Yet another Yellow Ninja 250 Conversion!
Postby pgt400 » Sat Jul 19, 2008 8:56 pm
(200 KiB) Downloaded 2458 times
I picked up my donor 03' Ninja 250 today. 1044 miles, mint condition but not running, sat for 3-4 years. Cleaned carb and 1 hour latter was running like new, took a 1 hour drive around town.....very nimble/fun bike! Tommorrow I will pull the engine and ebay it. On order ETEK-RT, Kelly 72400 with regen, contactor, fuse. Hoping to be able to shoe horn the motor above and behind the mono shock, but it will be close. All batts must fit within the flairing....I want it as stock looking as possible. Will gear for 50 max for now with 5-6 SLA's....35-50 AGM's depending on the room. Should be lots of fun!
03' Ninja EX250, Agni #95 reinforced, 25S1P 40ah CALB Lifepo4, Mini-BMS.
05' Mongoose 20" BMX, Golden Hub Motor, 48 volts @ 9ah, A123's, Signalab BMS.
http://www.evalbum.com/1955
http://www.evalbum.com/3337
pgt400
Re: Yet another Yellow Ninja 250 Conversion!
Postby pgt400 » Sun Jul 20, 2008 8:02 pm
Wow, sure is light without that engine! Can't wait for the motor and controller.....Come on UPS!
vegas trip 006.jpg (90.01 KiB) Viewed 4473 times
pgt400
Postby gogo » Sun Jul 20, 2008 8:53 pm
Hmm, I can't help but think that the stiff engine case was an integral part of the frame strength. The older cradle frames probably don't lose strength without the engine, but that picture of your frame without the engine raises an eyebrow on me.
gogo
Postby pgt400 » Sun Jul 20, 2008 9:45 pm
Bet it was...My lead holder will be pretty stout. Not worried.
pgt400
Postby fechter » Mon Jul 21, 2008 8:43 am
I'd suggest looking at the dimensions of lithium batteries and design the "lead holder" to be future compatible. :wink:
fechter
Postby pgt400 » Mon Jul 21, 2008 9:10 am
I'm using U1 SLA's. There are a few lifepo4 vendors with this size. Also, the packages are smaller so its easy to make a custom size. Maybe Firefly will make a U1 size and Walmart will stock it!
pgt400
Postby goodnslo » Mon Jul 21, 2008 9:22 am
gogo wrote:Hmm, I can't help but think that the stiff engine case was an integral part of the frame strength. The older cradle frames probably don't lose strength without the engine, but that picture of your frame without the engine raises an eyebrow on me.
I agree that the motor was a part of the frame structure, but when you realize that it is being replaced by a battery box that can be made to be as strong as or stronger than a motor mount, the builder just has to keep in mind the stress points and plan accordingly.
Keep current on electric motorcycle development http://www.electricmotorcycles.net
My Lectra electric motorbike http://www.evalbum.com/1567
Add your EV to the largest photo collection of Electric Vehicles on the net at EV ALBUM.com
goodnslo
Postby pgt400 » Mon Jul 21, 2008 11:24 am
Also, I intend to keep wheelies and stoppies to a minimum!
pgt400
Postby Jay64 » Mon Jul 21, 2008 10:45 pm
What's the fun in that???? :lol:
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby pgt400 » Wed Jul 23, 2008 6:41 am
Motor came yesterday, bigger then I thought. I bought directly from MARS, had within 3 days.
(86.8 KiB) Downloaded 3259 times
pgt400
Postby pgt400 » Sun Jul 27, 2008 3:17 pm
welded up the battery racks. batts come tommorrow.
vegas trip 012.jpg (89.64 KiB) Viewed 4145 times
pgt400
Postby dogstar74 » Mon Jul 28, 2008 9:04 pm
Yet another yellow ninja 250 conversion!
You say that like we get tired of seeing this stuff. Looks absolutely great!
dogstar74
Postby pgt400 » Mon Jul 28, 2008 9:34 pm
Well, all (6) batteries fit, maybe I can find room for 1-2 more? Wonder if the MARS-RT would like 96 volts?
More welding tommorrow and the 72 tooth sprocket. Kelly Controller & contactor are comming from China.
(90.15 KiB) Downloaded 3007 times
pgt400
Postby drewjet » Mon Jul 28, 2008 11:53 pm
Looking good!!!
ImageSuzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
3220 Mountain Bike viewtopic.php?f=28&t=16705&p=244317#p244317
Suzuki Lipo Upgrade viewtopic.php?f=10&t=23088&p=335986#p335986
Race Bike viewtopic.php?f=3&t=32486
drewjet
Postby Jay64 » Tue Jul 29, 2008 8:10 am
Looks good. Quick question, are all the batteries just stacked on top of each other at the front of your battery trays?
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby frodus » Tue Jul 29, 2008 2:32 pm
what bats are those?
Travis Gintz
Electro Motive Force, LLC.
EV Consulting and Sales
frodus
Postby pgt400 » Tue Jul 29, 2008 5:18 pm
No, theres a center tray that isn't done.....ran out of angle stock.
pgt400
Postby pgt400 » Tue Jul 29, 2008 5:25 pm
frodus wrote:what bats are those?
They are from Powerstar. I bought online. On their web page the battery stated "FOR DEEP CYCLE". The batts I got LOOK identical and had the same part number, but don't have DEEP CYCLE printed on them. I called and the guy assurded me they were the same construction, from same supplier. Anyway, they were only $52 each and $11 each to ship. 2 year warranty. U1 size. I was trying to find a vendor with B&B's but the best price I got was $116 for the EVp35's. I'm hoping to go with Lifepo4's soon....when price dives. A 72v 60 AH pack would be real nice. UPS brought controller, contactor and sprocket today.... after dinner I should get more done.
pgt400
Postby pgt400 » Sat Aug 02, 2008 6:13 pm
Great progress today, finished welding, painted and re-assembled batt trays. Mounted controller, fuse & contactor. Did most of the heavy wiring and called it quits. Pool, grilled salmon, asparagas and coronas. Should have a test run tommorrow.
(62.46 KiB) Downloaded 1515 times
pgt400
Postby pgt400 » Sun Aug 03, 2008 7:56 pm
First test today with 60 volts. Didn't do the twist throttle yet so I just taped a pot right to the tank! Ran great, real smooth. I put 8 miles on it and put her back on charge. The batts were at 64 volts.
(192.37 KiB) Downloaded 1100 times
pgt400
Postby Link » Mon Aug 04, 2008 12:09 am
pgt400 wrote:First test today with 60 volts. Didn't do the twist throttle yet so I just taped a pot right to the tank! Ran great, real smooth.
Gee, I can't see anything that could have gone wrong with that. :roll: :P
ಠ_ಠ
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
Link
1.21 GW
1.21 GW
Postby pgt400 » Wed Aug 06, 2008 8:12 pm
Been running at 72 volts, but only ~70% power. My pot setup only goes to about 2.8k ohm (default wants 4k for full power). Normally not a problem as the end points are programmable, but my PC isn't talking to the controller. Kelly has been very helpful, sending out a new cable and interface dongle. Added (3) on board 24v, 3 amp smart chargers. Nice to be able to just plug it in. They are cheap scooter chargers, seem to work real nice. Keeps burping the batts till they all go into float mode. Going to start cleaning it up an clearancing the lower fairing.
(98.76 KiB) Downloaded 1287 times
pgt400
Postby pgt400 » Sun Aug 10, 2008 7:23 pm
Finised, very happy with the way it came out. A blast to drive. I put over 100 miles on it the last couple days. The regen works very well, glad I got it. I take power from the brake light to close a relay sending 24v to the kelly controller giving 30% regen. I could use the fully regen but I'm using AGM's, not sure they want to see 80 amp charging current. Ordered LED bulbs since I tap 12volts off the main pack.
Posted on Evalbum as .well
(74.5 KiB) Downloaded 1204 times
pgt400
Postby frodus » Sun Aug 10, 2008 10:35 pm
dude, that turned out great! another one on the road.
Just insured mine, and need to get the lights working...
Everything on your seemed to fit together really well, great work!
Let us know the performance numbers as you get more seat time on it.
Travis Gintz
frodus
Postby pgt400 » Mon Aug 11, 2008 5:06 pm
Thanks, I was thinking of adding another batt but Mars didn't reccomend 84v. Going to add a tooth to the front sprocket. I really enjoy riding around town with it. Lots of looks from people tring to figure out why its so quiet. I do find myself checking out lifepo4's......will try and hold out till next year.
pgt400
Next
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: Drunkskunk and 2 guests
