RC Greyborg build thread
Postby comradegerry » Sun Mar 13, 2011 8:28 pm
After lurking, reading, learning and generally being left in awe at the slew of recent builds on the sphere, I thought it was about time to start a build thread to help document and hopefully get some advice to save any obvious costly mistakes during this iminent build.
The plan is simple, take Hal's awesome Greyborg platform, mate it with Matt' awesome 2 stage reduction, integrate a 48v 20ah battery into the frame, flesh the rest of the bike out with the best parts available and then run it through the cranks to the 11 speed Alfine lurking in the rear wheel. The bike will be initially built with a chain drive, however once the new monoque aluminium swing arm becomes available it will be getting switched out to a Gates Carbon Drive system to the rear wheel.
The bike is currently in transit and most of the parts are gathered or ordered, with the exception of the battery, this will be something a little special and hopefully a debut of something new. :)
I have next to no mechanical, electrical or engineering skills, therefore this build will showcase the skills of others and encourage others with limited abilities to take advantage of the plethora of available parts that helped Ebikes become plug and play. I have a mate that is an engineer and I will be bribing him with alcohol on a regular basis to ensure his assistance with things technical.
Whilst waiting for the parts to arrive, I thought I might make a start on the handlebars. It is worth mentioning that I am currently suffering a compulsive attraction to titanium bike parts and also am trying deal with an Ebay addiction, the build log may end up being part of my therapy and the first step to recovery.
The bars are Bontrager Race Lite Ti, I saw them on ebay and just had to have them. The idea is to mount a large format Cycle Analyst with 2 of rather bright LED lamps either side. I originally was leaning towards just the one but in the interest of symmetry I have ordered another one. The lamps are shipped with a standard handle bar mount, well made and quick release. This did not really wok for what I wanted so they have been adapted a little. I did a couple of dry runs to see where I wanted the parts to sit then drilled 3 x 4mm holes through the top bar. I worried about ruining the structural integrity of the bar so I mixed up some JB Weld, taped the bottom of the through hloes, took a syringe and put a good blob in each to help spread any load, I drill the holes out again the next day. I took the original mounts off then hand filed a half round profile into the plastic so that the mounts sits squarely on the skinny pipe. 3 stainless M4 machine screws will then be used to secure everything. Once I have the other LED light in hand I will shorten the cables to make them as tidy as I can on the bars. Few pictures below for illustration purposes.
I need this to be up and running in 3 months so that is my timeline.
Having seen Grayborg #1 in matt black posted by Hal in another thread, that pretty much settles my colour choice, black it will be!
LED light.JPG (68.6 KiB) Viewed 3525 times
Bar back.JPG (18.71 KiB) Viewed 3491 times
(64.95 KiB) Downloaded 3 times
(48.09 KiB) Downloaded 3 times
comradegerry
Re: RC Greyborg build thread
Postby comradegerry » Tue May 24, 2011 1:42 am
The canopy of the bike is going to be secured by Rivnuts, which I thought would be straight foorward enough. I bought all the gear and then had a go at it last night.
The plan was to use the M4 stainless rivnut which uses a 6mm clearence hole. I drilled the hole out from 5 to 6mm, easy enough, assembled the instalation tool only to find that the frame tube does not allow the tool to sit square over the hole. After some head scratching and advice from my engineer buddy, I started to mod the tool a little on the grinding wheel and then by file to a profile that would clear the tube and allow a straight pull. I ground the shiny piece at the end of the tool and then had another crack at the instalation. First one went in but because I had not ground the other part of the insertion tool, it did not sit square and as I tightened the handle, it twisted and cracked the threaded mandrel. Back to the vice with the tool and removed the offending material, it now looks like it should work. Just need to get a new 4mm mandrel that I will order online today. Attached pictures are the efforts of 3 hours of futility, next attempt will yield better results.
Rivnut 1.jpg (25.35 KiB) Viewed 3285 times
Rivnut 2.jpg (29.75 KiB) Viewed 3285 times
Rivnut 3.jpg (27.42 KiB) Viewed 3319 times
Rivnut 4.jpg (24.08 KiB) Viewed 3285 times
Rivnut 5.jpg (31.39 KiB) Viewed 3319 times
Rivnut 6.jpg (28.6 KiB) Viewed 3285 times
comradegerry
Postby Philistine » Tue May 24, 2011 7:02 am
Nice work. Really interested in what you are doing with the Rivnuts. I tried gluing nuts to the underside of the tabs, but of course they just broke off under torque of the screw.
