1986 VFR700 conversion
Re: So here's my 1986 VFR700 conversion
Postby frodus » Mon Jul 28, 2008 8:25 pm
got my 60 tooth sprocket specialists rear sprocket in today... damn that thing looks nice. Titan tough coating leaves it with a nice black/gunmetal color.
I'm installing it Thursday. Can't wait. more video to follow.
Travis Gintz
Electro Motive Force, LLC.
EV Consulting and Sales
frodus
Postby frodus » Fri Aug 08, 2008 3:58 pm
installed the rear sprocket and its definately peppier. Problem now is my batteries are sagging and the controller is starting to throttle back. I'm riding the battery power curve. I've decided to upgrade to some stiffer batteries, some 28Ah AGM Panasonics that someone local has for sale. Going to try and get one for test tomorrow and see how they are. They're brand new, but have been in storage for a little while, but maintained (trickled one at a time).
I also got her insured through Progressive for ~130 a year.
Going to try and get an aux battery and get the lights working. She'll be legal next week when I register it at the DMV.
Travis Gintz
frodus
Re: 1986 VFR700 conversion
Postby frodus » Mon Aug 25, 2008 1:08 pm
So, its been a while since I've posted. Sorry about that. Loni took a little break from the bike. He's been vacationing, and I've been doing research and testing on the nights I go to Synkromotive, so not much has happened with the bike.
As I posted before, I found a guy locally that had a ton (almost literally) of 28Ah 12V batteries from panasonic. I bought 2 (to replace in a go-kart we had at the shop), and tested one of them. I ran 2 tests. One test was at 50A another was 100A. It performed well and passed load testing. After looking at the Logged data, we figured the values jumped around too much, so I hooked a Dataq data logger to the battery and logged voltage vs time at 50A. Here's the curve.
After testing the one battery, Ives and I ran some power calcs, and at 100A with a 120V (115V under sag) it'd give me over 11,500W instantanious, lots more than what I was getting (60V sag and just under 150A, for about 9,000W. It matched the discharge curve from the battery datasheet (click the picture of the battery). We're going to install 7 of these batteries (84V) on Tuesday night for a quick test. These will fit in with little or no modification to the existing frame (we designed it to be compatible with this size of batteries for an upgrade when we fabricated it in March). Once we do a quick test or two, we can start to fabricate another battery tray.
I also played around with an optical sensor that I've got hooked into the Tach input on the controller. I tried to get it to calibrate, but its not logging correctly. I'll have to debug that later.
For a gauge display, I'm tossing ideas around and considering an Asus EEE 7inch with XP on it. Fairly low cost, and it'd do all my data logging, display, etc. Plus, it will run our software with no changes. Just hook up a USB cable, and voila. Just need to make a waterproof case for it, and some sort of one-button interface for toggling pages. Once my BMS is done (needs programming) we can display all the battery levels, log data for discharging and charging, and display all the controller stats.
Still need to get some time off work to go to the DMV to get it registered and to take the written test for my motorcycle endorsement so I can get a permit. The permit allows me to ride with someone within eyesight and only drive during daylight hours. Then I can get some seat time.
Travis Gintz
frodus
Postby frodus » Mon Oct 05, 2009 12:37 pm
So, its been a REALLY long time since I've posted pictures of my project.... It's been a busy year. Worked with the Motoczysz team for a while, started consulting, imported 25k of batteries and then joined forces with EVComponents.....
Now I THINK I finally have most of the parts I need to finish the bike. I don't have the Synkromotive controller yet due to delays in production, but if its a problem, I'll just build a Zilla 1k LV at EVC. I don't have a BMS either, but I'm working with Elithion on some BMS stuff for us moto guys, and I'll be testing his prototype. Right now I'm planning on the Lithiumate system with Cylindrical cell boards.
So what changed on my bike? Well, almost everything is changing. I decided to make the leap from Lead to Lithium before even installing the Panasonic SLA's. It wasn't enough of a gain, and would be much better long term to go Lifepo4. The fairings are no longer the stock plastic, they're all fiberglass.... Including the gas tank.
