sebastianzkerr
- Joined
- May 16, 2019
- Messages
- 12
Currently I am making a small, lightweight, sporty electric motorcycle, and am planning on using the 20kW cyclone hub motor. I'm aware that the 20kW is the peak power, but I still think it's a good choice for it's price. The only problem is the batteries; I'd like to make my own custom battery pack from 21700 Lithium-ion cells, but it seems to be pretty costly. Doing the math, for a 33S-5P pack, using the Samsung 30T cells (https://www.imrbatteries.com/samsung-30t-21700-3000mah-35a-battery/), the cost would be around $900 USD, which is kind of a lot... And even then, I only get 1.8kWh from it. For a 6kWh battery pack, which was sort of my goal, it would be damn near $3,000. Li-ion is my chemistry of choice due to the energy density, especially since I'm trying to keep this bike under 100kg if I can. Fitment isn't a big issue since I'm planning to create a custom carbon frame to keep the battery and controller tucked away and help weight balance. Inspiration comes from this: (http://novusbike.com/en/bike) but with a bit less radical of a design. So is there a better way to do this? A cheaper cell for my requirements (120V@170A)? Maybe a cheap pre-made battery that will work fine?
