Electricals caracteristics of the X5305 hub motor HERE
Postby Doctorbass » Fri May 23, 2008 12:00 am
As you know me, i am curious and i decided to measure some parameter of my X5 motor.
here they are:
The resistance between two phase wires: (tested at 10A DC with V measured directly on the winding wires connections (4 wires sensing measurement for better accuracy)
- measured voltage is 1.41V so R= 1.42V/10.0A= 0,142 ohms
so the max current that motor should draw between two phases is: 7.04A/Volt in DC operation.
The voltage loss in the Anderson Powerpole Y-B-G connectors:(tested at 10A DC with V measured directly on the rear connections blade of both male and female of the powerpole connector (4 wires sensing measurement for better accuracy)
- measured V loss at 10.0A = 10.4mV and R= 1.004 mohm... very low!!! :D
The measured winding wire diameter: 0,0285" dia
= AWG 21 !! :? but there are 4 parallels in a 5305...
and that's 12.77mohms per ft
and 4 parallels AWG 21 are equal to one AWG 15 wire... = 3.19 mohms per ft
so we can conclude that the total winding lenght between two phases is
142mohm / 3.19 =44.5 ft and one phase = 22.2 ft wire long.
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Re: Electricals caracteristics of the X5305 hub motor HERE
Postby pwbset » Fri May 23, 2008 12:24 am
So... like... I've been thinking of getting a x5 for my hillclimb project ( http://justev.info/route.jpg ). Can I conclude from those math/equations/research that it kicks ass or not? :?:
:mrgreen:
pwbset
Postby Doctorbass » Fri May 23, 2008 9:17 am
yes, it kick ass for sure! about torque!
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby tomv » Fri May 23, 2008 11:26 am
I'm really happy to see somebody measured Anderson powerpole resistance! Is it 45A version? Their datasheets actually claim 0.5mOhm resistance. I suspect that varies a lot. If some dirt/oxidation/oil gets into the contact it would deteriorate more...
tomv
Postby ZapPat » Thu Feb 19, 2009 3:49 pm
Good to have those resistance measurements, Doc! Do you happen to also know the inductance of your X5?
I'm curious about this since the resistance+inductance combination define the electrical time constant of the motor's windings. In other words it describes the speed at which the current changes through time in the coils + iron laminations. Before your post above, I was assuming about 0.2ohms and 200uH for an X5 type motor, which yields a time constant of 1 millisecond. I've googled the net and have not managed to get more than hints about a real X5's inductance...
All my ebikes have gone up in flames (with my whole house) --> Many lessons learned (like that insurance companies can be cold hearted a$$holes; and to read and understand your contract before your house burns down...)
ZapPat
Postby Doctorbass » Thu Feb 19, 2009 5:00 pm
ZapPat wrote:Good to have those resistance measurements, Doc! Do you happen to also know the inductance of your X5?
i'll measure that next time i'll open it .. Ex: when i'll install the contactor :twisted:
About that.. I remember that the Elica (japaneese fast electric 8 wheel car), they had problem with the motor over 9 or 10krpm.. they mooded their controller to compensate one of the parameter and that solved the problem
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby ZapPat » Sun Feb 22, 2009 10:46 am
Doctorbass wrote:i'll measure that next time i'll open it .. Ex: when i'll install the contactor :twisted:
Thanks Doc!
Doctorbass wrote:About that.. I remember that the Elica (japaneese fast electric 8 wheel car), they had problem with the motor over 9 or 10krpm.. they mooded their controller to compensate one of the parameter and that solved the problem
Doc
Maybe they raised the switching frequency of the controller, because at higher commutation rates the lower PWM switching frequencies can get too close to the commutation frequency.
ZapPat
Postby kZs0lt » Mon Feb 23, 2009 2:24 am
Doctorbass wrote:The measured winding wire diameter: 0,0285" dia
0.0285 dia, 4 strands, 22.2 ft long, x3 phases, with 8.9g/cm3, that would make for only about 300g (0.66lbs) of copper mass, if I made the calculations right. Is that true?
BMC v1 250w (nylon geared)
12 FET programmable Infineon controller with 4110s (running on 20A)
18s2p Konion 26650s (66v, 4.4Ah)
Max. speed 54km/h(34mph) no assist on flat
kZs0lt
Postby Doctorbass » Mon Feb 23, 2009 10:09 am
If the winding is made of pure cooper, that should be true.
What do you try to determine exactly with the winding mass?
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby cassschr1 » Tue Mar 12, 2013 2:21 pm
I just unwound 3 phases of a 5305 and they measure about 50' each. Give or take a foot. Three 4 wire groups. Whats the thinking on 22' for a phase lenght?
cassschr1
Postby Doctorbass » Tue Mar 12, 2013 11:39 pm
cassschr1 wrote:I just unwound 3 phases of a 5305 and they measure about 50' each. Give or take a foot. Three 4 wire groups. Whats the thinking on 22' for a phase lenght?
Hi
My calculations was made using the resisatance parameter of the wire winding according to industrial chart. But i might not have to divide by two like i did to acheive 22ft and the calculated lenght would have been 44' wich is closer.. maybe the error between the calculated lenght and your measured lengh is because of the resistance tolerance :wink:
BTW Thanks for having unwound your motor to confirm that :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby cassschr1 » Wed Mar 13, 2013 10:19 am
The weight of the copper is 1# 11 oz. Now keep in mind this is after it went thru the oven, that is no varnish on wire 20 guage
I will weigh the new copper later with varnish! and it about 55' that I cut new length's to.
Last edited by cassschr1 on Wed Mar 13, 2013 10:22 am, edited 1 time in total. View post history.
cassschr1
Postby cassschr1 » Mon Mar 18, 2013 12:23 am
Each phase weighs 9.2oz/260gm. 51.5' length NO VARNISH ON WIRE this is a 5305 4 strands of 20g per phase
cassschr1
Postby Doctorbass » Mon Mar 18, 2013 9:01 am
Thnaks for these measurement. We now better know the 5305!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Return to E-Bike Technical
Users browsing this forum: No registered users and 12 guests
