Would this kooky idea work?
Postby MikeFairbanks » Thu Apr 26, 2012 12:58 pm
You've all seen this by now here and there. It's called SUP (stand up paddle board). It was started in Hawaii about a hundred years ago so that surfers could bring a camera out at Waikiki and film the tourists who were riding waves in the outrigger canoes.
It died out quickly as telephoto lenses were developed, and was revived as a sport about fifteen years ago by a chap named Laird Hamilton.
Notice the paddle he uses.
Now, notice these e-devices.
http://uncrate.com/p/2009/04/craftsman- ... handle.jpg
See where I'm going with it?
What do you think?
MikeFairbanks
Re: Would this kooky idea work?
Postby cal3thousand » Thu Apr 26, 2012 1:29 pm
I think balance will be an issue with the increased torque. When you paddle, your body contracts synergist muscles that help you balance as you push the paddle through the water. When using a motor, your body will have to get used to using those muscles to keep you rigid and balanced as the motor makes torque. It would have to be a real smooth build up to speed. Otherwise, I believe, it will be hard to keep it down and control it.
Now, if you had a way to "hook" it to the board when you want thrust, that may fix those issues. The way I see it, it would be like trying to hold an outboard trolling motor instead of mounting it to the boat.
Heck, you wouldn't need to reinvent anything really, just buy a trolling motor and see how it goes. I'm interested to see what kind of battery setup can be used. Might not take much since trolling motors generally run on 12V Deep Cycle SLAs.
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby Ykick » Thu Apr 26, 2012 1:36 pm
Along the lines of a Bangkok water taxi?
Or, perhaps the cordless drill approach?
In order to handle any real thrust it's gonna need to be firmly attached.
Ykick
Postby MikeFairbanks » Thu Apr 26, 2012 6:29 pm
Well, the thing about Stand up Paddle Boarding is that eventually (pretty much a lot) the board will tip over, getting everything wet.
Some people like to SUP on flat water (lakes, marinas, lagoons, etc.), but most SUPers like to catch waves. They get into the waves much earlier than traditional hand-paddling, making so that the surfer not only gets the wave he wants (it can get competitive out there), but can get up on a plane riding and angling before the wave gets too steep.
So, using the trolling motor would probably create too much drag once he caught the wave.
Now, there's another option: Remote Control gliders have props that actually fold flat when the plane is gliding, but when the motor kicks in they become rigid (from spinning so fast) and create thrust. The rc pilot makes his plane climb to the desired altitude and then shuts off the motor, saving precious battery power for the wings. It enables the rc pilot to fly for an hour or so (more if he can find thermals), whereas the typical rc airplane will fly for 5-15 minutes.
But what about wetness. The system has to be completely submerged and inverted several times in an hour or two of surfing.
And how about this?
It's a stick that you use to push a skateboard, enabling the SUP surfer to keep in shape on land and enjoy a different way of propulsion on land other than using one foot to kick.
What if someone attached a small hub motor to the end, filled the shaft with some lipos, and had a way to push a skateboard. It would be like an e-skateboard, except that the skateboard would be unaffected, enabling the rider to use the board conventionally as well as electrically. I wonder if that would work.
So many dumb ideas that one of them might just work.
MikeFairbanks
Postby TylerDurden » Thu Apr 26, 2012 6:34 pm
The prop on a stick looks like a winning new combat sport to me.
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby cal3thousand » Thu Apr 26, 2012 6:46 pm
MikeFairbanks wrote:Well, the thing about Stand up Paddle Boarding is that eventually (pretty much a lot) the board will tip over, getting everything wet.
And how about this?
Well, now that you explain the issue of getting dumped often (something I completely disregarded), I think you need to think about how heavy the unit will be including battery and motor.
What is going to happen when you eventually fall? How do you keep from losing the power paddle? I'd have a hard time getting a 2lb weight off the bottom, especially if it is deeper than say 10 feet.
cal3thousand
Postby chvidgov.bc.ca » Thu Apr 26, 2012 6:48 pm
How about a 48V Mac motor with a prop attached on a kayak. I bet that puppy would sustain 4 knots, without much noise.
