Idontwanttopedal wrote:On that site they are 130. I want to pedal with my 1200 cyclone and the crank freewheel I got uses a 104bcd not a 130 if there a way to use a 130bcd. At mow I'm using a 48t but crank turns at about 112 rpm with that
Drunkskunk wrote:Idontwanttopedal wrote:You're going to be just about out of luck getting a 60+ ring in 104bcd. You'll need an adaptor plate. I've seen 130 to 104 before, but can't remember where. although you can make one fairly easily. a 6" saw blade, a hole saw, a drill, and some patience is all you need to make an adaptor plate.
Idontwanttopedal wrote:Seen one on here he got a 64t made but the sit he used is down see if I can get one made that way I will just unbolt the 48t and the fit 64t add new chain
Idontwanttopedal wrote:I have a extra wide bb crank which widened pedals to miss back off motor and moves chainring out and it was set up so the inner tWo chainrings are in line to rear and outter is in line for motor.
Users browsing this forum: No registered users and 12 guests