So after you posted about it I ordered some rivnuts, which should turn up tomorrow or the next day. But I am so stupid I didn't realise there was a tool for their installation. :oops: I had thought I could just slide them into a tight drill hole in the tab.
This is sending me nuts (excuse the pun), because it is the last thing I have to do to get my bike going. Have all the wiring done (have even tested it with my 9C and she is going, just haven't ridden it as I haven't attached the cranks or brake cables, and am just waiting to be able to attach the plastics to be able to attach the cranks and chain etc..
Look forward to seeing your further efforts. I will post photos of mine soon when I get a chance, have been insanely busy with work and family lately.
Philistine
Postby recumpence » Tue May 24, 2011 7:07 am
Gerry,
Guess what is all machined up and ready to go?! :mrgreen:
I am looking forward to this build. Did you notice I am building a full suspension bike myself too?
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
Location: On Earth right now. That can change at any time, though..........
Postby Philistine » Tue May 24, 2011 7:26 am
FYI, here is an article on how to make your own ghetto rivnut tool. I am going to try this first before I head to the hardware store http://www.carolinarovers.info/index.php?option=com_content&view=article&catid=81:miscellaneous-tips&id=259:make-your-own-rivnut-tool&Itemid=150
Philistine
Postby comradegerry » Wed May 25, 2011 1:31 pm
Had another try at the Rivnuts with no sucess, drill and tapped a M4 stainless bolt into the mandrel but that sheared 3 times under pressure. New parts on order from Make Ends Meet to finish the canopy instalation.
Split the frame for the belt drive, learnt a new phrase today "interference fit", apperently when you can just force one piece of metal into another so tight no other fixing are required, well it was new to me.
Wheels came back from LBS, going for the off road look, happy with the way they laced them up, will step up to thicker spokes if I end up putting more than 750 watts through the rear wheel but for now the plan is low power through the gears.
Rivnut round 2 failed.jpg (29.54 KiB) Viewed 3159 times
Frame Splitter Halfway.jpg (22.91 KiB) Viewed 3159 times
Frame Splitter Installed.jpg (29.46 KiB) Viewed 3193 times
New Wheels.jpg (27.07 KiB) Viewed 3193 times
comradegerry
Postby Whiplash » Wed May 25, 2011 2:32 pm
I hope you plan on welding that splitter there! I would NEVER Trust a press fit on a frame component like that without SOMETHING else, even some bad ass epoxy or something....
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby SoSauty » Wed May 25, 2011 11:40 pm
Interference fit is also a threading term, loose, tight, interference. An M30 X 1 thread (small flip/flop freewheels) isn't generally found on old lathes. Sometimes you can get a M30 X 1.5 feedrate and then mate to M30 X 1 threads accepting an interference fit :P
Chinese stuff is mostly 'loose' fit.
http://www.ebikes.ca/index.shtml No.#1 Trusted E-bike online sales!
3 hardtail MTBs:
-48V Lith-ion 10.5amp hr-408 C-lyte
-BPM 8FUN[*STOLEN]
-run Century rides w/Q100 mini
3 folders:
-20" wife's BaFang,
-20" TurnigyMax50cc airline suitcase folder,
-24" Stewart/Hass 9C; 3.5K/40mph fun racer
SoSauty
Postby comradegerry » Thu May 26, 2011 1:45 am
Hi Whiplash, I was planning on using a chemical metal type epoxy if there was any play or room for it. Since there is no space for epoxy and I think the loads are compressive at that point of the frame I am willing to see how she goes. If I get some movement I will drill and tap a couple of grub screws to steady it. It took some whaling on it with a hammer, I don't think it would come out even if I wanted it to!
Hi Matt, looking forward to your full suspension project, if it is anything like the rest of your builds it will be awesome and the envy of many.
