chazRevo
100 µW
EDIT: For those looking for a quick answer, the password for C695 is 0512. you access the advanced menu by 1) long press + and - to get to the first menu. 2) long press + and - again to get to password prompt. Wheel size, PAS levels, and speed limit are set in the menu after the password prompt. Manual for C695 attached in posts below.
I've been lurking and reading a ton on this site, and jumped in recently. I got a Bafang BBS02 from em3ev. It arrived this week, and i have been putting it together. So far it has all been very easy, but here is the rub:
It has a C695 display with only three buttons Power, +, -. I can power on, change PAS from 0 to 3. throttle and PAS are working OK. speed limit is set at 30km/h though, and I cannot access the advanced menu. :?
I have looked at various C695 manuals (from paul and lectric cycles, etc) but those don't match up with how my unit works. I dont have up or down buttons, and I cant access the parameters menu by double press of Power. I also looked at c691 manuals, and had a bit more luck. If I 'long press' + and - I get to a menu with some basic settings (not speed, wheel diameter, or # of PAS levels). Those are the three things I am after. long press of + and - with 8 presses of M does not do anything.
If I 'long press' + and - again in this menu it takes me to a password prompt. I entered "1919" as mentioned in the manuals. I also tried some other dummy ones like 1111, 1234, 0123, etc. No luck getting past this prompt. I have a feeling the settings I want are all hidden behind this wall.
Does anyone have any tips or ideas how I can change the speed, wheel, and PAS settings? Is there a way to 'reset' the password?
I will also send to Paul, but I probably wont hear back from him until after the weekend. I'll post my progress here if I make any.