So whats going in the bike?:
  • 192qty 10Ah 38120S Headway cells in 32s6p for 102V 60Ah
  • Fiberglass one-piece tail fairing, Solo seat cowl, front fender, race upper fairing, lower side fairings, inner fairings and gas tank.
  • taller windscreen to help cut back on aero drag a little
  • K99-4003 72V 6.7" motor from Advanced DC
  • delta-q 1000W 96V charger setup for 32 cells (116.8V cutoff)
  • Vicor 100Vin 12Vout 200W DC-DC converter (works down to like 80Vinput)
  • Inertia switch in case of a wreck
  • EV200 contactor
  • LSL MIG Dual headlights
  • Sprocket Specialists 60tooth anodized rear sprocket
  • Bar mounts so I can use a sportbike/superbike style handlebar
Stuff I don't have yet:
  • Controller (Want to use Synkromotive, might have to get a Zilla)
  • BMS (I'll likely use a full Elithion Lithiumate BMS)
Stuff I need to do:
  • Fabricate new motor mount (the old one could be improved and simplified)
  • Fabricate a battery box for the Headway cells
  • Fabricate headlight mount and cut holes into upper fairing
  • fabricate charger mount
  • mount controller/contactor/DC-DC etc inside gas tank
  • rebuild front forks (they're leaking)
  • replace wheel bearings (since its easier now than later)
  • Get fairings sanded and painted
  • get wheels/subframe/gauge mounts/panel mounts powdercoated (this could wait until after bike is done)
  • Talk with Elithion about their BMS and see if I can still integrate an LCD
[url="http://www.evfr.net/coppermine/thumbnails.php?album=33"]So here are some pictures:[/url]
Front of bike
Rear of bike
Batteries
http://www.evfr.net/coppermine/albums/10-3-09/normal_IMG_2253.jpg
DC-DC converter
http://www.evfr.net/coppermine/albums/10-3-09/normal_IMG_2225.jpg
Fiberglass tank
http://www.evfr.net/coppermine/albums/10-3-09/normal_IMG_2233.jpg
bottom of tank
http://www.evfr.net/coppermine/albums/10-3-09/normal_IMG_2234.jpg
Charger
http://www.evfr.net/coppermine/albums/10-3-09/normal_IMG_2229.jpg
headlights
http://www.evfr.net/coppermine/albums/10-3-09/normal_IMG_2248.jpg
http://www.evfr.net/coppermine/displayimage.php?album=33&pos=23
Handlebar mount
http://www.evfr.net/coppermine/albums/10-3-09/normal_IMG_2246.jpg
So thats about it for now, gotta check in on the controller and BMS. Talked to a welder the other day, and they said "we'll trick that bike out...." so I'm hoping the motor mount and battery box turn out good
Travis Gintz
frodus
Postby frodus » Thu Jan 14, 2010 5:10 pm
Another update:
V2.0: Mechanical planning
http://blog.evfr.net/?p=290
Getting closer.... starting the mechanical layout.
Travis Gintz
frodus
Postby frodus » Mon Jan 18, 2010 1:48 pm
New entry with pictures of my AC15 motor disassembled.
V2.0: Inside the AC15 motor http://blog.evfr.net/
Travis Gintz
frodus
Postby frodus » Wed Mar 03, 2010 3:34 pm
Another update:
eVFR 2.0: 72V 20Ah test pack
http://blog.evfr.net/?p=312
Key points:
- Got a test pack assembled and BMS talking
- update on iPhone display project
Travis Gintz
frodus
Postby frodus » Tue Jul 20, 2010 6:00 pm
July Update, blog entry and some photos:
http://blog.evfr.net/?p=344
  • got new motor mount fabricated
  • tested all 200+ batteries
I want to get the BMS working on the 48V test pack, the motor mounted and start mocking up where things will go.
