I'd like to adjust the cut-off voltage of my charger so I can set it to charge my battery to 80% for optimum lifetime. I'm just never going to figure out the timing to unplug it around the right time, especially since I'll be charging from a random level of discharge. I opened up the charger and found 3 pots, but don't know which to adjust or how to know what I'm adjusting to. Can I simply attach a volt meter to the output with no load to measure what I'm setting it to? I'd rather not experiment with all three to see which adjusts the cut-off.
Also I'm thinking about removing the PCB, unsoldering the POT and either mounting the existing one in the case, or maybe mounting a plug where I can stick in specific resistors for the 2 - 4 values I might want.