Next chalenge I seem to face is that I am not sure how to get the rear Gates Carbon Drive cog to mate to the Shimano Alfine rear hub. I bought the cog for the Alfine off of the Gates website but I am wondering if they changed things between the old 8 speed and the new 11 speed from a mounting perspective? hopefuly I just need to buy an adapter or something, any ideas.... and thanks in advance.
Gates Rear Hub.jpg (197.94 KiB) Viewed 3093 times
comradegerry
Postby recumpence » Thu May 26, 2011 7:16 am
Hmm, just use a really big hammer. :mrgreen:
That is something Miles has to "Moogle" for you. :wink:
Your box shipped a few days ago.........
I am looking forward to this. This build has been a long time in coming.
Matt
recumpence
Postby comradegerry » Thu May 26, 2011 9:04 am
Hi Matt
Over a year in the dreaming / planning and gathering stage, several thousand dollars later and the ball is well and truly rolling....
New Batteries arrived only last week, need to play with them once the frame is rolling, will definately be seeking expert advice on their wiring from the learned on the forum!
Look forward to your full susser, great looking frame to start with.... :mrgreen:
Batteries LifePo4.jpg (168.84 KiB) Viewed 3046 times
comradegerry
Postby Philistine » Thu May 26, 2011 8:39 pm
What sort of batteries are those?
Philistine
Postby AussieJester » Thu May 26, 2011 8:52 pm
Whiplash wrote:I hope you plan on welding that splitter there! I would NEVER Trust a press fit on a frame component like that without SOMETHING else, even some bad ass epoxy or something....
Where exacty do you think it is going to go? the belt will be tensioned tightly this alone
will hold it all together, together with the motor constantly pull the chain and seat
stays forward will prevent it ever falling off backwards...
KiM
AussieJester
Postby Whiplash » Thu May 26, 2011 10:18 pm
I guess I am just a stickler for chassis stuff, if I did it like that, I guanty you it would break the first time I rode it! Lol!
Whiplash
Postby Dingo2024 » Fri May 27, 2011 11:03 am
comradegerry wrote:Hi Whiplash, I was planning on using a chemical metal type epoxy if there was any play or room for it. Since there is no space for epoxy and I think the loads are compressive at that point of the frame I am willing to see how she goes. If I get some movement I will drill and tap a couple of grub screws to steady it. It took some whaling on it with a hammer, I don't think it would come out even if I wanted it to!
not sure if you have sorted this but this might help
http://thegoldenwrench.blogspot.com/201 ... d-hub.html
Ian :D
started as a boy, grew into a man....not sure where I am headed now
build thread; viewtopic.php?f=6&t=18130
top speed now stands at 43.9 mph
Dingo2024
Postby Philistine » Sat May 28, 2011 12:26 am
ComradeGerry I have stolen your idea with the rivnuts and it has worked a treat. The rivnut gun I got looks like it has a much thinner head than yours, and has worked no problem. Mine looks exactly like a poprivet gun, just with a different mandrel. So the mandrel/head is as thick as/no thicker than the rivnut itself. Hence it worked great. Looks just like a poprivet gun, just cost five times as much....
That was my last hurdle, when I get the time for a day in the garage I will have it going I'd say, will post up photos when I do...
Philistine
Postby Stevil_Knevil » Sat May 28, 2011 3:38 am
Wow, could not figure out why you split the frame - until the whole belt-drive-is-not-splitable reality set in.
That's some committed/hardcore sh!t, my friend :twisted:
Stevil_Knevil
Postby Philistine » Sun May 29, 2011 7:30 am
Here is my efforts with the rivnuts, was a cracking idea BTW, thanks a lot for it, works perfectly.
Here is where my bike is up to. I hope it isn't rude to post into your thread with my bike, but I thought it might be interesting to see where someone else is up to. I almost feel like I am wearing shoes in a mosque by posting a hub photo into the non-hub motor section. I await a scathing comment from Aussie Jester - and I deserve it, if I walked into a mosque with shoes I would await the abuse - or worse I guess.
It is a terrible photo I had to take in the garage where it stands, as it is too cold to take it outside for a photo tonight. The alumunium boxes are two boxes of 10S4P lipo (20S 20AH total). 24 Fet Lyen Controller, and a (*whispers under breath* 9C 8x8 - that I upgraded the phase wires on). Large screen cycle analyst, and the Halogen that plugs into the CA for power. To be done are tidy up the wiring, put in brake cables, attach cranks and chain, and plastic canopy and it is done.
