SLA Tester for 12ah and 20ah Batteries
A place to list links to retailers that sell EV related parts.
Postby carbon.nanotube.capacitor » Fri Jul 18, 2008 3:41 pm
I was wondering if anyone has experience with digital SLA testers. I remeber using one at a shop once that worked well, except that it always estimated the capacity of 12ah batteries to be full, even when they were near-dead. I don't remember the brand, just that it was hand-held and orange. What I'd like is a digital one that is accurate even for smaller batteries. At the moment I am using a 500 Amp load tester and reading the voltage before, during, and after load. Small batteries are difficult to measure this way - even 12ah sizes are too small really, although it works fine for liquid starter batteries.
Any ideas or recomendations would be appreciated.
signature
Re: SLA Tester for 12ah and 20ah Batteries
Postby usatracy » Sat Sep 06, 2008 7:39 pm
We have used the West Mountain Radio CBA II
Base unit is only 100 bucks and can test 3 volt cells to 18.8 amps and 12 volt batteries to about 8 amps
They have an expansion unit to allow serious testing at much higher loads but that adds over 600 to the cost.
Uses USB to a PC to control the testing and allows some configuration of the testing and safety cutoffs based on low voltage and/or temperature.
Its a nice toy, would be nice if the expansion unit ws not so much more money though...
http://www.westmountainradio.com/CBA_ham.htm
Here are some tests and graphs we produced using that unit on Thundersky cells
http://www.voltsrider.net/vr/forum_posts.asp?TID=179
usatracy
Postby usatracy » Sat Sep 06, 2008 7:45 pm
We have tried that (10 second load testers) and found it seriously lacking in find the true capacity of a EV deep cycle battery which was important for us since the pack of 5 batteries in our 60 volt string can only go as far as the weakest battery, using either a PakTrakr and riding the bike, or, the CBA II and performing a load test, have proven to be the only sure fire ways to make sure the pack is healthy and trouble free.
If someone had a silver bullet 10 second test we would be interested too, but so far, it seems you need to really put a little time and discharge into it if you want to have piece of mind that the pack is in tip tip shape.
Those high amp load testers exists to prove a battery can provide hi amp starting capacity for starter motors, and aren't really the thing to use to determine if a battery has the deep stores for lower amp long time drain capablity.
We took a silicone battery in Sep 2007 that had only 30% of its capacity left, used a starter load tester, the battery passed the test with flying colors, but could only power an EV for 2 miles instead of 23.
usatracy
Return to Resources & EV Related Parts
Users browsing this forum: No registered users and 0 guests
cron
