Thin Gap motor
Thin Gap motor
Postby salty9 » Thu Jun 28, 2012 5:59 pm
salty9
Re: Thin Gap motor
Postby flathill » Thu Jun 28, 2012 11:06 pm
Forget about it too expensive
Coreless wire only (cast into kapton or teonex)
No core no eddy currents
Wiley''s no limit liquor
flathill
Re: Thin Gap motor
Postby circuit » Fri Jun 29, 2012 9:38 am
Again: whats the inductance and what controller is suggested as compatible one?
Visit my blog, check out personal projects: ebike v2 | e-scooter | ebike v3
Also visit company's website for a High-end BMS.
Notice: whatever I say here on forums is my own opinion and may not represent my company's position. However, no commercial use of my post content is allowed.
circuit
Re: Thin Gap motor
Postby Kingfish » Fri Jun 29, 2012 10:41 am
circuit wrote:Again: whats the inductance and what controller is suggested as compatible one?
Controller: Suggest Castle or other similar RC unit.
The motor is designed for ducted fans, ultralight copters, and hovercraft. Not much application for ebikes because it rotates too fast; can’t use it as a hub motor.
It is however an interesting concept.
~KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9653 miles-to-date, 4163 as 2WD.
Kingfish
1.21 GW
1.21 GW
Re: Thin Gap motor
Postby circuit » Fri Jun 29, 2012 10:45 am
Haha, trololol.
Don't think so, unless you like to see what kind of smoke it is made of.
circuit
Re: Thin Gap motor
Postby Kingfish » Fri Jun 29, 2012 11:50 am
Haha, trololol.
Right. Any child can sling mud. So what do you suggest Einstein?
Kingfish
1.21 GW
1.21 GW
Re: Thin Gap motor
Postby liveforphysics » Fri Jun 29, 2012 12:37 pm
The motors have such low inductance, they actually make external inductor sets to go in series with each phase wire just to try to make possible to control.
This has a double wammy against finding a controller for it. Super high pole count means electrical RPM is going to be higher than a Sevcon/Curtis/Kelly can achieve to get it into it's power band, and super low inductance means no RC controller would be capable of any degree of phase current control and will turn into smoke.
It would likely require something along the lines of the KERS motor controllers to use to full potential. Similar to the solid slot motors, which are absolutely rocking motors, but mostly useless because the only things that can run them somewhat effectively cost 10x more than the motor itself.
liveforphysics
Re: Thin Gap motor
Postby circuit » Fri Jun 29, 2012 2:55 pm
Kingfish wrote:
circuit wrote:
Kingfish wrote:Controller: Suggest Castle or other similar RC unit.
Haha, trololol.
I did not suggest anything because I have not heard about suitable controller yet. This is why I ask what they suggest users should run. It looks all good until the inductance part.
circuit
Return to Motor Technology
Users browsing this forum: Bing [Bot] and 4 guests
