bzhwindtalker wrote:I love your pics! Nice bike too, looks sharp
dodjob wrote:I did exactly the same mounting for the CA. that's IMHO the slickest way to mount itVery nice build!!!
GMUseless wrote:Thanks man. I love these Kona bikes. Your build looks good as well.
The Coilair Supreme was only made a few years, but the Coilair line was marketed as a lighter weight version of the Stinky...they billed it as a Freeride rig that you could still climb with. They were going for a bike that didn't need shuttling, but could still handle some downhill. so, the main difference between the two are weight savings things like a single crown Bomber fork, Fox air shock, lighter components, etc.
GMUseless wrote:For the motors, you might have seen me mentioning a 9C in other threads. But I got the 9c 2810 for my Yuba Mundo Cargo bike, my third build. I'm running a bit behind on these threads! My first build used an Ezee kit from eBikes.ca, which later got moved to the wifes bike. I think for offroad you got it right. The 2810, even a 2812, is a good match. Allthough, if I ever switch this build up to a complete off-road bike, I might try some type of Mid drive..
GMUseless wrote:By the way, my 9c 2810 isn't really more quiet than my MAC 6T. On the 9C I get this loud rumbling that peaks a certain RPM and then quietens back down...only happens when accelerating under high load. Do you get that on your build? But, my 9C is on a 75 lb rig, with my 200lb ass, and two 50 lb kids on the back, and sometimes a load of groceries. I'm running 18s on that one. How many amps are you running?
GMUseless wrote:The DVD cases work well. They actually don't bounce at all. What I like about those DVD car cases is there's tie down loops at every corner...so the bags are pulled tightly to the frame with releasble zip ties. Tied to the frame, they get the benefit of both front and rear suspension. I pack out all void space with bubble wrap, so everything in there is nice and tight. And the aluminum plates on the bottom and exterior side keey things semi rigid and protected from punctures. The bags still just allow and inch of clearance for my knees when pedaling. With your triple crown fork, the upper stanchions will need more room to turn, so that might limit that application for you. Still, if you can figure it out, I think that's the next best place if you don't have front triangle room.
Wizzbit wrote:Great build, I had the same problem with the disk screws being too long,
filing them worked.
But the disk brake caliper was too fat and rubbing on the hub motor,
I see yours are just about right, do you know of any hydra brakes that will fit?
motomech wrote:GMUseless-You can salvage that 6s brick, especially if the bad cell is on the end[they usually are I think].
Remove the pair of cells that contains the bad one, but leave the board on top. Then solder the primary lead at the board to the end/start of your new 4S brick.
Buy a Turnigy 2S 20C 5Ah for $15 and tape the two together. Won't look as sweet, but it works.
Ck out the thread about recycling cells in the Batt. section.
Sacman wrote:I've used Avid BB7's on my last 3 commuter builds too and I've found another trick with them.
Notice that there is a difference in stack heights of the 2 spherical washers groups (on each side of
the bracket). One group has a stack height shorter than the other. You can simply swap the location
of the 2 washer groups if that gains you a better position for your caliper.
Users browsing this forum: Alan B, Chalo, zombiess and 14 guests
