vipertriplex
- Joined
- Jul 3, 2016
- Messages
- 28
My Spring Frankenstein has come to life. Yes, "ITS ALIVE, ITS ALIIIIIVE!!!!
Except with a bit of constipation perhaps.
I picked up on a Cromotor and did the Adaptto Max-E shuffle all the way to the workshop. The installation of the two was one of the many challenges I had to face but I think I pulled it off quite nicely.. Im more the builder then I am electronics guru so hopefully someone has come across these tiny nuggs of pleasure in their travels.
The problem I am having is in regards to my readings that just don't seem to make sense to me. Namely, Temp, Battery Capacity and speed...
First problem I am having is in my temp readingView attachment 2
Reading 321 in a room temp of 75
I ran a Motor Detection that was successful. immediately following the test the system shut down due to what I believe to be a temp trip in the motor the reached its 330 mark. 5 minutes later, system comes back up. Below are the images after testing
The next problem Im having is with the battery capacity. The pack I am running is a 86V 18AH 60A battery. Fresh off the charger and dropped in only reads 41% capacity remaining.
Lastly is my speed. From my calculations I should be getting a lot better then 60MPH and seems to be governed there, is that the case?
Any help you guys could offer I would greatly appreciate...
Thanks again and Happy Holidays to all
