Xyster's Stealth Scooter
Show off your E-Scooter or Motorcycle creation here.
Postby xyster » Sat Jan 13, 2007 10:54 pm
48V 4 x 10ah SLA
stock 30 amp controller
forced air cooling
added lights, foot rests, raised battery box, instrumentation, mirrors, better seat, etc...
top speed: 24 mph
range: 7-10 miles
Ebike: 5304/20", 72V 35A controller, 33AH 80V 20s15p (18650 sized cells) DIY lithium-ion pack
http://endless-sphere.com/forums/viewto ... 47&start=0
Scooter: '06 Stealth s1000, 48V 30A, 4x10ah SLA
http://endless-sphere.com/forums/viewtopic.php?t=148
Ebike: '06 Currie Mongoose, 32V 35A, 32V 22AH hybrid SLA/Li-ion pack
http://endless-sphere.com/forums/viewtopic.php?t=1010
xyster
1.21 GW
1.21 GW
Postby patrick_mahoney » Sun Jan 14, 2007 12:01 am
Out of curiousity, why have both the scooter and the e-bike?
9Continent 2807/700C, 36V 25A Infineon controller (w/ regen), 48V 15Ah "Ping" LiFePo battery
patrick_mahoney
Postby xyster » Sun Jan 14, 2007 12:16 am
Why order both chocolate and vanilla at the ice cream parlor? :)
xyster
1.21 GW
1.21 GW
Postby knightmb » Sun Jan 14, 2007 3:29 am
patrick_mahoney wrote:Out of curiousity, why have both the scooter and the e-bike?
In case one breaks down :mrgreen:
Right now I think his rack broke, so the bike is out of e-commission at the moment :?:
knightmb
Postby xyster » Sun Jan 14, 2007 12:37 pm
Yep
-in case one breaks down
(one flavor of ice cream tastes bad for some reason)
-so I can go riding with the ol' lady (share'n a scoop or two)
-because I like the scooter too -- it's little less practical, and little more fun than an ebike IMHO -- mainly because it's brushed motor, small wheels make it more maneuverable and quicker too.
(they're very different flavors of the same type food, but both chocolate and vanilla taste so good)
Right now though, both vehicles are out of commission and I'm missing my ice cream like it was meltin'!
The ebike needs a new rack (just ordered the same one again -- I though of a simple way to shore it up and my battery box was designed to bolt to that particular model)
The escoot needs new tires and tubes (will get soon).
xyster
1.21 GW
1.21 GW
Postby xyster » Thu Feb 15, 2007 4:36 pm
For Valentine's Day I got my scooter some new footwear. :)
Changing the tubes and tires took 4 hours. The s1000's rear assembly is a PITA to remove! I like the general performance and feel of this Schwinn's direct-drive, but going chainless was supposed to be less of a hassle, not more. If I had it to over, I'd get the '06 izip 1000 or '07 stealth with the chain drive instead.
Oh, the new tires are 2.25" wide whereas the originals were 3". They fit just as good, but seem a bit more squirrelly on the road. I'm hoping they'll handle better once worn in. The tubes are 3x thickness. I also installed puncture-resistant kevlar belts between the tubes and tires.
xyster
1.21 GW
1.21 GW
Postby Stevil_Knevil » Tue Feb 20, 2007 9:42 pm
I'll bet that your top speed "jumps" ~1.5 MPH with the new tires @ 55 PSI.
<slap> 5 bux..
I know it's a little late, but how about some dual inner-tube modification/flat insurance?
http://www.instructables.com/id/ECFUTKS5NREPORTJH9/
Ridefastakechances;^) -S
Stevil_Knevil
Postby xyster » Tue Feb 20, 2007 10:12 pm
<slap> 5 bux..
Well, Stevil Knevil (that'd be a great if that was your real name! If not, have you thought about naming one of your kids that? :) )
at their present 45 psi top speed is the same. The stock tires were 3" wide, these are 2.25". At low speeds these thinner tires ride more 'tipsy'. I didn't look very hard, but I didn't see 12.5" x 3" tires at any of the normal scooter parts stores.
Love that double-tube idea. I might try that on my bike when it times for the next tire change. I'm using panaracer kevlar belts
http://www.universalcycles.com/shopping ... &category=
in front and rear in the bike and scooter. So far, 1300 miles between 'em and no flats yet! (knock on rubber...)
xyster
1.21 GW
1.21 GW
Postby BiGH » Sun Apr 01, 2007 1:54 am
that dual innertube and kevlar tape are fantastic ideas - thanks guys!
BiGH
Postby BrendaEM » Mon Apr 02, 2007 9:45 pm
I like the footrests. Can we get a good look at them?
BrendaEM
1 W
1 W
Postby xyster » Mon Apr 02, 2007 10:50 pm
Absoscootely!
xyster
1.21 GW
1.21 GW
Postby fechter » Tue Apr 03, 2007 9:12 am
I like the footrests. It allows stacking tall piles of lead on the deck.
What are they made of? Are they strong enough?
fechter
Postby xyster » Tue Apr 03, 2007 9:34 am
Also a more comfortable, motorcycle-like seated position. The raised deck can be securely held between one's feet, allowing better control. In addition to the small controller, the box now fits at least five 10ah batteries, or four 12ah batteries.
Same as the deck risers, I cut the footrests from 1/2" oak plywood.
No problem supporting my 170lb weight. They're attached at the sides, and supported underneath by another wood slab.
xyster
1.21 GW
1.21 GW
Postby BrendaEM » Thu Apr 05, 2007 11:58 am
xyster wrote:...The ebike needs a new rack (just ordered the same one again....
REI has a rack that's supposed to take 40lbs. The cantilevered tube has no welds. It's is one-piece casting. The rack has saddlebag holders. I don't see it online. There's one there, but it's welded.
BrendaEM
1 W
1 W
Re: Xyster's Stealth Scooter
Postby jcat » Wed Apr 15, 2009 4:15 pm
one have a parts diagram for the re-assembly of the back wheel?
jcat
Return to E-Scooter and Motorcycle Photos & Videos
Who is online
Users browsing this forum: No registered users and 3 guests
