Tonight I temporarily modified my GuaLiLai switching power supply, and got it to output over 67 volts. I was afraid to go higher during my tests, for several reasons.
The output capacitors C3, C4, & C5 are only 50V, so at 67V I was well above their maximum. I quickly made my tests and took my pictures. I don't have any high voltage, high capacitance replacements on hand.
DigiKey has 63V, 80V, and 100V electrolytic capacitors. I need nearly 64V to charge 15S eMoli cells, so I will need at least 80V capacitors. Electrolytic capacitor voltages are often chosen 50% over the expected voltage. 100V parts would be better, but I am unsure if they would fit inside the aluminum box. Maybe I can lower the capacitance to get capacitors that will fit; the originals are 2200uF but 1800uF and 1500uF are available at 100V. I don't need lots of output filtering for charging batteries, though the switcher's feedback circuit might complain if I go too low.
Also, I could smell something burning; carefully touching a wet cotton swab on various parts indicated R3 was hot enough to evaporate water. R3 loads the power supply when there is no output connected. This metal-oxide resistor is larger than the 1W size from Radio Shack; the body is about 15mm long which matches a 2W resistor. 48V^2 /1K5 = 1.5W is within range; 64V^2 / 1K5 = 2.7W is not.
ZD1 is a pair of series connected zener diodes. If you look at the board from the traces side, ZD1 straddles surface-mount R6. With the diodes pulled from the circuit board, I connected a 18K resistor in series with each, one at a time, with a 36V power supply, anode to negative and cathode to positive. The resistor was to limit the current to the milliamp range, so the zeners wouldn't blow up. I measured 27V across each one, so in series they provide a 54V zener voltage.
This would explain why people had trouble adjusting the voltage above 55V. 55V^2 / 1K5 = 2W, equal to R3's power rating.
DigiKey has 51, 56, 58, 60, 62, 68V, and 75V zener diodes. I will probably chose a single 68V since I don't want to connect several diodes in series. To get the odd-ball 54V, the designers had to use 2 series zener diodes. For my brief tests, I added a 12V zener diode to the string, for a total of 27 + 27 + 12 = 66V.
I noticed that above 67V, the burning-resistor voltage, that the fan would come on even though the power diodes and transistors were cold. I can't explain this, but it might not affect me since I don't need that much voltage.
Finally, I replaced R4, the 2701 surface mount resistor on the bottom of the board. I tack-soldered a 1K8 resistor in place of the 2K7. This change, along with adding a zener to the ZD1 string, is the one that allowed the power supply to output more volts -- but only for moments because it was unsafe!
VR3, the coarse voltage adjustment, is connected as a rheostat; the wiper and one end are shorted on the board. The other end is in series with R4, the 2701 fixed resistor.
Before making changes, I turned the brass screw on VR3 until the output voltage was as high as it would go. Then I desoldered and measured VR3, its overall resistance was 500 ohms. I also measured the resistance across the non-shorted terminals; it was a short circuit. This meant I needed to lower the series combination of R4 and VR3 to raise the output. This matches my experience with another switcher I've modified.
I chose 1K8 because I wanted to raise the voltage by at least 1.33 or 33%. 2K7 x 48V/64V ~ 2K ohms; but 1K8 would allow me to go a bit higher; about 50% = 48V x 2K7/1K8 = 72V. This extra range allows me to trim above and below the 64V spot that I want.
So -- to make this change correctly so it is safe, I need to:
1. Replace C3, C4, and C5 with higher voltage electrolytic capacitors. 80V is minimum, 100V would be better. I could lower the capacitance from 2200 uF to help fit the replacements in the case. 1800uF and 1500uF are available.
2. Replace R3 with both a higher value and higher wattage resistor. Resistance will be 2K = 1K5 x 64V/48V. Wattage will be 3W; 72V^2 / 2K = 2.6W which is within range.
3. Replace the ZD1 zener diode pair. I will choose a 68V zener to avoid multiple diodes and keep the supply neat looking. I will use a 1W size, even though it is larger than the original two, because they are cheaper and a larger diode won't hurt anything.
4. Replace R4; 2K7 (2700 ohms) becomes 1K8 (1800 ohms). For my tests I used a 1/4W resistor because that's what I happened to have. A 1/10W resistor radial-lead resistor would fit better; or I could scavenge a surface-mount resistor from some discarded electronics I have in my junk box. Power rating isn't critical here since the resistor is in the feedback circuitry which is low-power.
Have I missed anything? Helpful comments would be appreciated.
- GuaLiLai PS modded for 15S eMoli cells ~63.75V
- (46.53 KiB) Downloaded 1368 times
- The temporary changes I made, please read my post for details.
- GuoLiLai005.jpg (49.52 KiB) Viewed 2965 times
