999zip999
100 TW
So I have custom built Samsung 40t 20s 6p Custom made battery 1,200 USD with BT BMS. It fully charges to 84v if needed. I was testing a different controller and it was hooked to the ceiling with a strap and I gave it a little throttle and it jumped into the bench. And now the battery is resting at 81.46volts and reading the BMS in print says 81.46v but at the top of the screen reads 61% the dial arrow that shows charge yes the big one on top and the cells individually read correct at 4.07 or so which is correct ???
