Reid Welch
I recall very little of a long-ago discussion at the defunct panel.
My want then was direct DC to DC conversion of non-standard voltages,
about a four amp output.
I hope I can be steered by fechter the fantastic or other big brawny brains here,
the EV Tech pack will be at 42 to ca. 33V across its discharge range.
I'd like to run my 12V nominal 20W halogen headlamp at a regulated 15.5V --for the white color, brilliance and lumen efficiency.
I can use the same regulated voltage to run my motor's hair drier force cooling blower.
I did these things before now with a 14.4 NiMh water bottle battery.
It'd be nice to lose that time-limiting water bottle, and work directly from the bike's pack.
Efficiency isn't a concern.
Reasonably decent regulation is the want,
so the output should remain within a volt or of target regardless of the load (light plus blower, or light sans blower, or no substantial load at all.
I can't use 12V output===the headlight is too weak and yellow at 12V.
It lasts just fine for me at 15.5V
Is there a turnkey solution?
Can I pay anyone here to make for me a 4A converter?
Thanks for advice,
Reid
_____________
edit: post-posting I thought to Google.
I find Powerstream, and have sent off a note of inquiry.
Maybe they have an off the shelf unit that can be adapted to do the job.
http://www.powerstream.com/dcdc.htm
Thanks for advice,
Reid
_____________
