Noob here with a legit question about disc brakes
Postby mediumrare » Sun Jul 29, 2012 12:34 pm
Hey everyone, newbie here, first post and first build.
I'm going with a kit from e-bikekit.com. I live in PA near their shop and they're good guys. Front drive, 36V Lithium.
The bike is a Surly Rat Ride 1x1, disc only, with the giant Large Marge Rims and 3.0 knobbies, Alfine 8 in the rear. It's like a mini-Pugsley snow bike.
Question is: I need to find a disc setup for the front that has a very narrow caliper. I need 18mm of space between the rotor and electric hub. I can't seem to find a definitive answer, although I've see people running front hubs with discs on fat bikes before.
24" Large Marge with 3.0 Duro Razorbacks
mediumrare
10 µW
10 µW
Re: Noob here with a legit question about disc brakes
Postby fractal » Mon Jul 30, 2012 10:44 am
Try Magura Gustav. I know Madrhino uses them because of their thin profile. I think they are the thinnest ones available.
Norco A-line DH bike with :
«cromotor/hubzilla» from http://www.greyborg.com/
24s 3p Lipo (100v, 15ah)
Methods LVC/HVC cell level protection system http://www.methtek.com
24 fet infineon controller made by Lyen, heavily moded by Methods
8awg harness by Icecube57
17 inch moped rims with Michelin Gazelle tires by John Rob Holmes http://www.holmeshobbies.com
other stuff http://www.ebikes.ca
details
http://endless-sphere.com/forums/viewtopic.php?f=6&t=31850
fractal
Postby MattyCiii » Mon Jul 30, 2012 11:02 am
I have to agree Fractal. My Gustav's need like 10-12 mm between the rotor and the wheel (in my case, the chainring for the left side electric drive... see my A-Line build thread.
Sadly the Gustav's have been out of production about a year. You can still find new pads for them, and find used Gustav's at pinkbike and ebay. I bought 2 sets back in April, took awhile & lots of effort to buy.
If you do go with the Gustavs, note that they originally shipped with a bunch of mounting adapters. You can still find the pdf showing all the options if you search. These things went for $50 and above originally, and are much harder to find than the brakes only.
If you're buying a front brake only, expect to pay about $150 for tthe brake/line/lever and mount, un used but very good condition. If you're lucky the brake you find for sale has the mount you need. If not I'd walk away, nobody wants to break a set by selling only the mount.
Great brake, lots of stopping power and uniquely meets the need of a narrow inside profile. It's a shame Magura stopped making them.
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Postby teklektik » Mon Jul 30, 2012 11:56 am
If you want to go mechanical, you might look at Avid BB7s. I use a 185mm BB7 and BMC motor up front. The distance between the inside of the rotor to the the hub face is 11/16" or 17.5mm. The BB7 fits with about 1/8" of extra clearance (pic + description here) - just enough to slip in a tool to adjust the inner knob.
I'm very happy with the BB7 - it's about as much brake as my fork can safely handle and is a breeze to adjust. Just thought I'd throw out the option - without going down the whole hydraulic vs mechanical discussion path :) .
teklektik
Postby Sacman » Mon Jul 30, 2012 2:23 pm
Justin at ebikes.ca sells an Ahlonga low profile mechanical disc brake caliper for $30. It's supposed to be thin enough to fit fine between the front forks and a 9C hubmotor. Look in the Store - Parts - Brakes section.
Also, you can remove 1mm or 2mm of material from your bike frame's disc caliper mounts or the caliper's mounting brackets (either or both), in order to increase distance between your disc and the side covers to your hubmotor. Local bike shops do this all the time and even have the special tool to remove the material exactly perpendicular to the mounting holes. You can bring your bike to them and have it done if you're not comfortable doing it yourself.
Sacman
Postby teklektik » Mon Jul 30, 2012 3:13 pm
Sacman wrote:Also, you can remove 1mm or 2mm of material from your bike frame's disc caliper mounts or the caliper's mounting brackets (either or both), in order to increase distance between your disc and the side covers to your hubmotor. Local bike shops do this all the time and even have the special tool to remove the material exactly perpendicular to the mounting holes. You can bring your bike to them and have it done if you're not comfortable doing it yourself.
Gee - that's good to know - clever tool. So I guess this calls for a spacer of equivalent thickness on the motor rotor mount. Coincidentally, ebikes.ca sells rotor spacers, although you can make one from an old rotor.
teklektik
Postby d8veh » Mon Jul 30, 2012 6:47 pm
With many motors you can solve the problem with a larger disk, which usually brings the caliper further away from the motor. Normally 180mm is enough. You only need a new disk and a new caliper mount.
All my present bikes that I built can be seen here: http://www.pedelecs.co.uk/forum/members/d8veh.html
d8veh
Postby Russell » Mon Jul 30, 2012 7:04 pm
I use Radius brand on both of my E-bikes, they are the narrowest I've found. Tha calipers also use easy to find Shimano pads plus the alignment hardware is similar to Avid.