Travis Gintz
frodus
Postby frodus » Fri Jul 30, 2010 1:12 pm
Another little update
V2.0: TTXGP @VIR and Battery testing
http://blog.evfr.net/?p=351
Main points:
  • I'm going to the TTXGP @ VIR to represent Manzanita Micro
  • Manzanita is expecting their Headway shipment to arrive soon
  • I've almost finished building my cell discharger/tester/cycler
  • I'll be testing the Headway cells at VIR
  • I'm excited to get to see another race!
Travis Gintz
frodus
Postby frodus » Tue Dec 14, 2010 12:40 pm
Here are the most recent pictures of the bike at the shop:
and here's one of the latest side project, my battery discharge setup:
Travis Gintz
frodus
Postby frodus » Thu Apr 14, 2011 5:12 pm
Blog update:
Wow, It’s been a long time since I’ve had something to update on here. I’ve done pretty much nothing to the motorcycle in 6 months. I’ve been busy, I’ve moved, and most of February and March was spent with friends who moved and had birthdays. The guys helping me with the fabrication have been slammed as well. Now that that is all over, I’ve hunkered down and decided to get serious!
I didn’t like the fact that my battery test setup didn’t cut out automatically at a set voltage and temperature to protect the battery, so I bought a CBA-II and a temperature sensor to help automate the test. I increased my discharge current ability, but now I can just walk away. So far the tests look good and I love the graphs from the CBA so far. It gives me all the information automatically (Ah, Watts, temperature, voltage). I want to set up “Burst Mode” on the CC400/CBA setup so I can alternate between 2 currents with 2 associated durations. For instance, set the CBA to 5A, and set the CC400 to alternate between 15A continuous and 75A for short bursts. This will allow me to check that the cell can discharge at 2C continuous and 8C bursts. From that, I can look at my CBA output and get the voltage at 2C and 8C and calculate IR for each cell. Its gonna take a while, but hopefully I can catalog all of the batteries. I better get to work, there’s 160 cells to test!
Another big thing to announce that I’ve found some help on the mechanical side. A guy at work who goes to ITT has 2 classmates that wanted to do an EV project for their senior project. I talked with them a bit and they’ve decided to use my project as their final project. They’re mechanical engineering students and wanted something real world, not just a drawing of something. I’ll do the electrical, and help with ideas on the mechanical, but for the most part, that is their project. I’ll be working with Aston and Bryan on getting the bike finished by June 4th, when they have to present. We won’t have the bike street legal, but it’l be drivable. I can work on the lights/paint after its done.
I also decided to sell my AC15 and Curtis 1238-7501 (AKA AC18) combo. Why? well, I decided to buy an AC20 off a friend of mine. It’l fit in the same motor mount, but it’l stick out 1.5″ more. I sold my AC18 to a fellow board member on ELMoto, so I know it’l have a good home.
So this week, I removed the old motor and shipped it, and readied the chassis for the AC20 motor. Aston and Bryan came over and we made foam mockups of all of the batteries (160 of them) in groups of 55, 55, 25 and 25 to fit in the chassis. We think we can get everything in without cramming everything in. At this point it looks like those groupings will get us the 160 without any issues. We’ll probably go with steel for a battery box and make it somewhat easy to remove out of the top of the frame. We measured and everything looks like it’l fit. I’ll have some photos and drawings soon.
So this weekend, I’ll probably fit the motor in the bike and get some of the Headway batteries tested on my discharger. I’ll throw them on a single cell charger for a bit to charge them up, let them rest for 24 hours or so, and then do a burst mode discharge to ensure they can do 80A (8c) and estimate their IR. I want to catalogue the cells by barcode so I have a “file” for each cell. This will prove useful in matching as well as future use. I may decide to measure these cells again at a later date, so I have some real world data on % capacity loss after XX cycles.
Anyway, thats it for now. Hopefully we finish by June without any hiccups.
Travis Gintz
frodus
Postby frodus » Tue May 03, 2011 3:36 pm
Blog entry
So these 2 students helping me are kicking some ass. They’ve got just a little help from me with the electrical layout and basic ideas, but they’ve done awesome at getting the drawings done for my fabricator and making a nice finished drawing. There are only some minor changes we’ll do, but overall things look awesome!
