Hello
I have in my possession 2 batteries for test, they are both Lipo and are rated as follows.
37V 20AH (265 x 155 x 100) Length, Depth, Height (6.8kg)
and
48V 20AH (265 x 160 x 150) Length, Depth, Height (9.1kg)
The 37V battery weighs 6.8KGS so is heavier than the ev tech battery however it is a higher capacity battery and will put out 15AH where as the point 1 battery only does 10AH before cutting off. Also you can pull peak of 60A from it with 45A continuous.
The build quality looks ok on the inside but it looks a little rushed on the outside, it is cheap however, its size is a little bigger than the point-1 packs again I think that this is down to the higher capacity.
I need to make some mods to my bike rack in order to get it bolted down for a test, the 48V battery is a different challenge as it is a little bigger I will post up some pictures of that soon.
There are some very substantial cables coming off the battery I think 10mm so they look good for the amps (if a little over sized in all honesty) there is an internal 2 pin socket fixed in the pack for charging, both units come with 3A chargers that look and perform very much like the point 1 chargers and put out 3A.
I will let you all know how they perform in the next few weeks.
All the best
Knoxie