Radius
Radius caliper
Avid BB7
-R
Jeep Comanche 29er w/Bafang QSWXH, 41 lbs + 9 to 14 lb rear trunk bag w/tools+battery, 29 mph w/12S LiPo.
Mongoose Hatchet dual suspension w/Bafang BPM
Past Bikes: Raleigh 700C, Kona Smoke 2-9
Russell
Postby jateureka » Mon Jul 30, 2012 8:20 pm
Is there much difference in stopping power between the Radius and Avid BB7?
Bafang; Mac; Ezee; Easy2Ride; PowerPed; Nope; Condor; Aprilia; eLation V2; Razor
jateureka
Postby Russell » Mon Jul 30, 2012 8:48 pm
jateureka wrote:Is there much difference in stopping power between the Radius and Avid BB7?
The BB7's are supposed to be the best mechanical brakes available however I never mounted my set so I can't say. The Radius calipers do use about the same size pads as the BB7's.
I don't know what your experience is with them is but mechanical disc brakes can be a disappointment for someone who hasn't used them before. It's not that they lack stopping power, it's just they require far more pressure due to less leverage than rim brakes. People often say "I can't lock up my wheel like I did with my rim brakes", which is true, but you really don't want to lock up your wheels when braking and discs offer better modulation. Also once you learn to really SQUEEZE the levers the stopping power of discs is substantial.
-R
Russell
Postby teklektik » Mon Jul 30, 2012 9:38 pm
d8veh wrote:With many motors you can solve the problem with a larger disk, which usually brings the caliper further away from the motor. Normally 180mm is enough. You only need a new disk and a new caliper mount.
This is an interesting point. In the pic I mentioned above, the adjuster part of the BB7 is actually hanging over the BMC motor with a 185mm rotor. In the picture below, the little silver thingie actually screws in and out as you turn the adjuster knob and is part of the inner pad adjuster screw (it's protuding with new pads, and withdraws with thinner used pads). If you have a larger diameter motor than the little BMC, the dimension in this photo is a more accurate representation than I gave above since it includes this adjuster component. (My Bad...).
teklektik
Postby mediumrare » Tue Jul 31, 2012 9:54 pm
That's a good point.
"No man is a hero to his driver."
mediumrare
10 µW
10 µW
Postby mediumrare » Tue Jul 31, 2012 10:05 pm
Sacman wrote:Justin at ebikes.ca sells an Ahlonga low profile mechanical disc brake caliper for $30. It's supposed to be thin enough to fit fine between the front forks and a 9C hubmotor. Look in the Store - Parts - Brakes section.
Good stuff, thanks!
mediumrare
10 µW
10 µW
Postby Punx0r » Wed Aug 01, 2012 8:47 am
Or use washers to space the disc away from the motor and then calliper away from the frame?
Punx0r
Postby spinningmagnets » Wed Aug 01, 2012 9:11 am
$7 from ebikes.ca, easily sanded to make them thinner. Place sandpaper on a flat surface and move spacer in a "figure-8" motion.
http://ebikes.ca/store/store_connectors.php
spinningmagnets
10 GW
10 GW
Postby scriewy » Sat Sep 01, 2012 2:00 pm
i checked few disk brake threads and Just to be clear, disc rotors are interchangeable between differend caliper brands if of same bolt patern and size.
for different rotor sizes we have different caliper adapter.
front rear calipers are usually the same, just the adapters different because of different angle of frame caliper mounts.
are the caliper adapters interchangeable between different brands for same size of disc ?
can caliper adapters be bought alone or usually just in brake kits ?
how to choose pad material, i noticed there are 3 types organic/metalic/forgot the 3rd one.
edit to add:
some time cleared to wonder around mtbr.com found out stuff.
caliper adapters can be bought alone, usually 10$ and up.
caliper adapters are not interchangeable between brands, they dont take that into accaunt, if your super lucky it'll fit
200mm & 203mm are actualy different sizes, not a local tradition from country to country to name differently, while 203 being the common size, so get 203 calipers.
it's a pitty i wont stay to see the world crumble, u jedi Scum
clyte 405,
went through battle, bloody resurected Dewalts 4x28v 2s2p usable 2.7ah, 52v drops to 44v at 54kmh
78v 2ah Vdrop to 58v at max 66kmh.
72kg rider + 23kg bike.
keywin 20a 30-70v mod to 6 4110 as methods advised for noobs, shunted 38a
clyte 24-72v 40a mod 4310 to 4110, shunted to 77a
17.5.11 - 5000km
at 78v 4ah 72.7kmh Vdrop to 68v
10.11 - 82.1kmh
30.8.12-17000km
a place for lasers as ES is for e-vehicles - laserpointerforums.com
scriewy
Return to E-Bike Technical
Users browsing this forum: kelvinscott76 and 11 guests