Last week I purchased a 3/4″ thick 4′x5′ piece of UHMW (Ultra-high-molecular-weight polyethylene) sheet. This will be the basis for the battery holders and covers. We’re making 5 packs. Two 11s5p packs, one 6s5p pack, one 4s5p pack and a 4s1p auxiliary 12V pack. The 4 large packs will be enclosed in an aluminum box which will be sealed to prevent water getting into the system. I’ve tested the batteries at 5C and do not think they’ll get too warm in this setup. I will get a fault/warning if the batteries are too hot (My BMS monitors temperature for each cell board).
Here are two drawings of the 11s5p packs we’ll build:
So we’ll be meeting this week to finalize any issues we’ve got and then send to my buddy Dave Boyd (formerly of Synkromotive) to route them out on his XYZ Router table. Once that is done, we’ll assemble and start fabricating the battery box and get bussbars waterjetted out of Copper sheet (1/16″).
We’re hoping to have the battery box, controller, motor and charger mounted and wired up by the last week of May. We’ll get it “running” but not street legal in time for their final presentation the first week of June.
Travis Gintz
frodus
Postby frodus » Tue Jun 07, 2011 10:41 pm
EVFR 2.0: Battery holder prototypes finished
http://blog.evfr.net/?p=389
We got a first run prototype done, it's a 2x2 holder for my 12V battery.
So far so good!
Gonna try and get the bike to Dave's shop soon so I can start doing some more measurements done. The help from the students has ended, so I'll be getting help from Dave on the fabrication of the rest of the battery holders. I'm impressed with the way they turned out!
Travis Gintz
frodus
Postby grindz145 » Wed Aug 03, 2011 7:30 am
Travis, this rocks. I'm trying to decide on lipo vs LiFePO4 for my hybrid KLR. More and more the mechanical and longevity benefits of LiFePO4 seems worth it.
I feel that this is a critical piece of an electric bike that has to be developed from scratch everytime, so I think there's a ton of potential here.
VFR is looking fantastic too.
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby frodus » Wed Aug 03, 2011 10:24 am
Thanks guys!
It's been a busy summer, so haven't got to work on it a ton. Changed the pack design a little bit, so we're redoing that.
Travis Gintz
frodus
Postby frodus » Tue Aug 30, 2011 12:30 pm
Little bit at a time. I got some new levers for my front brake (the old one has an adjustment piece that was rusting) and some other spare parts. The big thing I got was a heatsink from Noah that he did. He milled a second one for me that fits the curtis 1238 exactly. I'm very impressed. Right now I plan to mount it very low on the bike so that the fins kind of stick out from under the fairings where the exhaust was located. It will provide pretty good cooling. I might also consider the front behind the front wheel. Just need to see how my mockups fit.
Image Image
Also got my old 28Ah 12V SLA's back from the guy that I sold them to and didn't use them, along with some parts he wants me to sell. Should make a nice test setup.
This week:
Hot glue and foam-board mockup of my battery pack and location of charger and controller.
Travis Gintz
frodus
Postby frodus » Fri Sep 16, 2011 11:23 am
Got my forks rebuilt last week and drilled out my triple clamp to attach a bar riser I found to mount some Spiegler superbike handlebars. Only 1 problem, the brake line isn't long enough, so I need to order some new lines. Kind of a bummer, but now I can upgrade to braided brake lines quick would be good since I'm running with 25+ year old lines.
Got me thinking about just replacing the front master cylinder too. They're harder to get parts for. Since I don't NEED anything immediately, I'll let things go until I get the bike running because I'll probably want to rebuild the front and rear brake slaves, replace brake lines, replace pads and put new brake fluid in there. It'l be a good nice weekend project in the spring.
But at least it's back together. I'll throw the old bars on there for now until I get the lines. Probably be a couple months because I don't really feel like rebuilding the brakes too. At least I can get back to the battery pack I keep putting off.
