And yes, for the mercy of Dog I will be insulating the terminations!
Sounds goodjonescg wrote:I have the irons on for about 10-12 seconds, and most of the heat stays in the copper block while the solder melts. The cells will only really get the last bit of heat as the solder on the tabs gets molten, and this is only quite brief. As the whole lot sinks down I take the irons off and dab it with a sponge and cold water. I always feel the cells afterwards to see if the got hot, but nothing does. The tops of the cells get a bit warm, but within about 30 seconds they are cold again.
I would stay away from PVC electrical tape because it leaves leaves a horrible mess. Kapton tape might be better or even sheets of thin polycarb / lexan glued over the bars on each brick or group of bricks and then you could wrap the bolted connections in self amalgamating tape.jonescg wrote:And yes, for the mercy of Dog I will be insulating the terminations!I don't know what would be ideal, maybe Kapton tape or just a few rounds of PVC tape? I want the balance leads to stay out of the way as best I can manage.
Rodney64 wrote:Looking good Chris but I would be feeling better if I had a frame to put it in. How did the shed handle to storm. 150 high is that to the top of the terminations.
jonescg wrote:Nice! Those HP power supplies sound like turbines eh?...
Hyena wrote:Looking good Chris. Any plans to heatshrink them or add some other form of external protection ? Or are you leaving that up to the end user ?
I've been looking around for some fairly sizable headshink (HK only sell up to 100mm) but haven't had much luck.
You guys do know about shorting the pins (or putting a resistor in there) to drop the fan speed on those server PSUs right ? If you're running 2 in series on the icharger I doubt you're taxing them so there's minimal chance of them overheating.
Users browsing this forum: Bing [Bot] and 5 guests
