulleys and fairly large tooth count pulleys along with a torque limiter and a tensioner (only to get more belt wrap around the smaller pulley) that may get your system to work in one stage. Can you go to a 13t freewheel (ACS Crossfire) (Matt has an adapter that will do this) and 48t chainring (SickBikeParts)? This system may work as a single stage.
bandaro wrote:OK, before making the box, I would recommend reading the htd bible, basically outlines the rough design requirements and how strong each belt is, what you need, etc.
The 5mm pitch, 15mm wide htd would be the way to go, possibly even wider. You could also look into pies, a company down in victoria I think, they have some similar stuff to small parts.
recumpence wrote:I wish I was close enough to talk on the phone. I can save you a lot of grief trying to figure this whole thing out. Belts and their applications can be very frustrating to say the least........
Matt
bandaro wrote:Ok I am not really familiar with what design you are going with exactly, so I'll keep to universal stuff.
Why do you need two front drive freewheels? Also you want to order more sprockets than the pic has, I take it that is for gearing options? Also, I assume you want to fit the regular 3 sprockets on the cranks hence you are getting them, plus an extra for the motor drive. 3 sprockets is great, but make sure they will align well enough with the rear cassette, so you can actually use all 3. You could probably get the sprockets off an old bike, they are large so do not wear too fast, then if you cut some holes in the White Industries (un-toothed) freewheel they will bolt onto it, but you need longer bolts, so you may be better off getting them from a hardware store rather than online, to make sure they are long enough.
Check what speeds you will be geared for, because your reduction sounds very low if using a regular size front sprocket, even at 24 volts it will be too fast to peddle with, and there is no point gearing it for speeds you will never and could never reach. 24 volts will give the cranks over 200 rpm, now imagine the bike speed if you pedalled that fast, sprints top at around 120rpm, onroad commuting at 80 ish.
If I have missed anything let me know, hate to have overlooked something basic and give bad advice.
Timma2500 wrote:Good decision getting the PLE80 dude! What ratio and input/output shaft sizes did you end up getting?
Can't wait to see how the controllers work out, i suspect using them with a mid-drive should give them a reasonably easy run compared to a single speed setup
Hopefully you won't need the spare![]()
Re the RC CA, how do you get ahold of these, just email Justin? How much are they Sn0wy? I'd like to get one for my 80-100 / HV140 build.
Can't wait to see this come together![]()
Paul
Thud wrote:Both will barley notice an 80-100
219 chain is typicly a better grade than #35 (but you can get HQ #35)..finding 219 drive sprockets is the trick. (be ready to do some fabbing)
I lean toward #35 for low cost accross the board...& sprocket availability. but it's horses for courses.
Users browsing this forum: Miles and 7 guests