Some pics:
Travis Gintz
frodus
Postby Gregski » Mon Sep 19, 2011 9:16 pm
very nice build, keep the updates coming they're great
Gregski
Postby allen_okc » Thu Jan 05, 2012 1:55 pm
looking awesome and very clean Travis - looks like you'll be riding it very soon... good job... :D
For Everything There Is A First Time...
http://www.youtube.com/watch?v=dI3nbn0M ... re=related
allen_okc
Postby frodus » Fri Jan 06, 2012 11:54 am
definately a slow build eh?
Got some shop space at a metalshop near me for the next few months, will be moving the bike there soon. Have a welder/fabricator working with me on the battery pack since I have no metalworking tools/welding equip.
Travis Gintz
frodus
Postby Link » Fri Jan 06, 2012 4:35 pm
frodus wrote:definately a slow build eh?
Just a little, yeah.
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
Link
1.21 GW
1.21 GW
Postby frodus » Fri Jan 06, 2012 5:15 pm
bike < my side business < social life < girlfriend < day job
Plus I've been distracted trying to do some android stuff to talk to my controller/BMS.
Travis Gintz
frodus
Postby frodus » Tue Jun 19, 2012 1:55 pm
I’ve still been working on the 12V test pack and wiring while parts are fabricated. I got the BMS controller + cell boards talking and shutting off the charger correctly.
Working on a schematic, but here’s what I’ve got so far:
Ordered some optically isolated FETs to wire to the throttle since the Curtis I/O is not isolated. This will allow me to limit throttle as I reach my discharge current limit (DCL). It’s an analog output from the BMS, the more that output is driven, the less throttle I get. I can also limit regen by using another optically isolated FET on the CCL line and limit the Brake input.
Got the delta-q algorithms set up and wiring figured out. There’s an enable line that is grounded to B- when you want it to run, and ungrounded when you disable it. I control this with a little automotive relay connected to the HLIM (High Voltage Limit) on the BMS controller. This allows the BMS to turn the controller on/off when cells go high.
There’s a Relay inside the DeltaQ that turns on when you plug it in. I’ve taken the 12V always on from my Surepower DC-DC converter and wired that to the COM of the relay contacts. N/O goes to my V-Source of the BMS controller, so when it’s plugged in, it powers the BMS but nothing else. The N/C contacts go through the Ignition, and to the Key-switch input on the DC-DC converter. The switched output of the DC-DC goes to the V-Load input to power the BMS. It also goes to my 12V system (lights, signals, etc.).
The Curtis does its own Contactor control and pre-charge, but the BMS needs to be able to turn on/off the load. I can do that with DCL limiting throttle, but nothing disables the controller in case of a fault. I’m thinking I’ll use the LLIM line to drive a small 12V coil 150VDC contact to switch B+ and pin 1 (enable) of the controller.
I also wired up Canbus, changed the Elithion to ID 7E0 for OBD-II PIDs. I connected a Bluetooth-OBD-II dongle, paired with my Android tablet, started a program called Torque and imported a list of PIDs that I got from Elithion and added some Gauges. Screenshot:
So I’ve got the logic all figured out for the 4 main electronic pieces (controller, DC-DC, BMS and charger)… so after that, it’s on to the lighting/existing electrical.
Other pics of the bike below. Have fairings mounted, starting to sand and get ready for paint:
Travis Gintz
frodus
Postby frodus » Thu Jun 21, 2012 10:40 am
More pics....
Pic of the fibarglass faux tank (just 1/2 of it, used as a cover) with filled in gas cap:
Pic of the battery pack:
Travis Gintz
frodus
Postby grindz145 » Thu Jun 21, 2012 12:12 pm
Nice Travis!
I'm planning to do the same thing on my puch magnum top tank conversion. Tank as a cover.
The canbus BMS has really got me thinking now...
grindz145
PreviousNext
Return to E-Scooter and Motorcycle Photos & Videos
Users browsing this forum: Bartimaeus and 3 guests
