EddySPalm
Hi, I am quite restricted space wise on my battery pack, and for this reason plus aesthetic reasons I would like a BMS that fits within the width of my battery pack (which is the length of an 18650 cell + holders).
My chemistry is of course Li-ion, it's 16s, and I would like somewhere between 100 and 150A continuous current draw capacity.
I Just found one over at smart-bms.com, rated for 100A continuous and 150A peak (cut-off). This SHOULD be enough, and has the added bonus of BT compatibility, but I would really like to have one rated for a little bit more.
http://www.smart-bms.com/English/Product/642107113.html
What's a little sad is that smart-bms.com has a 13s BMS with 120A continuous limit, and 230A cut-off, this would be perfect for me in 16s!
http://www.smart-bms.com/English/Product/596301121.html
Also, tiny BMS can support such currents, if used with an external current sensor and relay, but I'd rather not over complicate my wiring, as this is not my expertise... Unfortunately, it supports only 60A continuous as is.
https://www.energusps.com/shop/product/tiny-bms-s516-150a-750a-36
Supower/batterysupports.com has one all the capacity I think I will need. It can handle 150A continuous, which is the same current as where it cuts off, strangely enough (to me at least). What sad is that it is simply too big, and I would only choose it as a last option.
https://www.aliexpress.com/item/SuPower-16S-57-6V-59-2V-60V-150A-Li-ion-Lithium-LiPo-Battery-BMS-Management-System/32802616270.html?spm=2114.search0104.3.1.ZZjvQG&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10344_10345_10342_10343_10340_10341_10541_10307_10060_10155_10154_10056_10055_10539_10537_10536_10059_10534_10533_100031_10103_10102_5670011_10142_10107_10171_5660011_5740011_10084_10562_10083_10561_10312_10313_10314_10550_10073_10551_10552_10553_10554_10557_5650011,searchweb201603_24,ppcSwitch_7&btsid=76758233-e39e-4693-969c-c62619348ea8&algo_expid=7aa60c4b-1673-4248-8652-bd80d9cc8f52-0&algo_pvid=7aa60c4b-1673-4248-8652-bd80d9cc8f52
Now do you guys know of any more alternatives than the ones I've listed?