Philistine
Postby comradegerry » Sun May 29, 2011 7:46 am
Good progress, looks like she is moving along nicely, look forward to the reports when you take her for a test drive. I am off to the LBS to get the bottom bracket installed tomorrow as I do not have the special tool. I have to get some bushings for the shock to fit over the 8mm bolts and also need a lock nut for the rear disc that also seems like a project for a specialist, that will be my evening tomorrow. It's amazing I do not seem to have any spare time at the moment and my girlfriend is feeling neglected.... better get this finished quick before she leaves!!
comradegerry
Postby recumpence » Sun May 29, 2011 9:54 am
Oh, no! I (wait for it)......... HUB MOTOR! String the guy up. Beat him with his own club! I cannot believe someone would be so daring as to post pictures of one of these abominations on this thread! :wink: :mrgreen:
It is good to see Greyborg frames being built up. It has been a long time in coming.
Matt
recumpence
Postby AussieJester » Sun May 29, 2011 7:41 pm
recumpence wrote:Oh, no! I (wait for it)......... HUB MOTOR! String the guy up. Beat him with his own club! I cannot believe someone would be so daring as to post pictures of one of these abominations on this thread! :wink: :mrgreen:
Matt
+1 !!! ...can a moderator please delete this frock immediately! :P Reason for deletion:- it's infecting the non hub section of the forum :mrgreen:
KiM
p.s couldn't you find a bigger controller? :-p
AussieJester
Postby Philistine » Sun May 29, 2011 10:40 pm
I know, I know, it is sick and unnatural isn't it? That is why God punished us Hubmotor riders with.....*trails off hanging head in shame*
Re the 24 Fet, I have found that is the only controller that can run decent current on the x5303.... oh, hang on, I've done it again, basically I have started talking about Easter with the Ayottola during Ramadan....
Sorry ComdradeGerry, I will get off your thread and take my filthy disgusting hubusexuality with me. Please continue, and do accept my apologies everyone. Maybe I can get trained not to like hubmotors any more, maybe then my father would start talking to me again....
Philistine
Postby Doctorbass » Sun May 29, 2011 10:52 pm
bla bla bla.... anti hub motor... they make me laugh! :roll:
Dont worrie... you'll ove your 5303 with a 24 fets controller! :twisted:
I love it with a 18 fets... so i can easy imagine how it will be with a 24 fets!
20s with 26" wheel will be really similar to my Giant setup with 24s and 24" wheel ... except.. your controller WILL NOT BLOW like mine did dozens of times!! :lol:
Btw.. Recumpence, my etrike with a 5304 and 9kW seem to have similar acceleration performances than your 20kW twin RC astro motor :wink: 0-60kmh in 3.5sec :mrgreen: .. btw.. my top speed is now 79km/h.
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby comradegerry » Mon May 30, 2011 4:47 am
Small progress over weekend, installed the Thomson seatpost and Tiogra Spider seat, seat is surprisingly comfortable once you get used to it, even though it does not look it. Tube needed a bit of filing internally for smooth fit just where the cut out for the compression is.
128mm bottom bracket from Tarty Bikes and shock from Ebay should get bushings today at LBS and installed, also getting 20mm spacer for steerer and extra fork tube cut down to size whilst I am there.
Shock has 600lb titanium spring installed, 400lb titanium spring next to it is just incase that it is too stiff for comfort.
Batteries in earlier photos are Lifebatt, forum member Armin hooked me up with batteries and BMS. Very happy with how they shipped and overall quality of product so far. They will be getting a thorough testing once I am up and running.
Bottom Bracket.jpg (194.49 KiB) Viewed 1152 times
Seat post and seat.jpg (212.55 KiB) Viewed 1156 times
Rear Shock.jpg (171.08 KiB) Viewed 1152 times
comradegerry
Postby recumpence » Mon May 30, 2011 6:57 am
Gerry,
Looks really, really great! I love the seat. :)
So, how much do you have invested in the bike at this point?
Matt
recumpence
Next
Who is online
Users browsing this forum: j3tch1u and 5 guests
