slats wrote:Yes, thanks guys, that makes sense. 3/8" chain would fit the 3/8" freewheel and OK on a 1/8th motor sprocket.
Cheers,
Steve
3/16" chain, not 3/8".
Keep us informed on how well it works!
Cheers,
Steve
slats wrote:Fractions huh. I should have listened more in school. but you're saying that a 3/16" chain would be fine on the 1/8" sprocket without slipping or anything.
I just bought on ebay from patsbelair for us$32 the LONG YIH Co. 7 Speed Freewheel 11-30t ,11-32t, 11-34t .
I'm running the ezip on ping lifepo4s . I bought 2 15AH for US$ 670 and put them in the curry boxes. Ping was really helpful with the wiring and advice with quite a few emails and pics going back and forth. my ride to work is 12 Km along a dedicated bike track following a creek and I've even started peddling a bit to get in the spirit with the lycra mob. I kept it to 24 volts, i was a bit nervous about cooking the motor.
Anyway, if the parts arrive, i'll start putting it together at easter .... if not then it will be July.
It would be nice to go a bit faster. drkangel, are you on 36v with your ezip and these mods?
Steve
vansingela wrote:I just purchased a 2008 EZip, but I am a little disappointed with the top speed -- I am looking at doing this upgrade. Is it advised to upgrade the motor as well, or is the southpaw enough?
DrkAngel wrote:ACS Southpaw 1/2 x 1/8" 16T freewheel
Alternate source - with International shipping:
Outside Outfitters
RyanTo wrote:Will this 7 speed freewheel work(I have the skyline but I'm sure it's the same)? It talks about a 3/32 chain compatibility..
Epoch 11-28T 7 speed freewheel
If not is there anywhere else to get a 11-xx sprocket for more peddling top speed? The link someone previously posted seems to be out of date.
RyanTo wrote:Do I need the DNP removal tool or is that something I could pick up locally? I'd rather get the one off eBay but it doesn't look like they have the tool..
Two possible solutions:
1. Seal all joints, I used duct tape, to keep grinding residue out of freewheel. Grind notches down, about half way. Remove tape and install.
2.(Recommended method!) Insert a 3/8" standard washer as a spacer, clearance is very close, 1/16" might be enough, 1/8" thicker than necessary.
anarce wrote:Great post! I ordered the 16T freewheel and I'm getting ready to mod my eZip Trailz. Unfortunately I couldn't find the chain link kit at the local bike shop and had to order one online, so I'm waiting for parts again. I'll try to take some pictures along the way to add to this thread.
I'm a little confused by this part of your instructions:Two possible solutions:
Do you mean 3/16" thick washer? 3/8" seems like a lot, and if I'm following you, you say that it should be 1/16" plus another 1/8" for safety, so 3/16" total. I figure once I start putting it together I can pick up a handful of different washers at Home Depot and see what fits, but I wanted to confirm.
anarce wrote:OK, I successfully completed this mod last night! Thank you for all the great info, DrkAngel! I rode to work this morning and was running at 18-19 mph on the flats with just the motor.
DrkAngel wrote:If you spin the removed, OEM freewheel, does it still feel like it is filled with tar.
Does your motor have the "C" insignia, or the inverted triangle?
Check your sprockets, are they still nicely aligned?
Shifts easily?
(2008 is nice but 2009 shifter is almost painfully stiff)
DrkAngel wrote:Still waiting on my machine shop buddy to finish my 11T motor drive sprocket.
Searched till I found a possible 12T item!
Users browsing this forum: Bing [Bot], cware05, OCMike, pchen92 and 16 guests