CatrikeRoad Rear9C 2805 KU123Sensorless CA
DevinciVancouver Front9C Disk
Rebike 20"R/16"F Bent C404 Front 48V 20A Crystalyte Pedal First
CCM 26" Cruiser Nexus 7 C406Front 48V 35Amp Crystalyte Start Imm
Sun EZSport CX 26R/20F LWBent C405 Front 48V 35Amp Crystalyte Start Imm
Giant Revive DX 20" Nexus 7 RearSusp with 9C Front 48V KU123
Actionbent T1 trike with Rear9C2806 KU123Sensorless CA
Vision R40 Recum USS SWB EZEE
CannondaleHooligan Cute100 48VHead 60T ring KU63
chvidgov.bc.ca
Postby cal3thousand » Thu Apr 26, 2012 7:01 pm
chvidgov.bc.ca wrote:How about a 48V Mac motor with a prop attached on a kayak. I bet that puppy would sustain 4 knots, without much noise.
Now that's an idea that I want to work on!
That way, I can go fishing anywhere and get to that secret spot before anyone else.
cal3thousand
Postby El_Steak » Thu Apr 26, 2012 7:25 pm
I researched this a while ago to use with a cheap inflatable boat on a tiny lake at the cottage. I'll probably go with the cordless drill approach. There's a thread somewhere on ES discussing the topic.
For the impeller, apparently one of the best choice is a 10x6 hobby plane propeller (non-folding). You can get them for 1.50$ a pop at Hobby King: http://www.hobbyking.com/hobbyking/stor ... oduct=5364
TidalForce S-750 frame
Rear 2807 in a 24" wheel fed by a Methods 100V 100A controller
LiPo config: 24s3p 15ah
All the details here: viewtopic.php?f=6&t=17166
El_Steak
Postby melodious » Thu Apr 26, 2012 8:07 pm
I believe electric propulsion has been trying to get a foothold of the water sporting community for a while now. This company looks legit. Their spokesman is big wave rider Garrett McNamara. Same guy who has is currently sitting on the claim to fame of riding the largest wave in history about 6 months ago off of Portugal's coast. You may be able to grab some ideas behind this. :idea:
http://www.wavejet.com/
melodious
Postby melodious » Thu Apr 26, 2012 8:28 pm
Dang. I had befriended Wavejet on facebook but I've not been on that social group for a while now. I thought they had posted a video of the insides. And ohso glorious youtube has nothing about the insides as well. :?
melodious
Postby amberwolf » Fri Apr 27, 2012 5:37 pm
Look up their patents; that will show them. ;)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby 999zip999 » Fri Apr 27, 2012 10:09 pm
I seen a guy in san clemente take a old surfboard and bolt on a milk crate for the batteries and use a trolling motor bolted to the crate.
999zip999
Postby REdiculous » Sat Apr 28, 2012 1:59 am
I think I'd want it integrated into the board so I could keep the paddle and do the throttle w/ my feet.
I put a small 3 bladed fan on a weed whacker and got my little fishing boat moving pretty good with a couple people in it. We had to pull the clutch springs out otherwise it'd always be slipping and get extremely hot (vs really hot), and we used a couple (wet) old towels to cool it. It's kind of tricky to slam a spinning prop into the water but at least then it would go more than 100ft without overheating. We were young and bored, go figure. :)
REdiculous
Postby dogman » Sat Apr 28, 2012 7:27 am
Laird is my hero god. Back in the day, when I was just getting started learning to windsurf, he was the top competetive windsurfer worldwide. Then he made that look like nuthin by pioneering tow in surfing at Jaws.
Stand up using a weedwhacker would be hard to waterproof. primarily because the motor is located in the lower end. But a motor on the dry end could be waterproofed, or a regular trolling motor used with it's motor seals.
Just paddling anything is cheap fun. Last spring we spent some of our fun budget on one of those sit on top style Kyacks. Perfect for light surf, or the water we have, a no rapids river or lake. Those plastic kyaks used to be quite pricy, but now they are down as low as $300-400. Very affordable summer fun.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby sk8norcal » Mon Apr 30, 2012 3:48 am
And how about this?
its been done....
http://wackyboards.blogspot.com/2009/07 ... epter.html
sk8norcal
Return to General Discussion
Who is online
Users browsing this forum: mdd0127 and 4 guests
