Autocycle
10 µW
Hi All,
I thought I'd start a general thread about my new build where I could ask questions and share the outcome. I'm ordering the motor and batteries in the coming days.
Based on my 250W 36V experience, if I have two 36V 20ah batteries (40ah) I will achieve 200km on ideal terrain with my fairly active input and normal (which is to say careful) use of power (sometimes at 100 per cent, sometimes at 75 or even 50 per cent). The obvious thing is to get the same kit again https://pirez.com.au/bbs01b-36v250w-bafang-mid-drive-kit/
However it occurs to me that it might be an idea to get a kit that I can use at lower power but generally, but call on for higher assistance when my distance is less but the mountains are...well...mountainous! For example a 500W kit https://pirez.com.au/bbs02b-36v500w-bafang-mid-drive-kit/
Or maybe a 750W 48V kit utilising a fraction of its power https://pirez.com.au/bbs02b-48v750w-bafang-mid-drive-kit/ I guess the other thing that springs to mind, given I'll be doing some long days, is the potential greater robustness of the bigger kit?
Does anybody have any advice? My aim is distance above all, and robustness. Am I wrong in thinking that just using less power - say, running the 500W at half power to equal a 250W drain and even less as I often do - will maintain the frugality I need for range? Am I right in thinking the bigger kits are more robust?
Ps I'm pretty settled on this bike, in fact I'm looking at it tomorrow and expect I'll buy it. https://www.reidcycles.com.au/granite-1-0.html This build will be coming together quickly in the coming weeks and then ridden on some long tours, I'll keep you updated with the outcome.
Regards,
Matt
Regards,
Matt
